Old 09-24-2015, 07:04   #16 (permalink)
jmr
Member: 614683
Sonork: 100.1605379
Thanks Meter: 370
all ok but I have no problem with these models after repair to the days back again with the same problem
Old 10-27-2015, 16:19   #17 (permalink)
Member: 2117988
Sonork: 100.1667932
Thanks Meter: 44
Thumbs up thanks
Originally Posted by moinuddin111 View Post
world first huawei Y300-0100 emmc read only done by me.
here is emmc pinout
here is log
just remove write protection.
Z3X EasyJtag Software ver. 2.0.3.0
Loading eMMC Addon Firmware... IO: 2800 mV
Box S/N: 0B00A0127411F87F, ,FW Ver.: 01.52
CMD Pullup Level:1175 mV
CMD Active Level:1577 mV
eMMC Device Information
EMMC CID : 150100534A53303041030F775CBA11D4
EMMC CSD : D02701320F5903FFF6DBFFE78A406032
EMMC Manufacturer ID: 0015 , OEM ID: 0100
EMMC Date: 01/2014 Rev.0x3
EMMC NAME: <b>SJS00A</b> , S/N: 259480762
EMMC NAME (HEX): 534A5330304100
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 1024 kB
EMMC ROM3 (Boot Partition 2) Capacity: 1024 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 128 kB
EMMC Permanent Write Protection: <b>Yes<b>
EMMC Temporary Write Protection: No
Extended CSD rev 1.5 (MMC 4.41)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
Backup saved: SJS00A_ 259480762_20150705_2220.extcsd
Done.
Running:SAMSUNG: Remove Write Protection...
Skip loading eMMC Addon Firmware
CMD Pullup Level:2165 mV
CMD Active Level:2691 mV
Removing write protection...
Done.
CMD Pullup Level:2186 mV
EMMC CSD : D02701320F5903FFF6DBFFE78A404056
EMMC Permanent Write Protection: No
here is boot file
DOWNLOAD
i have done it too,thanks
Old 11-04-2015, 18:29   #18 (permalink)
Pablo Velasqu's Avatar
Member: 2074524
Sonork: 100.1627435
Thanks Meter: 135
Z3X EasyJtag Software ver. 2.0.5.1
Loading eMMC Addon Firmware... IO: 3300 mV
Box S/N: 07FFB005A703FA68, ,FW Ver.: 01.52
CMD Pullup Level:2629 mV
CMD Active Level:2805 mV
EMMC CID : 150100534A5330304D00F5B7441F6076
EMMC Date: 06/2013 Rev.0x0
EMMC NAME: SJS00M , S/N: 4122428447
EMMC NAME (HEX): 534A5330304D00
EMMC Permanent Write Protection: Yes
H/W reset function [RST_N_FUNCTION]: 0x00
Backup saved: SJS00M_4122428447_20151003_1256.extcsd
Done.
Old 11-04-2015, 18:29   #19 (permalink)
Member: 2074524
Sonork: 100.1627435
Thanks Meter: 135
Done.
Old 11-04-2015, 18:30   #20 (permalink)
Member: 2074524
Sonork: 100.1627435
Thanks Meter: 135
CMD Pullup Level:2970 mV
CMD Active Level:3310 mV
Backup saved: SJS00M_4122428447_20151003_1257.extcsd
Done.
Old 11-07-2015, 09:42   #21 (permalink)
Member: 601566
Sonork: 100.1637134
Thanks Meter: 551
good job man
regards
Old 01-29-2016, 22:55   #22 (permalink)
Member: 1068226
thanks brother
G510-0200 emmc read only
help me
Old 02-08-2016, 05:20   #23 (permalink)
KUMARANSUGUMAR's Avatar
Member: 726340
Sonork: 100.1624264
Thanks Meter: 86
after try this process same issue in y300_0100 . cant update via sd card
what is the solution ?????
Old 02-15-2016, 17:15   #24 (permalink)
alorpothe's Avatar
Member: 2235775
Thanks Meter: 351
i am not clear bro.without remove ic not possible pinout.& remove protection
Old 02-26-2016, 16:55   #25 (permalink)
Member: 2336072
Sonork: 100.1662984
Thanks Meter: 23
hey mainuddin bro do u have huawei y540-u01 frimware if u have pleas share me
Old 03-30-2016, 15:06   #26 (permalink)
Member: 520327
Sonork: 100.1636717
Thanks Meter: 84
no connect with me
any help
Old 05-16-2016, 14:18   #27 (permalink)
NIYUBAHRIN's Avatar
Member: 1333065
Sonork: 100.1656291
Thanks Meter: 12
Huawei Y300-0100 emmc error
Dear brother monuddin,
how to do this,pls explain i have one phone th same problem.pls help me to fix,
Old 05-16-2016, 23:42   #28 (permalink)
Member: 2558672
Thanks Meter: 26
only samsung emmc ic supported remove write protection till date
i hope more emmc ics added soon.
wait and watch.
Gud job, nice share thanks bro
Old 05-24-2016, 07:09   #29 (permalink)
Member: 381415
greetings friend
Could you explain me the step by step procedure to repair the Huawei Y300 EMMC.
Old 06-29-2016, 03:03   #30 (permalink)
Member: 2301015
Sonork: 100.1668279
Thanks Meter: 10
Riff Supported this?
Page generated in 0.21940 seconds with 8 queries
