Old 02-13-2016, 00:50   #46 (permalink)
Member: 574717
Sonork: 100.1601348
Thanks Meter: 10
any one try write dump for j700h/ds and worked ?????
Old 02-13-2016, 14:09   #47 (permalink)
Member: 1778926
Thanks Meter: 60
i try rom 2 and rom 3 from z3x support but still dead only 0.06 amper with power supply pls supporter help us with this rubbish phone
Old 02-13-2016, 14:53   #48 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
PLEASE CHECK AND POST RESULT FROM THIS POST
THANKS
http://forum.gsmhosting.com/vbb/f609...-done-2051470/
Old 02-13-2016, 18:36   #49 (permalink)
Member: 2089529
Thanks Meter: 2
Any one solved this problem plz
أرسلت من HTC Desire 816 dual sim بإستخدام تاباتلك
Old 02-15-2016, 11:19   #50 (permalink)
AllGsmStore's Avatar
Member: 99509
Sonork: Whatsapp +971508482353
Thanks Meter: 210
Z3X EasyJtag Software ver. 2.0.6.8
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: xxxxxxxxxxxxx, ,FW Ver.: 01.52
CMD Pullup Level:391 mV
CMD Active Level:2114 mV
eMMC Device Information
EMMC CID : 11010034303030373300C4B83295A26C
EMMC CSD : D07E00320F5903FFFFFFFFE78A4000D0
EMMC Manufacturer ID: 0011 , OEM ID: 0100
EMMC Date: 10/2015 Rev.0x0
EMMC NAME: 400073 , S/N: 3300405909
EMMC NAME (HEX): 34303030373300
EMMC ROM1 (Main User Data) Capacity: 15028 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
Extended CSD rev 1.7 (MMC Unknown)
Boot configuration [PARTITION_CONFIG: 0x08] Boot from:ROM2 (Boot Partition 1)
Boot bus config [177]: 0x01 , width 4bits , Partition config [179]: 0x08.
H/W reset function [RST_N_FUNCTION]: 0x00
Backup saved: 400073_3300405909_20160215_1317.extcsd
Done.
All Done, but still same
Old 02-15-2016, 12:01   #51 (permalink)
Diamond Gsm's Avatar
Member: 2064519
Thanks Meter: 83
@shahram11
your files not work because u read from older sboot version and older sboot version can't return boot
so must be use latest version of BL
solution is here : http://forum.gsmhosting.com/vbb/f609...shing-2052359/
The Following User Says Thank You to Diamond Gsm For This Useful Post:
Old 02-15-2016, 23:04   #52 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
Originally Posted by allgsmstore View Post
z3x easyjtag software ver. 2.0.6.8
loading emmc addon firmware... Io: 2800 mv
box s/n: Xxxxxxxxxxxxx, ,fw ver.: 01.52
cmd pullup level:391 mv
cmd active level:2114 mv
emmc device information
emmc cid : 11010034303030373300c4b83295a26c
emmc csd : D07e00320f5903ffffffffe78a4000d0
emmc manufacturer id: 0011 , oem id: 0100
emmc date: 10/2015 rev.0x0
emmc name: 400073 , s/n: 3300405909
emmc name (hex): 34303030373300
emmc rom1 (main user data) capacity: 15028 mb
emmc rom2 (boot partition 1) capacity: 4096 kb
emmc rom3 (boot partition 2) capacity: 4096 kb
emmc rpmb (replay protected memory block) capacity: 4096 kb
emmc permanent write protection: No
emmc temporary write protection: No
extended csd rev 1.7 (mmc unknown)
boot configuration [partition_config: 0x08] boot from:rom2 (boot partition 1)
boot bus config [177]: 0x01 , width 4bits , partition config [179]: 0x08.
H/w reset function [rst_n_function]: 0x00
backup saved: 400073_3300405909_20160215_1317.extcsd
done.
All done, but still same
this is due to non samsung emmc
easy jtag supported on samsung emmc
Old 02-23-2016, 12:34   #53 (permalink)
harish1717's Avatar
Member: 332635
Sonork: 100.1648966
Thanks Meter: 54
Originally Posted by shahram11 View Post
j700f-dd
j700f-dd
j700f\dd emmc pinout please
Old 02-23-2016, 14:40   #54 (permalink)
Member: 1933748
Sonork: 100.1671759
Thanks Meter: 26
The Following User Says Thank You to ishaqreborn For This Useful Post:
Old 02-27-2016, 08:27   #55 (permalink)
Member: 2107033
hi
can i repair J700f/dd dead boot, with ATF last version ?
and can i use this pinout for ATF ?
Old 02-27-2016, 19:30   #56 (permalink)
zameer_yus's Avatar
Member: 774915
Thanks Meter: 1,640
Processing file...C:\Users\ahmad\Desktop\j700h-ds\EMMC_ROM1_00000000_20000000.bin
Z3X EasyJtag Software ver. 2.0.7.3
USB Open Failed, Reason: PORT Read Error
Done.
Old 02-28-2016, 21:06   #57 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Done.
Hi
Change USB Port or Cable..
Don't Use USB Hub
The Following User Says Thank You to BABAK NURI For This Useful Post:
Old 02-28-2016, 21:13   #58 (permalink)
BABAK NURI's Avatar
Member: 131131
Sonork: 100.1606847
Thanks Meter: 4,475
Originally Posted by UNKNOWN GSM View Post
Hi
This pinout is find by me for security reason i have marked vcc & vccq wrong since amator users cant easily use that... pinout works on j700f j700h j700h/ds j700f/dd...
There is some information that can help to think better about this phone!!!
I desoldered an emmc from working phone and solder on a dead phone by flashing but phone doesnt power on !!! When i resolder the emmc on working phone it will work like before!!!so we must think about this!
Qualcom phones that i know since this time just using rom1 for booting!but this phone with qualcom cpu is using rom2!!!
Third : you can open rom3 with hex editor you can see that this rom also programed and this isnt a null rom!!
Creating zbin from many flash files or binary file that dumped from working phone also not helped unbrick using sdcard!!!
Also writing dump from working phone via isp not worked!
I think this is new type of security that samsung using by Qualcom trust zone to avoid repairing out of samsung service centers!
Any idea?!!
Br.
Milad.B
Hi My Dear
First,This is No New Security,It's Just Different Boot Config....
In fact if i want be honest no need write ROM2/3 Because You do already when you write ROM1.....
let me explain,please Read First 4MB from rom1 then save as R2.bin....Then Read 4MB From Rom2,Then Compare Both File...Surprise,Both is same
or try read second 4MB from Rom1 Then save as r3.bin...Now Read 4MB from Rom3 and Compare Both File....it's same too
Anyway,,,R2.bin is Sboot and r3.bin is CM and both place is in Rom1
i hope i explain clearly
B/R
The Following 8 Users Say Thank You to BABAK NURI For This Useful Post:
Old 02-28-2016, 21:24   #59 (permalink)
Member: 251872
Thanks Meter: 309
[QUOTE=BABAK NURI;11657736]Hi My Dear
mr nuri your always gsm emperator
The Following User Says Thank You to shahram11 For This Useful Post:
Old 02-28-2016, 21:56   #60 (permalink)
Jimbojump's Avatar
Member: 1748375
Sonork: 100.1617845
Thanks Meter: 17
i have a question.
i dont understand .
last firmware for j700F dd is J700FXXU1AOL2_J700FODD1AOL1_INS ?
Or same with J700F ds last firmware J700FXXU1APA7_J700FOJV1APA5_BTC ???
this mean I repair J700F dd with Last firmware dd Indian firmware Or same Ds Normal J700F,???
Thanks.
Page generated in 0.25675 seconds with 9 queries
