11-12-2016, 03:30 | #33 (permalink) |
Freak Poster Join Date: Apr 2013 Location: Đà Nẵng - Việ Age: 44
Member: 1911593 Status: Offline Sonork: 100.1645151 Thanks Meter: 130 | LS996 not found pinout Data 0. You need remove eMMC out PCB https://www.facebook.com/photo.php?f...type=3&theater |
04-21-2017, 23:07 | #37 (permalink) |
Crazy Poster Join Date: Jan 2014
Member: 2109196 Status: Offline Thanks Meter: 6 | this boot can use for h959 and enter download mode. for emmc change. but the problem is when i flash it into h959 stock rom it will be dead. same hw or not between ls996 and h959. and now i will try one more to flash it into ls996. if it workin i will tell here if its not, had someone here share dump rom1 1gb from a working phone lg h959 ???? regards |
07-20-2017, 01:34 | #41 (permalink) |
Freak Poster Join Date: Sep 2011
Member: 1659385 Status: Offline Sonork: 100.1678591 Thanks Meter: 115 | I know this is an old thread but just some info... Just reballing did the job for me on a V10 a few months ago no need for programming. These phones have an overheating issue from factory which causes a bootloop and phone being recognized as hs-usb qdloader 9008, there is even a lawsuit against LG. I used arctic silver and a home made heatsink to transfer the heat. |
The Following User Says Thank You to jcdes For This Useful Post: |
12-28-2017, 17:42 | #42 (permalink) |
Junior Member Join Date: Apr 2008 Location: lebanon
Member: 759172 Status: Offline Thanks Meter: 6 | http://www .mediafire.com/file/a8ati8ujdtcoacs/LS996+emmc+pinout.jpg#! lg ls966 emmc pinout ...remove space in the likn !!!! |
The Following User Says Thank You to faithfull For This Useful Post: |
02-12-2018, 07:39 | #43 (permalink) |
Freak Poster Join Date: Mar 2012 Location: BARNALA
Member: 1734313 Status: Offline Sonork: 100.1620886 Thanks Meter: 70 | I have some points damaged by mistake of LS996 Can any expert tell....will EMMC work on it...or which necessary point is broken and how to fix that...... Thx in advance....... IMG_20180212_120623.jpg |
