07-17-2016, 23:16 | #32 (permalink) |
Freak Poster Join Date: Nov 2013 Location: Venezuela-Falcon
Member: 2074524 Status: Offline Sonork: 100.1627435 Thanks Meter: 135 | I have done on several computers all ok procedure when upgrading by sd or perform deletion or start again the protection in the EMMC and I can check by putting it in pink screen Enviado desde mi ZTE Blade Apex2 mediante Tapatalk |
The Following User Says Thank You to Pablo Velasqu For This Useful Post: |
08-10-2016, 02:05 | #34 (permalink) |
Freak Poster Join Date: May 2016 Location: Saudi Arab Dammam
Member: 2574123 Status: Offline Sonork: 100.1652460 Thanks Meter: 11 | If your phone having write protection, you cant update firmware . You should remove write protection as he did & he remove emmc for pinout purpose which u don't have to remove emmc as he uploaded the pin out.Make a jumpers remove write protection n update firmware thats all If face any prblm while updating just try different firmwares as I tried n got seccuss in fifth firmware Great work bro thanks 4 helping us Sent from my GT-I8262 using Tapatalk |
The Following User Says Thank You to khanyunus For This Useful Post: |
09-21-2016, 14:09 | #38 (permalink) | |
Freak Poster Join Date: Jul 2015 Location: Kathmandu nepal
Member: 2430157 Status: Offline Sonork: dsakkkkmriz Thanks Meter: 49 | Quote:
Z3X EasyJtag Software ver. 2.3.0.0 Loading eMMC Addon Firmware... IO: 3300 mV Box S/N: 0700\, ,FW Ver.: 01.55CMD Pullup Level:2382 mV CMD Active Level:2825 mV Box IO Level:3300 mV CLK Rate:7000 khz HiPower mode is ON! Can't init device, Reason: OCR Ready Timeout Error [Check VCC or eMMC DEAD] Done. | |
02-26-2017, 17:30 | #40 (permalink) | |
Freak Poster Join Date: Jun 2007 Location: Chittagong, Bangladesh, Age: 41
Member: 537240 Status: Offline Sonork: 100.1660416 Thanks Meter: 233 | Quote:
plz post full detail. | |
02-26-2017, 21:30 | #41 (permalink) | |
Member: 131131 Status: Offline Sonork: 100.1606847 Thanks Meter: 4,475 | Quote:
Usually When you have WP eMMC You Must Replace eMMC Because Personally I think any eMMC after remove WP or Update FW have a short Life except VTU00M Anyway after remove write protect you don't need anything just reset from setting also sometimes after reset,WP back again so need update FW then write dump and reflash phone | |
The Following 4 Users Say Thank You to BABAK NURI For This Useful Post: |
04-22-2017, 12:52 | #44 (permalink) | |
Major Poster Join Date: May 2010 Location: Bromo-Indonesia
Member: 1299901 Status: Offline Thanks Meter: 6 | Quote:
and this is yours ; EMMC Manufacturer ID: 0045 ( not samsung ) i am sory if i'm wrong. | |
