Old 05-12-2019, 08:35   #1 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
need redmi s2/y2 full dump
hi guys,
I need full EMMC dump for xiaomi redmi S2/Y2 emergency.
please share your backups.
thanks in advance.
Old 05-20-2019, 10:13   #2 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Originally Posted by aydin.gsm1 View Post
hi guys,
thanks in advance.
https://mega.nz/#!TVxiHS6B!uQVe3gfn_...gFnSq5CSNzvMqs
Redmi S2 backup by vendor w/o system & userdata
The Following 5 Users Say Thank You to layder For This Useful Post:
Old 05-22-2019, 15:07   #3 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
hey bro! the device turned alive!
thank you so much...
Old 05-23-2019, 17:15   #4 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
can you please give me redmi s2 service manual sir?
Old 05-24-2019, 12:54   #5 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
battery connector ways need please.
Old 05-25-2019, 12:34   #6 (permalink)
raisalina's Avatar
Member: 1911970
Sonork: 9741081772
Thanks Meter: 2,080
The Following User Says Thank You to raisalina For This Useful Post:
Old 05-28-2019, 08:20   #7 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
Originally Posted by raisalina View Post
sir, maybe one way is wrong
the device powered once at ten times (only with charger)
your solution not working.
Old 05-31-2019, 12:55   #8 (permalink)
aydin.gsm1's Avatar
Member: 1333047
Sonork: 100.1618775
Thanks Meter: 278
isn't there any schematic for redmi s2/y2?
Old 06-26-2019, 17:04   #9 (permalink)
Member: 1212133
Thanks Meter: 58
Xiaomi Redmi S2 - eMMC - good or bad?
Xiaomi Redmi S2, when connected to a computer, shows QLoader 9008 error.
I desolder eMMC and checked with EasyJtag :
Setting frequence to 21 Mhz
CMD Pullup Level: 3217 mV
CMD Active Level: 3310 mV
EMMC Device Information :
EMMC CID: 0600003136FFFFFFFFFF195C493934EA
EMMC CSD: 8C4F012A0F598000F6D801E08A400076
EMMC Manufacture : , EMMC NAME: 16 , HEX: 313600000000 , S/N: 195C4939 , rev. 0xFF
EMMC Manufacture ID: 0x06 , OEM ID: 0x00 , Device Type: Device (removable) , Date: 3/2017
EMMC ROM 1 (Main User Data) Capacity: 31596 MB (0007B6C80000)
EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 0 KB (000000000000)
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000)
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: Yes
Extended CSD Information :
Extended CSD rev: 1.7 (MMC 5.0, MMC 5.01)
Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot
Boot Bus Config: 0x00 , width 1bit
H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled
Supported partition features [PARTITIONING_SUPPORT]: 0x07
Device supports partitioning features
Device can have enhanced technological features in partitions and user data area
Device can have extended partitions attribute
Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: 16_195C4939_20190626_161702.extcsd
EMMC Init completed.
Error: EMMC Password Locked
Backup saved: 16_195C4939_20190626_161722.extcsd
Operation: File Explorer...
Scan from: 16
Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #1
Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #2
Error reading at address: 000000000000 , error: -206, PORT Read Error ... Retry #3
Too many errors. Reading has been stopped
Error reading at address: 0007B6C7C000 , error: -206, PORT Read Error ... Retry #1
Error reading at address: 0007B6C7C000 , error: -206, PORT Read Error ... Retry #2
Error reading at address: 0007B6C7C000 , error: -206, PORT Read Error ... Retry #3
Vendor: Qualcomm
Searching GPT ...
GPT header is not found
Searching MBR ...
MBR header is not found
Partition table not found
Is it enough to test that eMMC is OK and the QLoader 9008 error is caused by something else?
Thanks for reply
Old 06-28-2019, 17:20   #10 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 650
partion is currupt resize partion or flash with dump
Old 06-28-2019, 21:22   #11 (permalink)
Member: 1212133
Thanks Meter: 58
Thanks for the reply. Do you mean that eMMC itself ( hardware) is good?
But if I flash with dump will it work? It is Xiaomi and eMMC is linked with CPU.
Or can you let me know how to resize the partition?
Old 06-29-2019, 06:31   #12 (permalink)
ishant's Avatar
Member: 1763238
Thanks Meter: 370
Old 06-29-2019, 08:09   #13 (permalink)
layder's Avatar
Member: 13148
Thanks Meter: 2,948
Try to use "Erase e(MMC) password" and "Universal Format Repair" function at EasyJTAG classic software
The Following User Says Thank You to layder For This Useful Post:
Old 06-29-2019, 18:47   #14 (permalink)
umar342's Avatar
Member: 1246696
Sonork: 100.1681950
Thanks Meter: 650
just farmat factry reset and wright full dump no need to resise partion
Old 07-01-2019, 10:39   #15 (permalink)
Member: 1212133
Thanks Meter: 58
Thank you for your replies.
@layder: But when using the latest EasyJtag version, it does not reports Password protected
Setting frequence to 21 MHz
CMD Pullup Level: 3021 mV
CMD Active Level: 1815 mV
EMMC Manufacture ID: 0x06 , OEM ID: 0x00 , Device Type: Device (removable) , Date: 3/2001
EMMC RPMB (Replay Protected Memory Block) Capacity: 0 KB (000000000000) Counter: 0 , Response: Maybe not clean
Extended CSD rev: 1.0 (MMC 4.0)
H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled
Supported partition features [PARTITIONING_SUPPORT]: 0x00
Backup saved: 16_195C4939_20190627_095207.extcsd
Do you have any explanation?
I can try to format eMMC and write dump, but isn't eMMC linked with CPU in Xiaomi?
And eMMC can not be replaced but only together with CPU from the same mainboard?
Can EasyJtag help?
Any advice?
Thank you for help
Page generated in 0.22129 seconds with 9 queries
