01-02-2019, 13:47 | #1 (permalink) |
Junior Member Join Date: Jun 2016
Member: 2584252 Status: Offline Thanks Meter: 0 | what is nand iphone? iConfig mode 2, type x64 Read CE0, serial block number: 0 Can't parse Serial block: iConfig block not found Read CE0, serial block number: 1 serial number: F2LLWABGFNJL model: ME343 sub model: A1533 area: LL/A color: not found board: F3Y3493015CF7GRA WiFi mac: 54724FC29483 bluetooth mac: 54724FC29484 GICl : 010000007B1400000000000000000000 AICl : 020000008C070000F401000000000000 BLCl : 000100007C15204E0902000000000000 Read CE1, serial block number: 0 Can't parse Serial block: iConfig block not found Read CE1, serial block number: 1 serial number: F2LLWABGFNJL model: ME343 sub model: A1533 area: LL/A color: not found board: F3Y3493015CF7GRA WiFi mac: 54724FC29483 bluetooth mac: 54724FC29484 GICl : 010000007B1400000000000000000000 AICl : 020000008C070000F401000000000000 BLCl : 000100007C15204E0902000000000000 Done. when closing SN null wifi null solution with easy jtag nand bad please give me solution with nand easy or fix its Last edited by daigiahnam; 01-02-2019 at 13:53. |
01-02-2019, 16:02 | #2 (permalink) | |
Freak Poster Join Date: Jul 2008
Member: 818380 Status: Offline Thanks Meter: 56 | Quote:
01-04-2019, 04:29 | #5 (permalink) |
Member: 2584252 Status: Offline Thanks Meter: 0 | Z3X EasyJtag Software ver. 3.3.0.0 Identify NAND Chip. It's PPN NAND Id: 0x50504E010505 Extended id: 0x980001361902 apple bus capability: x32 x64 Name: THGBX2G7B2JLA01 Vendor: Toshiba FW version: 040100P Full page size: 0x4040 Page data size: 0x4040 Page spare size: 0x0 Layout: number of CS: 2 number of LUNs per CS: 1 number of Planes per LUN: 2 number of Blocks per Plane: 1056 number of Pages per Block: 256 number of Pages per SLC Block: 128 Flash size: 0x424200000 / 16,578,000,000B / 16GB Prepare to iConfig works. Bad block skipping is disable Auto addressing is disable Using physical addressing Blocks ordered by LUN Skip empty blocks is disable PPN NAND does not use Spare as common understanding. Spare and ECC settings are abolished iConfig mode 0, type x32 Read CE0, serial block number: 0 Can't parse Serial block: iConfig block not found Read CE1, serial block number: 0 Can't parse Serial block: iConfig block not found iConfig mode 1, type x32 Read CE0, serial block number: 0 Can't parse Serial block: iConfig block not found Read CE1, serial block number: 0 Can't parse Serial block: iConfig block not found iConfig mode 2, type x64 Read CE0, serial block number: 0 Can't parse Serial block: iConfig block not found Read CE0, serial block number: 1 serial number: F2LLWABGFNJL model: ME343 sub model: A1533 area: LL/A color: not found board: F3Y3493015CF7GRA WiFi mac: 54724FC29483 bluetooth mac: 54724FC29484 GICl : 010000007B1400000000000000000000 AICl : 020000008C070000F401000000000000 BLCl : 000100007C15204E0902000000000000 Read CE1, serial block number: 0 Can't parse Serial block: iConfig block not found Read CE1, serial block number: 1 serial number: F2LLWABGFNJL model: ME343 sub model: A1533 area: LL/A color: not found board: F3Y3493015CF7GRA WiFi mac: 54724FC29483 bluetooth mac: 54724FC29484 GICl : 010000007B1400000000000000000000 AICl : 020000008C070000F401000000000000 BLCl : 000100007C15204E0902000000000000 Done. easy ver 3.3.3.0 |
01-04-2019, 08:29 | #6 (permalink) |
Member: 818380 Status: Offline Thanks Meter: 56 | Follow these steps: 1. erase nand 2. fill all info 3. select x64 mode 1 4. select device in this is iphone 5s 5. click write iconfig for select device (after write dont change any information) 6. put back nand chip to mainboard. |
01-04-2019, 17:37 | #7 (permalink) | |
Member: 2584252 Status: Offline Thanks Meter: 0 | Quote:
do the same and wrong know or serial number. 18 plays with 1 5s hard drive | |
03-07-2019, 21:37 | #8 (permalink) |
Freak Poster Join Date: Nov 2006
Member: 389266 Status: Offline Thanks Meter: 17 | Problem nand iphone 5s, help me PROBLEM NAND IPHONE 5S, HELP ME Hello friends I got an iphone 5s in recovery mode, I try to flash with itunes with error 4013 result, rebuilt tracks where they break the screws and the same problem comes out I desoldo the nand, clean, reballing and connect to the easy jtag plus, here the log: ********************************************* Z3X EasyJtag Software ver. 3.4.0.2 Identify NAND Chip. It's PPN NAND Id: 0x50504E010507 Extended id: 0xAD8260242102 apple bus capability: x32 x64 Name: H2JTDG8UD1BMS ( eye mine is H2JTDG8UD1BMR) Vendor: Hynix FW version: 050260P_HYX_BD16 Full page size: 0x4040 Page data size: 0x4040 Page spare size: 0x0 Layout: *number of CS: 2 *number of LUNs per CS: 1 *number of Plans per LUN: 2 *number of Blocks per Plane: 1064 *number of Pages per Block: 256 *number of Pages per SLC Block: 128 Flash size: 0x42C280000 / 16,706,512,000B / 16GB Donate ********************************************** ******************** Z3X EasyJtag Software ver. 3.4.0.2 Identify NAND Chip. It's PPN NAND Id: 0x50504E010507 Extended id: 0xAD8260242102 apple bus capability: x32 x64 Name: H2JTDG8UD1BMS Vendor: Hynix FW version: 050260P_HYX_BD16 Full page size: 0x4040 Page data size: 0x4040 Page spare size: 0x0 Layout: *number of CS: 2 *number of LUNs per CS: 1 *number of Plans per LUN: 2 *number of Blocks per Plane: 1064 *number of Pages per Block: 256 *number of Pages per SLC Block: 128 Flash size: 0x42C280000 / 16,706,512,000B / 16GB Prepare to iConfig works. Bad block skipping is disable Auto addressing is disable Using physical addressing Blocks ordered by LUN Skip empty blocks is disable PPN NAND does not use Spare as common understanding. Spare and ECC settings are abolished iConfig mode 0, type x32 Read CE0, serial block number: 0 Error reading, CE0 sector address 0x841F000000 block address 0x841F000000, block number 2110. Error Code: -202 Reason: Status fail Read CE1, serial block number: 0 Error reading, CE1 sector address 0x8C20000000 block address 0x8C20000000, block number 2113. Error Code: -202 Reason: Status fail iConfig mode 1, type x64 Read CE0, serial block number: 0 Can not parse Serial block: iConfig block not found Read CE0, serial block number: 1 **serial number: xxxPLCVHFFG8 **model: ME432 **sub model: A1457 **area: CI / A **color: not found **board: FJ651130CC8FGFDE **WiFi mac: xxx72CAA8B00 **bluetooth mac: xxx72CAA8B01 **GICl: 01000000881300000000000000000000 **AICl: 02000000C0070000F401000000000000 **BLCl: 000100006D15204E3002000000000000 Read CE1, serial block number: 0 Can not parse Serial block: iConfig block not found Read CE1, serial block number: 1 **serial number: xxxPLCVHFFG8 **model: ME432 **sub model: A1457 **area: CI / A **color: not found **board: 0000000000031206 **WiFi mac: xxx72CAA8B00 **bluetooth mac: xxx72CAA8B01 **GICl: 01000000881300000000000000000000 **AICl: 02000000C0070000F401000000000000 **BLCl: 000100006D15204E3002000000000000 Donate ******************************************** despues de 1-Erase NAND [General Tab] 2-Select Device Like 5S [iConfig Tab] 3-Write iConfig For Selective Device 4-Write Original Numbers [SN MAC ETC] 5-Click WRITE ICONFIG FOR SELECTED DEVICE Then I Resoldered NAND But When I Try To Restore VIA iTunes restores without errors excellent but it does not let me activate the iphone, because it has another serial than the original one, when giving in the logo (i) it can be seen in the screen of the iphone already restored I desoldo again the nand and I connect to the box and here the logo: ********************************************* iConfig mode 1, type x64 Read CE0, serial block number: 0 Can not parse Serial block: iConfig block not found Read CE0, serial block number: 1 **serial number: DNQL96T4F888 **model: ME305 **sub model: A1533 **area: ZP / A **color: not found **board: F3X33520942FGCC6 **WiFi mac: 6476BA151965 **bluetooth mac: 6476BA151966 **GICl: 010000007B140000000000000000000000 **AICl: 020000008C070000F401000000000000 **BLCl: 000100007C15204E0902000000000000 Read CE1, serial block number: 0 Can not parse Serial block: iConfig block not found Read CE1, serial block number: 1 **serial number: xxxPLCVHFFG8 **model: ME432 **sub model: A1457 **area: CI / A **color: not found **board: 0000000000031206 **WiFi mac: xxx72CAA8B00 **bluetooth mac: xxx72CAA8B01 **GICl: 010000007B140000000000000000000000 **AICl: 020000008C070000F401000000000000 **BLCl: 000100007C15204E0902000000000000 Donate ****************************************** the information is corrupted or altered compare the 2 logs questions 1-why is this new sn: DNQL96T4F888 on the display of the iphone, wrong original data does not let me activate iphone 2- my nand is exactly H2JTDG8UD1BMR is not supported? * this same process I have done in two iphone 6 without any failure total success thanks for advance luck |
The Following User Says Thank You to engendro For This Useful Post: |
03-09-2019, 11:46 | #9 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | try to write config via this test version https://smartjtagbox.com/owncloud/in...x7r5a324cJ5xLJ sete "Erase User data" when Write config, also select correct mode (x64) Last edited by layder; 03-09-2019 at 11:52. |
04-16-2019, 12:08 | #11 (permalink) |
No Life Poster Join Date: Nov 2014
Member: 2289628 Status: Offline Thanks Meter: 226 | NAND (iConfig) I had some questions about "NAND" tab. Could anyone guide me because of I am newbie ..... How to change SN, Model & Sub Model. If I want to upgrade NAND from 16GB to 64GB then how to do it ? |
04-16-2019, 13:25 | #12 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | What is you device? Instuction for iPhone NAND change 1) Put a old Flash, Identify 2) Read and save SN (Read iConfig and and Read and Save iConfig area) 3) Put a new Flash, Identify 4) Upload saved configs (Choose "Master" file) 5) Set Bit depth (in fact, serials will be only in one bit width, see select box from above) 6) Set "Erase data" checkbox (equivalent to wiping the entire flash manually) 7) Click Write iConfig for selected device 8) Solder Flash IC to device, connect to iTunes, Restore |
The Following User Says Thank You to layder For This Useful Post: |
04-16-2019, 13:41 | #13 (permalink) | |
Member: 2289628 Status: Offline Thanks Meter: 226 | Quote:
Your mean is that 1st Save iConfig > put 64GB nand > delete (format) entire nand > write again saved iConfig > Restore via iTune. By the way can I write IPSW firmware from here or is it necessory to use iTune ? But how to change SN, Model and Sub Model ? | |
04-16-2019, 14:19 | #14 (permalink) | |
S/N you need put it correct with imei, model and submodel some time i change it with other model not problem. | |
04-16-2019, 14:25 | #15 (permalink) | |
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
2) You can change data at label box to another | |
