03-28-2016, 04:11 | #1 (permalink) |
No Life Poster Join Date: Dec 2012 Location: india mumbai
Member: 1847344 Status: Offline Thanks Meter: 300 | why dead 7 or 8 days n7100 n7000 succes fully repair after success fully repared 1 repare emmc firmware 2 write extra csd 3 factory reset or movinand reset 4 write rom1 rom2 5 flash odian but dead 10 dead again again |
03-31-2016, 00:55 | #3 (permalink) |
Freak Poster Join Date: Jul 2012 Location: Venezuela
Member: 1788767 Status: Offline Sonork: walidjamil Thanks Meter: 28 | S3 I9300 and s3 I9305,huawei y300 have same problem all of them are dead from 5 to 10 days after update firmware and repaired emmc.its happened in all of boxes not only easy jtag. |
03-31-2016, 14:41 | #4 (permalink) |
Junior Member Join Date: Sep 2006 Location: Greece Age: 41
Member: 349413 Status: Offline Thanks Meter: 8 | This EMMC has 4 banks and each bank has 51 spare sectors that is using to replace the bad sectors that die during use. If on one of the banks all of the 51 sectors are used then the next bad sector can not be swaped because there is no space left. In this case the device can not power on or it freezes on logo during boot up and can not be flashed by ODIN. By reinitialising the EMMC the list with the sectors that are marked as bad is erased and these sectors will be used again. At first the device works ok but these sectors are still faulty and when the device starts writing and erasing them they will be marked as bad again. When you reach 51 bad sectors the device will die again. In this case you have to replace the EMMC. Sent from my Elite 2 using Tapatalk |
04-01-2016, 14:25 | #5 (permalink) |
Member: 1847344 Status: Offline Thanks Meter: 300 | here smart t report n7000 samsung n7100 bord Running:SAMSUNG: Read S.M.A.R.T Report... Z3X EasyJtag Software ver. 2.0.7.6 Skip loading eMMC Addon Firmware CMD Pullup Level:897 mV CMD Active Level:2660 mV Reading S.M.A.R.T S.M.A.R.T Ver. 0 , Card Error mode : Normal Super Block size : 0x00800000 (8388608 bytes) Super Page size : 0x00004000 (16384 bytes) Optimal Write size : 0x00010000 (65536 bytes) Read Reclaim count : 0 Optimal TRIM size : 0x00002000 (8192 bytes) Total Number of banks : 4 Initial bad blocks per bank : 30,40,35,39 Runtime bad blocks per bank : 0,1,0,0 Reserved blocks left per bank : 21,10,16,12 All Erase counts (min,avg,max): 0,0,3 SLC Erase counts (min,avg,max): 0,0,2 MLC Erase counts (min,avg,max): 0,0,3 S.M.A.R.T Report Done. Last edited by shamsulhaq; 04-01-2016 at 14:33. |
04-01-2016, 14:28 | #6 (permalink) |
Member: 349413 Status: Offline Thanks Meter: 8 | This report is taken after the repair or when the device came back dead. I guess it's after the repair. Στάλθηκε από το LG-D800 μου χρησιμοποιώντας Tapatalk |
