Old 04-07-2017, 15:44   #1 (permalink)
Member: 2409394
Thanks Meter: 8
xt1022 write block verify error rom 1
EasyJtag Suite Classic ver.: 2.5.0.8 / wxWidgets 3.1.0-W-U started.
OS ver.: Windows 8 (build 9200), 64-bit edition. Admin rights FAIL
undefined
Android Explorer ver.: 1.0.0.23
eMMC ODIN ver.: 1.0.11.2
Successfully connected to box on COM7
Box S/N: 0800F013AE8155A3, ,FW Ver.: 01.58
Box Working Mode: JTAG Box.
Box Drivers version: 3.0.1.0, are OK
Z3X Card Serial : AA33-1D6E , ver: 22
Z3X Card Activation [LG] : NOT ACTIVATED
Z3X Card Activation [SAMS] : NOT ACTIVATED
Z3X Card Activation [JTAG] : ACTIVATED
Z3X EasyJtag Software ver. 2.5.0.8
Loading eMMC Addon Firmware... IO: 3300 mV
CMD Pullup Level:1763 mV
CMD Active Level:2423 mV
Box IO Level:3300 mV
CLK Rate:3000 khz
HiPower mode is off!
---------- eMMC Device Information ----------
EMMC CID : 90014A483447316404050EA1500051E8
EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2
EMMC Manufacturer ID: 0090 , OEM ID: 014A
EMMC Date: 05/2014 Rev.0x5
EMMC NAME: H4G1d , S/N: 245452800
EMMC NAME (HEX): 48344731642000
EMMC ROM1 (Main User Data) Capacity: 3728 MB
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.6 (MMC 4.5)
Boot configuration [PARTITION_CONFIG: 0x00] No boot partition configured.
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x00.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Backup saved: H4G1d _ 245452800_20170407_1951.extcsd
Done.
Checking NAND Image : D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dump\EMMC_ ROM1_004G90_1171445907_00000000_20000000.bin
Autodetected RAW data
File successefuly loaded!
Found ROM2 and automatically selected.
Found ROM3 and automatically selected.
Found EXT CSD and automatically selected.
Processing file...D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dum p\004G90_1171445907_20160530_1915.extcsd
Processing file...D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dum p\EMMC_ROM1_004G90_1171445907_00000000_20000000.bi n
Processing file...D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dum p\EMMC_ROM2_004G90_1171445907_00000000_00200000.bi n
Processing file...D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dum p\EMMC_ROM3_004G90_1171445907_00000000_00200000.bi n
Running:Repair extCSD...
Skip loading eMMC Addon Firmware
CLK Rate:3000 khz
Writing...
Done.
Length limit is enabled!
Input file : D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dump\EMMC_ ROM1_004G90_1171445907_00000000_20000000.bin
Writing 0000800000 bytes to 0000000000... ROM1 (USER ROM)
Write Block Failed, Reason: Write Block Verify Error
Done.
Done with error(s)
Input file : D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dump\EMMC_ ROM2_004G90_1171445907_00000000_00200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 345 kB/s
Input file : D:\IDM\MOTOROLA_MOTO_XT1022_emmc_direct_dump\EMMC_ ROM3_004G90_1171445907_00000000_00200000.bin
Writing 0000200000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Done. Write Speed: 346 kB/s
Writing as RAW data
Writing 0020000000 bytes to 0000000000... ROM1 (USER ROM)
Done.
Done with error(s)
Writing as RAW data
Done.
Done with error(s)
Checking NAND Image : D:\EMMC_ROM1_H4G1d_245452800_00000000_00020000.bin
Processing file...D:\EMMC_ROM1_H4G1d_245452800_00000000_00020 000.bin
Writing as RAW data
Input file : D:\EMMC_ROM1_H4G1d_245452800_00000000_00020000.bin
Writing 0000020000 bytes to 0000000000... ROM1 (USER ROM)
Done. Write Speed: 133 kB/s
CMD Active Level:2402 mV
CLK Rate:3000 khz
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
Backup saved: H4G1d _ 245452800_20170407_1957.extcsd
Done.
Writing as RAW data
Writing as RAW data
Done.
Done with error(s)
Checking NAND Image : D:\IDM\XT1022 Full Rom files Easy jtag\EMMC_ROM1_H4G1d_10606932_00000000_20000000.bi n
Processing file...D:\IDM\XT1022 Full Rom files Easy jtag\H4G1d _ 10606932_20160604_1804.extcsd
Processing file...D:\IDM\XT1022 Full Rom files Easy jtag\EMMC_ROM1_H4G1d_10606932_00000000_20000000.bi n
Processing file...D:\IDM\XT1022 Full Rom files Easy jtag\EMMC_ROM2_H4G1d_10606932_00000000_00400000.bi n
Processing file...D:\IDM\XT1022 Full Rom files Easy jtag\EMMC_ROM3_H4G1d_10606932_00000000_00400000.bi n
Box IO Level:2800 mV
CLK Rate:3000 khz
Writing...
Done.
Input file : D:\IDM\XT1022 Full Rom files Easy jtag\EMMC_ROM1_H4G1d_10606932_00000000_20000000.bi n
Done.
Done with error(s)
Input file : D:\IDM\XT1022 Full Rom files Easy jtag\EMMC_ROM2_H4G1d_10606932_00000000_00400000.bi n
Writing 0000400000 bytes to 0000000000 ...ROM2 (BOOT1 ROM)
Done. Write Speed: 348 kB/s
Input file : D:\IDM\XT1022 Full Rom files Easy jtag\EMMC_ROM3_H4G1d_10606932_00000000_00400000.bi n
Writing 0000400000 bytes to 0000000000 ...ROM3 (BOOT2 ROM)
Done. Write Speed: 349 kB/s
Old 04-07-2017, 16:15   #2 (permalink)
>Amit<'s Avatar
Member: 1359320
Sonork: 100.1620477
Thanks Meter: 79
reduce some lenth of the wires connected in the pcb and try
Old 04-10-2017, 09:13   #3 (permalink)
ALI_MAFIA's Avatar
Member: 537240
Sonork: 100.1660416
Thanks Meter: 233
undefined
CLK Rate:3000 khz
Done.
CLK Rate:3000 khz
Writing...
Done.
Done.
Done with error(s)
Writing as RAW data
Done.
Done with error(s)
Writing as RAW data
Done.
Done with error(s)
Writing as RAW data
CLK Rate:3000 khz
Done.
Writing as RAW data
Writing as RAW data
Done.
Done with error(s)
CLK Rate:3000 khz
Writing...
Done.
Done.
Done with error(s)
reconfig GP pertition and try again.
Old 04-10-2017, 11:33   #4 (permalink)
ProcyOne's Avatar
Member: 523318
Thanks Meter: 268
If You haven't got CID partition backup don't even bother to fix this phone. Waste of time!!!
Page generated in 0.22319 seconds with 8 queries
