11-05-2018, 14:09 | #1 (permalink) |
Junior Member Join Date: Oct 2018
Member: 2874213 Status: Offline Thanks Meter: 9 | Sm-j400f emmc config CMD Pullup Level: 402 mV CMD Active Level: 2196 mV EMMC Device Information : EMMC CID: 150100515831334D4200565CF27955C4 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 565CF279 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_565CF279_20181105_160009.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: cm.bin Unpacking file: sboot.bin Unpacking file: nad_refer.bin Unpacking file: param.bin Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: nad_fw.bin Partition name: CM Filename: cm.bin , Offset: 000000000000 , filesize: 2183696 bytes eMMC switching to ROM3 Erasing partition... Writing partition... Done writing partition. Write speed: 328.19 KB/s Partition name: BOOTLOADER Filename: sboot.bin , Offset: 000000000000 , filesize: 1602064 bytes eMMC switching to ROM2 Erasing partition... Writing partition... Done writing partition. Write speed: 331.91 KB/s Partition name: NAD_REFER Filename: nad_refer.bin , Offset: 000003400000 , filesize: 65536 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 405.75 KB/s Partition name: PARAM Filename: param.bin , Offset: 000003500000 , filesize: 962560 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 629.62 KB/s Partition name: BOOT Filename: boot.img , Offset: 000003D00000 , filesize: 18115104 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 741.77 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000005D00000 , filesize: 21563936 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 734.00 KB/s Partition name: NAD_FW Filename: nad_fw.bin , Offset: 0000CE900000 , filesize: 4653072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 738.94 KB/s Partition CACHE : formatting as EXT4. Please wait ... Formatting completed Partition HIDDEN : formatting as EXT4. Please wait ... Formatting completed Partition USERDATA : formatting as EXT4. Please wait ... Formatting completed Check BootConfig for the selected vendor All done time: [00:02:13:094] Setting frequence to 21 Mhz CMD Pullup Level: 412 mV CMD Active Level: 2217 mV EMMC Device Information : EMMC CID: 150100515831334D4200565CF27955C4 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 565CF279 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_565CF279_20181105_160428.extcsd EMMC Init completed. Writing eMMC Register ... Reg: 179 Value: 0x48 Reg: 177 Value: 0x01 Reg: 162 Value: 0x01 Successfully Setting frequence to 21 Mhz CMD Pullup Level: 412 mV CMD Active Level: 2206 mV EMMC Device Information : EMMC CID: 150100515831334D4200565CF27955C4 EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: 565CF279 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 5/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_565CF279_20181105_160436.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: bota0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: bota1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: efs, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: cpefs, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: nad_refer, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: param, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: boot, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: recovery, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: radio, [000008300000 - 00000DB00000], size: 000005800000 (88.0 MB) Partition: persistent, [00000DB00000 - 00000DB80000], size: 000000080000 (512. KB) Partition: steady, [00000DB80000 - 00000DF80000], size: 000000400000 (4.00 MB) Partition: misc, [00000DF80000 - 00000E080000], size: 000000100000 (1.00 MB) Partition: dtbo, [00000E080000 - 00000E280000], size: 000000200000 (2.00 MB) Partition: reserved2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB) Partition: system, [00000E800000 - 0000AB000000], size: 00009C800000 (2.45 GB) Partition: vendor, [0000AB000000 - 0000BA000000], size: 00000F000000 (240. MB) Partition: odm, [0000BA000000 - 0000C7000000], size: 00000D000000 (208. MB) Partition: cache, [0000C7000000 - 0000CD000000], size: 000006000000 (96.0 MB) Partition: omr, [0000CD000000 - 0000CE400000], size: 000001400000 (20.0 MB) Partition: cp_debug, [0000CE400000 - 0000CE900000], size: 000000500000 (5.00 MB) Partition: nad_fw, [0000CE900000 - 0000CFD00000], size: 000001400000 (20.0 MB) Partition: hidden, [0000CFD00000 - 0000D6100000], size: 000006400000 (100. MB) Partition: userdata, [0000D6100000 - 000747BFBE00], size: 000671AFBE00 (25.7 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J400F CPU Abi = armeabi-v7a Android release = 8.0.0 Firmware version = R16NW.J400FXXU1ARE8 Firmware date = Tue May 15 22:40:22 KST 2018 |
The Following User Says Thank You to EMMC PT KING For This Useful Post: |
11-13-2018, 13:53 | #2 (permalink) |
Member: 2874213 Status: Offline Thanks Meter: 9 | sm-j400f emmc direct eMMC_tool Suite ver. 1.5.2.0 (release date: 06.08.2018) Microsoft Windows 10 (64 bit) build 17134 (10.0.17134.228) Looking for EasyJTAG box... EasyJTAG API ver. 2100 EasyJTAG Box Serial = 8B600F51929A6640 Card Serial = *********** EasyJTAG Box Firmware = 2.30 Changelog: 06.08.2018 (ver 1.5.2.0) Fix: Bugs that have been found through your crash report Fix: Writing ROM2 for Samsung (Write by vendor) Fix: Freezing the program on a RandomVerify Add: Folder for saving to Explorer (in settings) Add: Extract from store.vol from emmc (explorer) Add: Automatic repair of damaged store.vol when extracting (Explorer) Add: Adding MountPoints for partitions (efs, userdata) when formatting Add: Checking for an empty EFS before backup (Read by Vendor Samsung) Failed to connect to the server Setting interface to EasyJtag2/E-Socket Setting bus width to 1 Bit Setting frequence to 42 Mhz EMMC Device Information : EMMC CID: 150100514536334D42008304CE5A358D EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D EMMC Manufacture : SAMSUNG , EMMC NAME: QE63MB , HEX: 514536334D42 , S/N: 8304CE5A , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 15028 MB (0003AB400000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 16384 KB (000001000000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x48 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x01 , width 4bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QE63MB_8304CE5A_20181113_141141.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB) Partition: BOTA1, [000000800000 - 000000C00000], size: 000000400000 (4.00 MB) Partition: EFS, [000000C00000 - 000002000000], size: 000001400000 (20.0 MB) Partition: CPEFS, [000002000000 - 000002800000], size: 000000800000 (8.00 MB) Partition: m9kefs1, [000002800000 - 000002C00000], size: 000000400000 (4.00 MB) Partition: m9kefs2, [000002C00000 - 000003000000], size: 000000400000 (4.00 MB) Partition: m9kefs3, [000003000000 - 000003400000], size: 000000400000 (4.00 MB) Partition: NAD_REFER, [000003400000 - 000003500000], size: 000000100000 (1.00 MB) Partition: PARAM, [000003500000 - 000003D00000], size: 000000800000 (8.00 MB) Partition: BOOT, [000003D00000 - 000005D00000], size: 000002000000 (32.0 MB) Partition: RECOVERY, [000005D00000 - 000008300000], size: 000002600000 (38.0 MB) Partition: RADIO, [000008300000 - 00000DB00000], size: 000005800000 (88.0 MB) Partition: PERSISTENT, [00000DB00000 - 00000DB80000], size: 000000080000 (512. KB) Partition: STEADY, [00000DB80000 - 00000DF80000], size: 000000400000 (4.00 MB) Partition: MISC, [00000DF80000 - 00000E080000], size: 000000100000 (1.00 MB) Partition: DTBO, [00000E080000 - 00000E280000], size: 000000200000 (2.00 MB) Partition: RESERVED2, [00000E280000 - 00000E800000], size: 000000580000 (5.50 MB) Partition: SYSTEM, [00000E800000 - 0000AB000000], size: 00009C800000 (2.45 GB) Partition: VENDOR, [0000AB000000 - 0000BA000000], size: 00000F000000 (240. MB) Partition: ODM, [0000BA000000 - 0000CD000000], size: 000013000000 (304. MB) Partition: CACHE, [0000CD000000 - 0000D3000000], size: 000006000000 (96.0 MB) Partition: OMR, [0000D3000000 - 0000D4400000], size: 000001400000 (20.0 MB) Partition: CP_DEBUG, [0000D4400000 - 0000D4900000], size: 000000500000 (5.00 MB) Partition: NAD_FW, [0000D4900000 - 0000D5D00000], size: 000001400000 (20.0 MB) Partition: USERDATA, [0000D5D00000 - 0003AAD00000], size: 0002D5000000 (11.3 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J400F CPU Abi = armeabi-v7a Android release = 8.0.0 Firmware version = R16NW.J400FXXU2ARH5 Firmware date = Thu Aug 30 15:10:31 KST 2018 |
The Following 2 Users Say Thank You to EMMC PT KING For This Useful Post: |
