12-06-2018, 22:06 | #18 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | XT1562_boot_files.zip (from LUX_RETEU_7.1.1_NPD26.48-24-1_cid7_subsidy-DEFAULT_CFC) https://mega.nz/#!GMgVXYYT!paYgKtXR2...qV0FMvXz80sUdA post results, pls Add all files, include boot, recovery Last edited by layder; 12-06-2018 at 22:12. |
The Following User Says Thank You to layder For This Useful Post: |
12-08-2018, 17:54 | #20 (permalink) | |
Freak Poster Join Date: Oct 2016 Location: india
Member: 2636476 Status: Offline Thanks Meter: 61 | Quote:
unfortunately can't detect set tha't why i can't post result Code: 12/8/2018 5:39:19 PM> Looking for EasyJTAG box... 12/8/2018 5:39:19 PM> EasyJTAG API ver. 2100 12/8/2018 5:39:19 PM> Setting IO Levels to 1.8V 12/8/2018 5:39:19 PM> Setting frequence to 18 Mhz 12/8/2018 5:39:19 PM> EasyJTAG Box Serial = 52940E1C263B0124 12/8/2018 5:39:19 PM> EasyJTAG Box Firmware = 2.30 12/8/2018 5:39:20 PM> Setting interface to EasyJtag2/ISP 12/8/2018 5:39:20 PM> Setting bus width to 1 Bit 12/8/2018 5:39:20 PM> Setting frequence to 18 Mhz 12/8/2018 5:39:20 PM> CMD Pullup Level: 1840 mV 12/8/2018 5:39:20 PM> CMD Active Level: 1850 mV 12/8/2018 5:39:20 PM> eMMC Init returned = -1 12/8/2018 5:39:20 PM> Can't init device. Reason: CMD Timeout Error 12/8/2018 5:39:20 PM> 12/8/2018 5:39:31 PM> Looking for EasyJTAG box... 12/8/2018 5:39:31 PM> EasyJTAG API ver. 2100 12/8/2018 5:39:31 PM> Setting IO Levels to 1.8V 12/8/2018 5:39:31 PM> Setting frequence to 18 Mhz 12/8/2018 5:39:31 PM> EasyJTAG Box Serial = 52940E1C263B0124 12/8/2018 5:39:31 PM> EasyJTAG Box Firmware = 2.30 12/8/2018 5:39:31 PM> Setting interface to EasyJtag2/ISP 12/8/2018 5:39:31 PM> Setting bus width to 1 Bit 12/8/2018 5:39:31 PM> Setting frequence to 18 Mhz 12/8/2018 5:39:31 PM> CMD Pullup Level: 1853 mV 12/8/2018 5:39:32 PM> CMD Active Level: 1850 mV 12/8/2018 5:39:32 PM> eMMC Init returned = -2 12/8/2018 5:39:32 PM> Can't init device. Reason: CMD CRC Error | |
12-20-2018, 15:15 | #21 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2772222 Status: Offline Thanks Meter: 9 | I did a backup from a original eMMC Chip, Rom1, Rom2, ROM3, Extcsd. I have to chance Emmc, because I damaged. Original eMMC KMRX1000BM, the substitute KQMX10013M. The new eMMC was formatted and write ROM2-3, EXTcsd, and ROM1 with you boot files. Log: Setting interface to EasyJtag2/E-Socket Setting bus width to 8 Bit Setting frequence to 21 Mhz EMMC Device Information : EMMC CID: 150100525831424D42074F0CDE979391 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: RX1BMB , HEX: 525831424D42 , S/N: 4F0CDE97 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: RX1BMB_4F0CDE97_20181217_101548.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000020000 - 0000000A0000], size: 000000080000 (512 KB) Partition: rpm, [0000000A0000 - 0000000E0000], size: 000000040000 (256 KB) Partition: tz, [000000120000 - 0000002E0000], size: 0000001C0000 (1,75 MB) Partition: devcfg, [000000320000 - 000000330000], size: 000000010000 (64,0 KB) Partition: aboot, [000000360000 - 0000004E0000], size: 000000180000 (1,50 MB) Partition: cmnlib, [0000004E0000 - 000000520000], size: 000000040000 (256 KB) Partition: cmnlib64, [000000520000 - 000000560000], size: 000000040000 (256 KB) Partition: keymaster, [000000560000 - 0000005A0000], size: 000000040000 (256 KB) Partition: prov, [0000005A0000 - 0000005D0000], size: 000000030000 (192 KB) Partition: sbl1bak, [0000005E0000 - 000000660000], size: 000000080000 (512 KB) Partition: rpmbak, [000000660000 - 0000006A0000], size: 000000040000 (256 KB) Partition: tzbak, [0000006E0000 - 0000008A0000], size: 0000001C0000 (1,75 MB) Partition: devcfgbak, [0000008E0000 - 0000008F0000], size: 000000010000 (64,0 KB) Partition: abootbak, [000000920000 - 000000AA0000], size: 000000180000 (1,50 MB) Partition: cmnlibbak, [000000AA0000 - 000000AE0000], size: 000000040000 (256 KB) Partition: cmnlib64bak, [000000AE0000 - 000000B20000], size: 000000040000 (256 KB) Partition: keymasterbak, [000000B20000 - 000000B60000], size: 000000040000 (256 KB) Partition: provbak, [000000B60000 - 000000B90000], size: 000000030000 (192 KB) Partition: modem, [000000BA0000 - 000006FA0000], size: 000006400000 (100 MB) Partition: fsc, [000006FA0000 - 000006FA0400], size: 000000000400 (1,00 KB) Partition: ssd, [000006FA0400 - 000006FA2400], size: 000000002000 (8,00 KB) Partition: dsp, [000006FA2400 - 000007FA2400], size: 000001000000 (16,0 MB) Partition: DDR, [000007FC0000 - 000007FC8000], size: 000000008000 (32,0 KB) Partition: sec, [000007FC8000 - 000007FCC000], size: 000000004000 (16,0 KB) Partition: utags, [000007FE0000 - 000008060000], size: 000000080000 (512 KB) Partition: utagsBackup, [000008060000 - 0000080E0000], size: 000000080000 (512 KB) Partition: modemst1, [0000080E0000 - 0000082E0000], size: 000000200000 (2,00 MB) Partition: modemst2, [0000082E0000 - 0000084E0000], size: 000000200000 (2,00 MB) Partition: fsg, [0000084E0000 - 000008CE0000], size: 000000800000 (8,00 MB) Partition: persist, [000008CE0000 - 00000ACE0000], size: 000002000000 (32,0 MB) Partition: frp, [00000ACE0000 - 00000AD60000], size: 000000080000 (512 KB) Partition: cid, [00000AD60000 - 00000AD80000], size: 000000020000 (128 KB) Partition: logo, [00000AD80000 - 00000BD80000], size: 000001000000 (16,0 MB) Partition: carrier, [00000BD80000 - 00000CD80000], size: 000001000000 (16,0 MB) Partition: metadata, [00000CD80000 - 00000CE00000], size: 000000080000 (512 KB) Partition: kpan, [00000CE00000 - 00000D600000], size: 000000800000 (8,00 MB) Partition: boot, [00000D600000 - 00000E600000], size: 000001000000 (16,0 MB) Partition: recovery, [00000E600000 - 00000F619000], size: 000001019000 (16,1 MB) Partition: misc, [00000F620000 - 00000F720000], size: 000000100000 (1,00 MB) Partition: limits, [00000F720000 - 00000F728000], size: 000000008000 (32,0 KB) Partition: mota, [00000F740000 - 00000F7C0000], size: 000000080000 (512 KB) Partition: dip, [00000F7C0000 - 00000F8C0000], size: 000000100000 (1,00 MB) Partition: syscfg, [00000F8C0000 - 00000F940000], size: 000000080000 (512 KB) Partition: logs, [00000F940000 - 00000FB40000], size: 000000200000 (2,00 MB) Partition: apdp, [00000FB40000 - 00000FB80000], size: 000000040000 (256 KB) Partition: msadp, [00000FB80000 - 00000FBC0000], size: 000000040000 (256 KB) Partition: dpo, [00000FBC0000 - 00000FBC2000], size: 000000002000 (8,00 KB) Partition: padA, [00000FBE0000 - 000010000000], size: 000000420000 (4,13 MB) Partition: sp, [000010000000 - 000010800000], size: 000000800000 (8,00 MB) Partition: hw, [000010800000 - 000011000000], size: 000000800000 (8,00 MB) Partition: oem, [000011000000 - 000041000000], size: 000030000000 (768 MB) Partition: cache, [000041000000 - 000051000000], size: 000010000000 (256 MB) Partition: system, [000051000000 - 000151000000], size: 000100000000 (4,00 GB) Partition: userdata, [000151000000 - 000151000200], size: 000000000200 (512 B) GPT header successfully parsed Later a soldering Chip and phone continue in QD Loader. So I flashed new boot files that my friend, o__rionTG, provide me. Log: Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 Mhz CMD Pullup Level: 1651 mV CMD Active Level: 1870 mV EMMC Device Information : EMMC CID: 150100515831334D4207DD86E445938F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: DD86E445 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_DD86E445_20181220_080718.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 Mhz CMD Pullup Level: 1651 mV CMD Active Level: 1868 mV EMMC Device Information : EMMC CID: 150100515831334D4207DD86E445938F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: DD86E445 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_DD86E445_20181220_081006.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon) Partition name: sbl1 Filename: sbl1_PhysPart_0_28_11_2018_15_10_43.bin , Offset: 000000020000 , filesize: 524288 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 234,15 KB/s Partition name: tz Filename: tz_PhysPart_0_28_11_2018_15_10_43.bin , Offset: 000000120000 , filesize: 1835008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 427,79 KB/s Partition name: devcfg Filename: devcfg_PhysPart_0_28_11_2018_15_10_44.bin , Offset: 000000320000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 474,60 KB/s Partition name: aboot Filename: aboot_PhysPart_0_28_11_2018_15_10_44.bin , Offset: 000000360000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 459,55 KB/s Partition name: cmnlib Filename: cmnlib_PhysPart_0_28_11_2018_15_10_44.bin , Offset: 0000004E0000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 460,19 KB/s Partition name: cmnlib64 Filename: cmnlib64_PhysPart_0_28_11_2018_15_10_44.bin , Offset: 000000520000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 461,35 KB/s Partition name: keymaster Filename: keymaster_PhysPart_0_28_11_2018_15_10_45.bin , Offset: 000000560000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 461,22 KB/s Partition name: prov Filename: prov_PhysPart_0_28_11_2018_15_10_45.bin , Offset: 0000005A0000 , filesize: 196608 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 453,31 KB/s Partition name: boot Filename: boot_PhysPart_0_28_11_2018_15_12_16.bin , Offset: 00000D600000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 456,53 KB/s Partition name: recovery Filename: recovery_PhysPart_0_28_11_2018_15_12_22.bin , Offset: 00000E600000 , filesize: 16879616 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 455,11 KB/s All done time: [00:01:35:646] Setting interface to EasyJtag2/ISP_HiPower Setting bus width to 1 Bit HiPower mode is ON Setting frequence to 4 Mhz CMD Pullup Level: 1816 mV CMD Active Level: 1867 mV EMMC Device Information : EMMC CID: 150100515831334D4207DD86E445938F EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: DD86E445 , rev. 0x07 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 9/2016 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_DD86E445_20181220_115121.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000020000 - 0000000A0000], size: 000000080000 (512 KB) Partition: rpm, [0000000A0000 - 0000000E0000], size: 000000040000 (256 KB) Partition: tz, [000000120000 - 0000002E0000], size: 0000001C0000 (1,75 MB) Partition: devcfg, [000000320000 - 000000330000], size: 000000010000 (64,0 KB) Partition: aboot, [000000360000 - 0000004E0000], size: 000000180000 (1,50 MB) Partition: cmnlib, [0000004E0000 - 000000520000], size: 000000040000 (256 KB) Partition: cmnlib64, [000000520000 - 000000560000], size: 000000040000 (256 KB) Partition: keymaster, [000000560000 - 0000005A0000], size: 000000040000 (256 KB) Partition: prov, [0000005A0000 - 0000005D0000], size: 000000030000 (192 KB) Partition: sbl1bak, [0000005E0000 - 000000660000], size: 000000080000 (512 KB) Partition: rpmbak, [000000660000 - 0000006A0000], size: 000000040000 (256 KB) Partition: tzbak, [0000006E0000 - 0000008A0000], size: 0000001C0000 (1,75 MB) Partition: devcfgbak, [0000008E0000 - 0000008F0000], size: 000000010000 (64,0 KB) Partition: abootbak, [000000920000 - 000000AA0000], size: 000000180000 (1,50 MB) Partition: cmnlibbak, [000000AA0000 - 000000AE0000], size: 000000040000 (256 KB) Partition: cmnlib64bak, [000000AE0000 - 000000B20000], size: 000000040000 (256 KB) Partition: keymasterbak, [000000B20000 - 000000B60000], size: 000000040000 (256 KB) Partition: provbak, [000000B60000 - 000000B90000], size: 000000030000 (192 KB) Partition: modem, [000000BA0000 - 000006FA0000], size: 000006400000 (100 MB) Partition: fsc, [000006FA0000 - 000006FA0400], size: 000000000400 (1,00 KB) Partition: ssd, [000006FA0400 - 000006FA2400], size: 000000002000 (8,00 KB) Partition: dsp, [000006FA2400 - 000007FA2400], size: 000001000000 (16,0 MB) Partition: DDR, [000007FC0000 - 000007FC8000], size: 000000008000 (32,0 KB) Partition: sec, [000007FC8000 - 000007FCC000], size: 000000004000 (16,0 KB) Partition: utags, [000007FE0000 - 000008060000], size: 000000080000 (512 KB) Partition: utagsBackup, [000008060000 - 0000080E0000], size: 000000080000 (512 KB) Partition: modemst1, [0000080E0000 - 0000082E0000], size: 000000200000 (2,00 MB) Partition: modemst2, [0000082E0000 - 0000084E0000], size: 000000200000 (2,00 MB) Partition: fsg, [0000084E0000 - 000008CE0000], size: 000000800000 (8,00 MB) Partition: persist, [000008CE0000 - 00000ACE0000], size: 000002000000 (32,0 MB) Partition: frp, [00000ACE0000 - 00000AD60000], size: 000000080000 (512 KB) Partition: cid, [00000AD60000 - 00000AD80000], size: 000000020000 (128 KB) Partition: logo, [00000AD80000 - 00000BD80000], size: 000001000000 (16,0 MB) Partition: carrier, [00000BD80000 - 00000CD80000], size: 000001000000 (16,0 MB) Partition: metadata, [00000CD80000 - 00000CE00000], size: 000000080000 (512 KB) Partition: kpan, [00000CE00000 - 00000D600000], size: 000000800000 (8,00 MB) Partition: boot, [00000D600000 - 00000E600000], size: 000001000000 (16,0 MB) Partition: recovery, [00000E600000 - 00000F619000], size: 000001019000 (16,1 MB) Partition: misc, [00000F620000 - 00000F720000], size: 000000100000 (1,00 MB) Partition: limits, [00000F720000 - 00000F728000], size: 000000008000 (32,0 KB) Partition: mota, [00000F740000 - 00000F7C0000], size: 000000080000 (512 KB) Partition: dip, [00000F7C0000 - 00000F8C0000], size: 000000100000 (1,00 MB) Partition: syscfg, [00000F8C0000 - 00000F940000], size: 000000080000 (512 KB) Partition: logs, [00000F940000 - 00000FB40000], size: 000000200000 (2,00 MB) Partition: apdp, [00000FB40000 - 00000FB80000], size: 000000040000 (256 KB) Partition: msadp, [00000FB80000 - 00000FBC0000], size: 000000040000 (256 KB) Partition: dpo, [00000FBC0000 - 00000FBC2000], size: 000000002000 (8,00 KB) Partition: padA, [00000FBE0000 - 000010000000], size: 000000420000 (4,13 MB) Partition: sp, [000010000000 - 000010800000], size: 000000800000 (8,00 MB) Partition: hw, [000010800000 - 000011000000], size: 000000800000 (8,00 MB) Partition: oem, [000011000000 - 000041000000], size: 000030000000 (768 MB) Partition: cache, [000041000000 - 000051000000], size: 000010000000 (256 MB) Partition: system, [000051000000 - 000151000000], size: 000100000000 (4,00 GB) Partition: userdata, [000151000000 - 000747BFBE00], size: 0005F6BFBE00 (23,8 GB) GPT header successfully parsed Get firmware version Firmware info not found Now phone is in Fastboot Log Mfastboot: E:\MaximoAssisTec\Motorola\Software\MFastboot>mfas tboot getvar all version: 0.5 version-bootloader: moto-msm8953-C1.82(*) product: unknown board: unknown secure: yes hwrev: unknown radio: 0 storage-type: emmc emmc: 32GB SAMSUNG QX13MB RV=08 PV=07 FV=0000000000000007 ram: 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F cpu: MSM8953 serialno: dd86e445 cid: 0xDEAD channelid: 0x00 uid: 0000000000000000000000000000 securestate: oem_locked iswarrantyvoid: n/a max-download-size: 534773760 reason: Failed to initialize partition table imei: 000000000000000 meid: date: 01-01-1970 sku: 000000000000000 battid: iccid: cust_md5: max-sparse-size: 268435456 current-time: ro.build.fingerprint: poweroffalarm: 0 ro.build.version.full: ro.build.version.qcom: version-baseband: kernel.version: sbl1.git: sbl1.git rpm.git: rpm.git tz.git: tz.git devcfg.git: devcfg.git keymaster.git: keymaster.git cmnlib.git: cmnlib.git cmnlib64.git: cmnlib64.git prov.git: prov.git aboot.git: git=MBM-NG-VC1.82-0-g345bd7e frp-state: no protection (err) ro.carrier: all: listed above finished. total time: 0.125s When I try flash by UMT Box Port : Fastboot Interface Baud Rate : Not Applicable Device : Motorola QC Operation : Flash Fw Model : addison Fw Version : addison-user 8.0.0 OPNS27.76-12-22-9 10 release-keysM8953_10238.63.04.83.01R Searching for Device in FastBoot Mode... OK Reading Phone Information... Model : 000000000000000 Boot Ver. : moto-msm8953-C1.82(*) Baseband : Not Found Software : Not Found IMEI : 000000000000000 CPU : MSM8953 RAM : 2GB SAMSUNG LP3 DIE=8Gb M5=01 M6=05 M7=00 M8=1F EMMC : 32GB SAMSUNG QX13MB RV=08 PV=07 FV=0000000000000007 Sending Data [partition]... Denied Possibly Downgraded Version! Use same version or higher. Operation Failed. Elapsed Time: 00:05 [Module Ver. 5.2] When I try flash By MFastboot E:\MaximoAssisTec\Motorola\Software\MFastboot>mfas tboot flash partition gpt.bin sending 'partition' (45 KB)... OKAY [ 0.000s] writing 'partition'... Validating 'gpt.default.xml' Image primary_gpt failed validation Preflash validation failed Cancelling 'gpt.default.xml' FAILED (remote failure) finished. total time: 0.078s E:\MaximoAssisTec\Motorola\Software\MFastboot>mfas tboot flash bootloader bootloader.img sending 'bootloader' (5115 KB)... OKAY [ 0.109s] writing 'bootloader'... Validating 'bootloader.default.xml' Invalid partition name aboot Invalid partition name rpm Invalid partition name tz Invalid partition name devcfg Invalid partition name cmnlib Invalid partition name cmnlib64 Invalid partition name keymaster Invalid partition name prov Invalid partition name sbl1 Cancelling 'bootloader.default.xml' FAILED (remote failure) finished. total time: 0.234s By experience, I'm thinking that I need the last Firmware. Alright? |
