03-13-2018, 12:39
#1 (permalink)
Member: 2339474
Sonork: 100.1662352 Thanks Meter: 332 | where is problem and how to fix it? 1.8 to dat0 resistor is 103
1.8 to cmd is 160
tested in plus hipower on same result Quote:
EasyJtag Suite Classic ver.: 2.9.0.1 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 7 (build 7601, Service Pack 1), 64-bit edition. Admin rights OK
Android Explorer ver:1.0.0.23
Autorun Agent ver:1.0.0.0
Crash Reporting ver:1.4.0.3
eMMC Odin ver:1.0.11.2
QUALCOMM Direct ver:1.0.6241.462
Android ADB API ver:2.0.0.0
FTDI API ver:3.2.4.0
LibUSB API ver:1.2.6.0
Visual C++ Runtime ver:10.0.30319.1
Setting box Pinout ...
Box Drivers version: 1.2.0.0
Z3X Card Serial : AA55-9616 , ver: 22
Z3X Card Activation [LG] : ACTIVATED
Z3X Card Activation [SAMS] : ACTIVATED
Z3X Card Activation [JTAGPLUS] : ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Selected pinout: GEN2 High Speed Pinout
Change EasyJTAG Pinout OK
Compression if OFF
Z3X EasyJtag Software ver. 2.9.0.1
Loading eMMC GEN2 Firmware... IO: 2800 mV
Initial pull results:
clock: 1450mV pin connected ok
command: 1450mV pin connected ok
data0: 1450mV pin connected ok
data1: 1451mV pin connected ok
data2: 1451mV pin connected ok
data3: 1448mV pin connected ok
data4: 1450mV pin connected ok
data5: 1450mV pin connected ok
data6: 1877mV pin connected ok
data7: 1861mV pin connected ok
Box S/N: 7604E355A5D3B120, ,FW Ver.: 02.21
Box IO Level:2800 mV
CLK Rate:42000 kHz
Bus Width:8bit,SDR
HiPower mode is off!
Can't init device, Reason: CMD Timeout Error
Done.
Selected pinout: GEN2 ISP Pinout
Compression if OFF
CMD Pullup Level:1879 mV
CMD Active Level:2570 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
---------- eMMC Device Information ----------
EMMC CID : 15010056335730304D00B7C0B8F58059
EMMC CSD : D02701320F5903FFF6DBFFEF8E40400D
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 08/2013 Rev.0x0
EMMC NAME: V3W00M , S/N: 3082860789
EMMC NAME (HEX): 56335730304D00
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 512 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.7 (MMC 5.0)
Boot configuration [PARTITION_CONFIG: 0x48] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x48.
H/W reset function [RST_N_FUNCTION]: 0x00
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: V3W00M_3082860789_20180313_1353.extcsd
Done.
Compression if OFF
Loading eMMC GEN2 Firmware... IO: 3300 mV
CMD Pullup Level:1887 mV
CMD Active Level:2954 mV
Box IO Level:3300 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Done.
Skip loading eMMC Addon Firmware
CMD Pullup Level:1885 mV
CMD Active Level:2952 mV
CLK Rate:24000 kHz
Bus Width:1bit,SDR
Reading 0x000400000000 (16.0GB) from 0x000000000000 ...ROM1 ( USER ROM)
Read Length has been corrected to 0x0003AB400000 (14.675GB)...
Output file :C:\Program Files\Z3X\EASYJTAG\EMMC_ROM1_V3W00M_3082860789_000 00000_3AB400000.bin
Error reading address 0x23FA0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x23FA0000 (Attempt #1)
Retry Success!
Error reading address 0x35160000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x35160000 (Attempt #1)
Retry Success!
Error reading address 0x55A00000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x55A00000 (Attempt #1)
Retry Success!
Error reading address 0x5B360000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x5B360000 (Attempt #1)
Retry Success!
Error reading address 0x717A0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x717A0000 (Attempt #1)
Retry Success!
Error reading address 0x80FC0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x80FC0000 (Attempt #1)
Retry Success!
Error reading address 0x8B420000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x8B420000 (Attempt #1)
Retry Success!
Error reading address 0xA6B80000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0xA6B80000 (Attempt #1)
Retry Success!
Error reading address 0xAD520000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0xAD520000 (Attempt #1)
Retry Success!
Error reading address 0xBF0E0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0xBF0E0000 (Attempt #1)
Retry Success!
Error reading address 0xD7C80000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0xD7C80000 (Attempt #1)
Retry Success!
Error reading address 0xDA020000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0xDA020000 (Attempt #1)
Retry Success!
Error reading address 0xE43E0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0xE43E0000 (Attempt #1)
Retry Success!
Error reading address 0xF3FC0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0xF3FC0000 (Attempt #1)
Retry Success!
Error reading address 0x102020000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x102020000 (Attempt #1)
Retry Success!
Error reading address 0x103420000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x103420000 (Attempt #1)
Retry Success!
Error reading address 0x10D1A0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x10D1A0000 (Attempt #1)
Retry Success!
Error reading address 0x111480000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x111480000 (Attempt #1)
Retry Success!
Error reading address 0x11CE20000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x11CE20000 (Attempt #1)
Retry Success!
Error reading address 0x122960000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x122960000 (Attempt #1)
Retry Success!
Error reading address 0x135560000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x135560000 (Attempt #1)
Retry Success!
Error reading address 0x136140000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x136140000 (Attempt #1)
Retry Success!
Error reading address 0x140BE0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x140BE0000 (Attempt #1)
Retry Success!
Error reading address 0x14DAC0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x14DAC0000 (Attempt #1)
Retry Success!
Error reading address 0x158240000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x158240000 (Attempt #1)
Retry Success!
Error reading address 0x160120000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x160120000 (Attempt #1)
Retry Success!
Error reading address 0x1608A0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1608A0000 (Attempt #1)
Retry Success!
Error reading address 0x168A00000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x168A00000 (Attempt #1)
Retry Success!
Error reading address 0x16FDA0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x16FDA0000 (Attempt #1)
Retry Success!
Error reading address 0x176100000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x176100000 (Attempt #1)
Retry Success!
Error reading address 0x1773C0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1773C0000 (Attempt #1)
Retry Success!
Error reading address 0x17CA00000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x17CA00000 (Attempt #1)
Retry Success!
Error reading address 0x1933E0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1933E0000 (Attempt #1)
Retry Success!
Error reading address 0x1A0FE0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1A0FE0000 (Attempt #1)
Retry Success!
Error reading address 0x1AF0E0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1AF0E0000 (Attempt #1)
Retry Success!
Error reading address 0x1C1F60000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1C1F60000 (Attempt #1)
Retry Success!
Error reading address 0x1D5B00000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1D5B00000 (Attempt #1)
Retry Success!
Error reading address 0x1DF060000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1DF060000 (Attempt #1)
Retry Success!
Error reading address 0x1E1FE0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1E1FE0000 (Attempt #1)
Retry Success!
Error reading address 0x1E5820000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1E5820000 (Attempt #1)
Retry Success!
Error reading address 0x1E9420000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1E9420000 (Attempt #1)
Retry Success!
Error reading address 0x1EBEA0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1EBEA0000 (Attempt #1)
Retry Success!
Error reading address 0x1EFAA0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x1EFAA0000 (Attempt #1)
Retry Success!
Error reading address 0x216420000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x216420000 (Attempt #1)
Retry Success!
Error reading address 0x223080000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x223080000 (Attempt #1)
Retry Success!
Error reading address 0x22DF80000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x22DF80000 (Attempt #1)
Retry Success!
Error reading address 0x22EAC0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x22EAC0000 (Attempt #1)
Retry Success!
Error reading address 0x23ED80000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x23ED80000 (Attempt #1)
Retry Success!
Error reading address 0x246120000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x246120000 (Attempt #1)
Retry Success!
Error reading address 0x253140000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x253140000 (Attempt #1)
Retry Success!
Error reading address 0x2562A0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x2562A0000 (Attempt #1)
Retry Success!
Error reading address 0x2680E0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x2680E0000 (Attempt #1)
Retry Success!
Error reading address 0x276D20000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x276D20000 (Attempt #1)
Retry Success!
Error reading address 0x27E2A0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x27E2A0000 (Attempt #1)
Retry Success!
Error reading address 0x27EA20000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x27EA20000 (Attempt #1)
Retry Success!
Error reading address 0x284100000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x284100000 (Attempt #1)
Retry Success!
Error reading address 0x28DCA0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x28DCA0000 (Attempt #1)
Retry Success!
Error reading address 0x2936A0000 Error Code:-2 Reason :CMD CRC Error
Retry reading address 0x2936A0000 (Attempt #1)
Retry Success!
