07-22-2018, 08:14 | #1 (permalink) |
Freak Poster Join Date: Mar 2009 Location: KRJ
Member: 993718 Status: Offline Thanks Meter: 91 | where am i wrong anyone please help me pin's connect successfully but when detect emmc it's showing this error "Can't init device, Reason: CMD Timeout Error " i connect two pull up resistor 100oms with 1.8volt to cmd and data0 i try with easy jtag emmc classic and plus software both give same error i am using samsung j210f working phone and j00g dead phone micromax d321 emmc working in EMMC socket BGA162 please tell me where am i wrong this is micromax D321 with EMMC socket logs Compression if OFF Z3X EasyJtag Software ver. 3.0.0.0 Loading eMMC GEN2 Firmware... IO: 2800 mV Initial pull results: clock: 1835mV pin connected ok command: 1842mV pin connected ok data0: 1842mV pin connected ok data1: 1839mV pin connected ok data2: 1842mV pin connected ok data3: 1835mV pin connected ok data4: 1840mV pin connected ok data5: 1843mV pin connected ok data6: 1818mV pin connected ok data7: 1840mV pin connected ok Box S/N: 8C30F9F3F3B1121F, ,FW Ver.: 02.29 Box IO Level:2800 mV CLK Rate:21000 kHz Bus Width:8bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A48344732611101956B214F6239 eMMC CSD : D02701320F5903FFFFFFFFEF8A4040D3 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 06/2015 Rev.0x1 eMMC NAME: H4G2a , S/N: 2506826063 eMMC NAME (HEX): 483447326120 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x48. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G2a _2506826063_20180722_1211.extcsd Done. please help me Thank you Here Is Screen Shots |
07-23-2018, 18:04 | #3 (permalink) |
No Life Poster Join Date: Feb 2009 Location: inside apples a15
Member: 975554 Status: Offline Sonork: KG state:prenormal Thanks Meter: 253 | you should only see all red dots in scan not green..try not to connect the 1.8v to the board and scan again..if you see red dots then theres a problem of the cp board..sometimes emmc is shorted |
07-23-2018, 18:24 | #4 (permalink) | |
Freak Poster Join Date: Nov 2010 Location: Vice City
Member: 1436243 Status: Offline Thanks Meter: 99 | Quote:
- try to set 1,8, 2,8 or 3,3 volt - if necessary try lower frequence to 1Mhz at first, then you can set to higher frequence if it works (readed by box) - bus Width always to 1 bit (if you use 1 bit ISP adapter like yours picture SET PINOUT MODE/INTERFACE : E-SOCKET If you use socket "remove emmc and place on socket" hope it help | |
The Following User Says Thank You to mifluvcute For This Useful Post: |
07-24-2018, 14:45 | #5 (permalink) | |
Member: 993718 Status: Offline Thanks Meter: 91 | Quote:
Thank you bro now it's working Here is the log detail 7/24/2018 9:56:05 AM> Looking for EasyJTAG box... 7/24/2018 9:56:05 AM> EasyJTAG API ver. 2100 7/24/2018 9:56:05 AM> Setting IO Levels to 1.8V 7/24/2018 9:56:05 AM> Setting frequence to 12 Mhz 7/24/2018 9:56:05 AM> EasyJTAG Box Serial = 8C30F9F3F3B1121F 7/24/2018 9:56:05 AM> EasyJTAG Box Firmware = 2.29 7/24/2018 9:56:05 AM> Setting interface to EasyJtag2/ISP 7/24/2018 9:56:05 AM> Setting bus width to 1 Bit 7/24/2018 9:56:05 AM> Setting frequence to 12 Mhz 7/24/2018 9:56:05 AM> CMD Pullup Level: 1800 mV 7/24/2018 9:56:05 AM> CMD Active Level: 1861 mV 7/24/2018 9:56:06 AM> eMMC Init returned = 0 7/24/2018 9:56:06 AM> EMMC Device Information : 7/24/2018 9:56:06 AM> EMMC CID: 150100514E31364242005F85D00C739F 7/24/2018 9:56:06 AM> EMMC CSD: D02701320F5903FFF6DBFFEF8E40400D 7/24/2018 9:56:06 AM> EMMC Manufacture : SAMSUNG , EMMC NAME: QN16BB , HEX: 514E31364242 , S/N: 5F85D00C , rev. 0x00 7/24/2018 9:56:06 AM> EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 7/2016 7/24/2018 9:56:06 AM> EMMC ROM 1 (Main User Data) Capacity: 7456 MB (0001D2000000) 7/24/2018 9:56:06 AM> EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) 7/24/2018 9:56:06 AM> EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) 7/24/2018 9:56:06 AM> EMMC Permanent Write Protection: No 7/24/2018 9:56:06 AM> EMMC Temporary Write Protection: No 7/24/2018 9:56:06 AM> Extended CSD Information : 7/24/2018 9:56:06 AM> Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01) 7/24/2018 9:56:06 AM> Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) 7/24/2018 9:56:06 AM> Boot Bus Config: 0x00 , width 1bit 7/24/2018 9:56:06 AM> H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled 7/24/2018 9:56:06 AM> Supported partition features [PARTITIONING_SUPPORT]: 0x07 7/24/2018 9:56:06 AM> Device supports partitioning features 7/24/2018 9:56:06 AM> Device can have enhanced technological features in partitions and user data area 7/24/2018 9:56:06 AM> Device can have extended partitions attribute 7/24/2018 9:56:06 AM> Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 7/24/2018 9:56:06 AM> Backup saved: QN16BB_5F85D00C_20180724_095606.extcsd 7/24/2018 9:56:06 AM> EMMC Init completed. 7/24/2018 9:56:06 AM> 7/24/2018 9:56:06 AM> Get firmware version 7/24/2018 9:56:06 AM> 7/24/2018 9:56:07 AM> Brand = samsung 7/24/2018 9:56:07 AM> Manufacturer = samsung 7/24/2018 9:56:07 AM> Model = SM-J210F 7/24/2018 9:56:07 AM> Phone platform = sc8830 7/24/2018 9:56:07 AM> CPU Abi = armeabi-v7a 7/24/2018 9:56:07 AM> Android release = 6.0.1 7/24/2018 9:56:07 AM> Firmware version = MMB29Q.J210FXXU0AQG4 7/24/2018 9:56:07 AM> Firmware date = Fri Jul 28 15:55:44 KST 2017 | |
