Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 07-12-2019, 11:32   #1 (permalink)
kothamamun's Avatar
Member: 2556542
Thanks Meter: 780
warning health report is bad whats problem
Setting frequence to 21 MHz
CMD Pullup Level: 2000 mV
CMD Active Level: 2299 mV
EMMC Device Information :
EMMC CID: 150100514E3136424200CDE4EEEEB3A4
EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C
EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: CDE4EEEE , rev. 0x00
EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 11/2016
   EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000)
   EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000)
   EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Maybe not clean
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1)
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: QN16BB_CDE4EEEE_20190712_163028.extcsd
EMMC Init completed.
Warning: Health report is very BAD
Device Life Time Estimation (MLC) [269]: 0x0B   Exceeded its maximum estimated device life time
Device Life Time Estimation (SLC) [268]: 0x0B   Exceeded its maximum estimated device life time
Pre EOL information [267]: 0x01   Normal
Scanning soft partitions
GPT header is found and is valid
Partition: BOTA0, [000000400000 - 000000800000], size: 000000400000 (4.00 MB)
Partition: NVRAM, [000000800000 - 000001000000], size: 000000800000 (8.00 MB)
Partition: LK, [000001000000 - 000001200000], size: 000000200000 (2.00 MB)
Partition: BOTA1, [000001200000 - 000001400000], size: 000000200000 (2.00 MB)
Partition: SECRO, [000001400000 - 000001B00000], size: 000000700000 (7.00 MB)
Partition: SECCFG, [000001B00000 - 000001B80000], size: 000000080000 (512. KB)
Partition: EFUSE, [000001B80000 - 000001C00000], size: 000000080000 (512. KB)
Partition: TEE1, [000001C00000 - 000002200000], size: 000000600000 (6.00 MB)
Partition: BOTA2, [000002200000 - 000002800000], size: 000000600000 (6.00 MB)
Partition: EFS, [000002800000 - 000003000000], size: 000000800000 (8.00 MB)
Partition: NVDATA, [000003000000 - 000005000000], size: 000002000000 (32.0 MB)
Partition: PARAM, [000005000000 - 000005800000], size: 000000800000 (8.00 MB)
Partition: RECOVERY, [000005800000 - 000006800000], size: 000001000000 (16.0 MB)
Partition: BOOT, [000006800000 - 000007800000], size: 000001000000 (16.0 MB)
Partition: MD1IMG, [000007800000 - 000009800000], size: 000002000000 (32.0 MB)
Partition: MD1DSP, [000009800000 - 000009C00000], size: 000000400000 (4.00 MB)
Partition: KEYSTORE, [000009C00000 - 00000A400000], size: 000000800000 (8.00 MB)
Partition: OMEKEYSTORE, [00000A400000 - 00000A780000], size: 000000380000 (3.50 MB)
Partition: PROINFO, [00000A780000 - 00000AA00000], size: 000000280000 (2.50 MB)
Partition: PARA, [00000AA00000 - 00000AA80000], size: 000000080000 (512. KB)
Partition: PERSISTENT, [00000AA80000 - 00000AB00000], size: 000000080000 (512. KB)
Partition: STEADY, [00000AB00000 - 00000AC00000], size: 000000100000 (1.00 MB)
Partition: PROTECT1, [00000AC00000 - 00000B400000], size: 000000800000 (8.00 MB)
Partition: PROTECT2, [00000B400000 - 00000BC00000], size: 000000800000 (8.00 MB)
Partition: RESERVE2, [00000BC00000 - 00000C000000], size: 000000400000 (4.00 MB)
Partition: SYSTEM, [00000C000000 - 0000CC800000], size: 0000C0800000 (3.01 GB)
Partition: CACHE, [0000CC800000 - 0000E5800000], size: 000019000000 (400. MB)
Partition: HIDDEN, [0000E5800000 - 0000E9400000], size: 000003C00000 (60.0 MB)
Partition: USERDATA, [0000E9400000 - 0001D1FFBE00], size: 0000E8BFBE00 (3.64 GB)
GPT header successfully parsed
AP_G532GDXU1ASA5_CL15222057_QB21594701_REV00_user_low_ship_MULTI_CERT.tar.md5
The list of files in the firmware:
boot.img
recovery.img
system.img
secro.img
userdata.img
CMD Pullup Level: 2010 mV
Backup saved: QN16BB_CDE4EEEE_20190712_163111.extcsd
Old 07-12-2019, 13:30   #2 (permalink)
Member: 13148
Thanks Meter: 1,103
You need replace flash IC
Flash IC cell is degradation when writing
The Following User Says Thank You to layder For This Useful Post:
Page generated in 0.16415 seconds with 7 queries
