Old 09-07-2019, 07:08   #1 (permalink)
Member: 2887331
Thanks Meter: 2
Netflix does not work after taking the dump.
Hello, it's about eMMC memory on tv.
I took a memory dump from a good tv, after soldering the tv works fine, only netflix problem.
Apparently, netflix does not work on rooted devices.
Is there any number in the original memory that should be sent to the other one? Soldering memory from a good motherboard gives the same symptom,
maybe the memory and the processor on the motherboard are paired with each other?
The only difference is the S/N number ???
and H/W reset function [RST_N_FUNCTION]: ???
and Partitioning Setting [PARTITION_SETTING_COMPLETED]: ???
Does it matter?
The first photo is the original memory, second photo after recording the dump.
https://zapodaj.net/cb8c661690761.jpg.html
https://zapodaj.net/938d46bb8ed67.jpg.html
The Following User Says Thank You to valdix23 For This Useful Post:
Page generated in 0.11207 seconds with 8 queries
