02-11-2020, 08:33 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | huawei y530-u00 dead boot repair done Code: Setting frequence to 21 Mhz CMD Pullup Level: 2062 mV CMD Active Level: 2361 mV EMMC Device Information : EMMC CID: 90014A4834473164040300A522CE112A EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 00A522CE , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G1d_00A522CE_20200209_233722.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... The file is too large for the ROM1. The size has been corrected Operation: Writing BootConfig ... Reg: 179 Value: 0x38 Reg: 177 Value: 0x00 Reg: 162 Value: 0x00 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000200000 Filename: EMMC_ROM2_00000000_00400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 289.24 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000200000 Filename: EMMC_ROM3_00000000_00400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 289.24 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x0000E9000000 Filename: EMMC_ROM1_00000000_100000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 499.73 KB/s All done time: [13:53:54:755] Code: Setting frequence to 21 Mhz CMD Pullup Level: 2052 mV CMD Active Level: 2371 mV EMMC Device Information : EMMC CID: 90014A4834473164040300A522CE112A EMMC CSD: D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacture : SKHYNIX , EMMC NAME: H4G1d , HEX: 483447316400 , S/N: 00A522CE , rev. 0x03 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 1/2014 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G1d_00A522CE_20200211_133301.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000004400 - 000000084400], size: 000000080000 (512. KB) Partition: sdi, [000000084400 - 00000008C400], size: 000000008000 (32.0 KB) Partition: DDR, [000000400000 - 000000408000], size: 000000008000 (32.0 KB) Partition: rpm, [000000800000 - 00000087D000], size: 00000007D000 (500. KB) Partition: tz, [00000087D000 - 0000008FA000], size: 00000007D000 (500. KB) Partition: aboot, [0000008FA000 - 000000E70000], size: 000000576000 (5.46 MB) Partition: pad, [000000E70000 - 000000F70000], size: 000000100000 (1.00 MB) Partition: oeminfo, [000000F70000 - 000004F70000], size: 000004000000 (64.0 MB) Partition: modemst1, [000004F70000 - 000005370000], size: 000000400000 (4.00 MB) Partition: modemst2, [000005370000 - 000005770000], size: 000000400000 (4.00 MB) Partition: modem, [000005800000 - 00000B800000], size: 000006000000 (96.0 MB) Partition: fsg, [00000B800000 - 00000BC00000], size: 000000400000 (4.00 MB) Partition: fsc, [00000BC00000 - 00000BC00400], size: 000000000400 (1.00 KB) Partition: ssd, [00000BC00400 - 00000BC02400], size: 000000002000 (8.00 KB) Partition: log, [00000BC02400 - 00000DC02400], size: 000002000000 (32.0 MB) Partition: bkbootup, [00000E000000 - 000012000000], size: 000004000000 (64.0 MB) Partition: persist, [000012000000 - 000012800000], size: 000000800000 (8.00 MB) Partition: boot, [000012800000 - 000013400000], size: 000000C00000 (12.0 MB) Partition: recovery, [000013400000 - 000014400000], size: 000001000000 (16.0 MB) Partition: cust, [000014400000 - 000024400000], size: 000010000000 (256. MB) Partition: cache, [000024400000 - 000030400000], size: 00000C000000 (192. MB) Partition: misc, [000030400000 - 000030800000], size: 000000400000 (4.00 MB) Partition: system, [000030800000 - 000070800000], size: 000040000000 (1.00 GB) Partition: userdata, [000070800000 - 0000B0800000], size: 000040000000 (1.00 GB) Partition: grow, [0000B0800000 - 0000EBFFBE00], size: 00003B7FBE00 (951. MB) GPT header successfully parsed Get firmware version Brand = Huawei Manufacturer = HUAWEI Device = hwY530-U00 Model = HUAWEI Y530-U00 Phone platform = msm8610 CPU Abi = armeabi-v7a Android release = 4.3 Firmware version = Y530-U00V100R001C150B179 Firmware date = Tue Mar 11 16:48:08 IST 2014 |
