Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 01-15-2020, 10:36   #1 (permalink)
Member: 1471997
Thanks Meter: 16
Vivo V15 Pro Not Connecting with easy jatg ver1 box..Need HELP
Hello Everyone
i am using very useful box easy jtag But i am getting problem in vivo v15 pro,i am not able to connect this phone,i have version 1 box...
I am using this pinout
https://i.postimg.cc/sgyndvf7/Whats-...t-10-51-04.jpg
I Use This Isp Adapter For all Phones And using it for this phone
https://img.gem-flash.com/images/303...1150044319.jpg
Here Is Log
Selected pinout: EasyJTAG GEN1 ISP Pinout
Change EasyJTAG Pinout OK
Z3X EasyJtag Software ver. 3.6.1.15
Loading eMMC GEN1 Firmware... IO: 3300 mV
Box S/N: 16161317F77A2E59, ,FW Ver.: 01.63
CMD Pullup Level:2052 mV
CMD Active Level:2897 mV
Box IO Level:3300 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
CMD Pullup Level:2031 mV
CMD Active Level:2866 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
CMD Pullup Level:2041 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
Loading eMMC GEN1 Firmware... IO: 1800 mV
CMD Pullup Level:1907 mV
CMD Active Level:2083 mV
Box IO Level:1800 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
CMD Pullup Level:1897 mV
CMD Active Level:2062 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
CMD Pullup Level:2021 mV
CMD Active Level:2877 mV
CLK Rate:21000 kHz
Bus Width:1bit,SDR
Done.
I Checked Connectivity Properly But Same Condition,I checked In 3 Handset,Getting Same problem ,Oppo Realme Working connecting Proper...
Old 01-15-2020, 18:11   #2 (permalink)
Member: 13148
Thanks Meter: 1,460
Use "HiPower CLK" mode
CPH1803 dead by other tool
The Following User Says Thank You to layder For This Useful Post:
Old 01-16-2020, 05:54   #3 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 913
just connect 2.8v vcc
usb charger must be connected without battery
if not connect change vol 1.8 io/ips
Old 01-16-2020, 13:53   #4 (permalink)
Member: 1471997
Thanks Meter: 16
this time handset Done with another way,i am sure this will work,next time i will try..
Old 01-16-2020, 13:55   #5 (permalink)
Member: 1471997
Thanks Meter: 16
as you see in my posted pinout there in no vcc or vccq point,if you have pinout with vcc or vccq ,it will be helpful for everyone..
Old 01-19-2020, 02:57   #6 (permalink)
murari-GSM's Avatar
Member: 1538128
Sonork: 100.1613105
Thanks Meter: 199
Always show cmd data error
How to solve
I am try many times but same
Please any one suggestion me
Page generated in 0.14191 seconds with 7 queries
