08-16-2019, 02:21 | #1 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | XT1792 - Write Flashfile.XML not loaded How use flashfile.xml for write emmc? I tried but no show partitions. Someone have good full dump for it? Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 17763 (10.0.17763.1) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 15AEEBC0126DD0AB Card Serial = AAB79EC2 EasyJTAG Box Firmware = 2.44 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122527.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000020000 - 0000000A0000], size: 000000080000 (512 KB) Partition: rpm, [0000000A0000 - 0000000E0000], size: 000000040000 (256 KB) Partition: tz, [000000120000 - 0000002E0000], size: 0000001C0000 (1,75 MB) Partition: devcfg, [000000320000 - 000000340000], size: 000000020000 (128 KB) Partition: aboot, [000000360000 - 0000004E0000], size: 000000180000 (1,50 MB) Partition: cmnlib, [0000004E0000 - 000000520000], size: 000000040000 (256 KB) Partition: cmnlib64, [000000520000 - 000000560000], size: 000000040000 (256 KB) Partition: keymaster, [000000560000 - 0000005A0000], size: 000000040000 (256 KB) Partition: prov, [0000005A0000 - 0000005D0000], size: 000000030000 (192 KB) Partition: sbl1bak, [0000005E0000 - 000000660000], size: 000000080000 (512 KB) Partition: rpmbak, [000000660000 - 0000006A0000], size: 000000040000 (256 KB) Partition: tzbak, [0000006E0000 - 0000008A0000], size: 0000001C0000 (1,75 MB) Partition: devcfgbak, [0000008E0000 - 000000900000], size: 000000020000 (128 KB) Partition: abootbak, [000000920000 - 000000AA0000], size: 000000180000 (1,50 MB) Partition: cmnlibbak, [000000AA0000 - 000000AE0000], size: 000000040000 (256 KB) Partition: cmnlib64bak, [000000AE0000 - 000000B20000], size: 000000040000 (256 KB) Partition: keymasterbak, [000000B20000 - 000000B60000], size: 000000040000 (256 KB) Partition: provbak, [000000B60000 - 000000B90000], size: 000000030000 (192 KB) Partition: modem, [000000BA0000 - 000006FA0000], size: 000006400000 (100 MB) Partition: fsc, [000006FA0000 - 000006FA0400], size: 000000000400 (1,00 KB) Partition: ssd, [000006FA0400 - 000006FA2400], size: 000000002000 (8,00 KB) Partition: dsp, [000006FA2400 - 000007FA2400], size: 000001000000 (16,0 MB) Partition: DDR, [000007FC0000 - 000007FC8000], size: 000000008000 (32,0 KB) Partition: sec, [000007FC8000 - 000007FCC000], size: 000000004000 (16,0 KB) Partition: utags, [000007FE0000 - 000008060000], size: 000000080000 (512 KB) Partition: utagsBackup, [000008060000 - 0000080E0000], size: 000000080000 (512 KB) Partition: modemst1, [0000080E0000 - 0000082E0000], size: 000000200000 (2,00 MB) Partition: modemst2, [0000082E0000 - 0000084E0000], size: 000000200000 (2,00 MB) Partition: fsg, [0000084E0000 - 000008CE0000], size: 000000800000 (8,00 MB) Partition: persist, [000008CE0000 - 00000ACE0000], size: 000002000000 (32,0 MB) Partition: frp, [00000ACE0000 - 00000AD60000], size: 000000080000 (512 KB) Partition: cid, [00000AD60000 - 00000AD80000], size: 000000020000 (128 KB) Partition: logo, [00000AD80000 - 00000BD80000], size: 000001000000 (16,0 MB) Partition: carrier, [00000BD80000 - 00000CD80000], size: 000001000000 (16,0 MB) Partition: metadata, [00000CD80000 - 00000CE00000], size: 000000080000 (512 KB) Partition: kpan, [00000CE00000 - 00000D600000], size: 000000800000 (8,00 MB) Partition: boot, [00000D600000 - 00000E600000], size: 000001000000 (16,0 MB) Partition: recovery, [00000E600000 - 00000F619000], size: 000001019000 (16,1 MB) Partition: misc, [00000F620000 - 00000F720000], size: 000000100000 (1,00 MB) Partition: limits, [00000F720000 - 00000F728000], size: 000000008000 (32,0 KB) Partition: mota, [00000F740000 - 00000F7C0000], size: 000000080000 (512 KB) Partition: dip, [00000F7C0000 - 00000F8C0000], size: 000000100000 (1,00 MB) Partition: syscfg, [00000F8C0000 - 00000F940000], size: 000000080000 (512 KB) Partition: logs, [00000F940000 - 00000FB40000], size: 000000200000 (2,00 MB) Partition: apdp, [00000FB40000 - 00000FB80000], size: 000000040000 (256 KB) Partition: msadp, [00000FB80000 - 00000FBC0000], size: 000000040000 (256 KB) Partition: dpo, [00000FBC0000 - 00000FBC2000], size: 000000002000 (8,00 KB) Partition: padA, [00000FBE0000 - 000010000000], size: 000000420000 (4,13 MB) Partition: sp, [000010000000 - 000010800000], size: 000000800000 (8,00 MB) Partition: hw, [000010800000 - 000011000000], size: 000000800000 (8,00 MB) Partition: oem, [000011000000 - 00003A000000], size: 000029000000 (656 MB) Partition: cache, [00003A000000 - 00004A000000], size: 000010000000 (256 MB) Partition: system, [00004A000000 - 000122000000], size: 0000D8000000 (3,38 GB) Partition: userdata, [000122000000 - 000747BFBE00], size: 000625BFBE00 (24,5 GB) GPT header successfully parsed Get firmware version Brand = motorola Manufacturer = motorola Device = montana Model = Moto G (5S) Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 8.1.0 Firmware date = Wed Jun 26 05:52:45 CDT 2019 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122606.extcsd EMMC Init completed. Opening file: flashfile.xml Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1800 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122632.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1800 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122644.extcsd EMMC Init completed. Opening file: flashfile.xml Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1798 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122707.extcsd EMMC Init completed. Opening file: servicefile.xml Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1801 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122713.extcsd EMMC Init completed. Opening file: flashfile.xml Nothing to write. Process stopped. Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1798 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122737.extcsd EMMC Init completed. Opening file: flashfile.xml Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1800 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122811.extcsd EMMC Init completed. Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122844.extcsd EMMC Init completed. Operation: Find table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122923.extcsd EMMC Init completed. Opening file: gpt.bin Analyzing Image: gpt.bin Vendor: Qualcomm Searching GPT ... GPT header is not found Searching MBR ... MBR header is not found Partition table not found Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_122939.extcsd EMMC Init completed. Opening file: flashfile.xml Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_123018.extcsd EMMC Init completed. Opening file: flashfile.xml Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_123055.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000020000 - 0000000A0000], size: 000000080000 (512 KB) Partition: rpm, [0000000A0000 - 0000000E0000], size: 000000040000 (256 KB) Partition: tz, [000000120000 - 0000002E0000], size: 0000001C0000 (1,75 MB) Partition: devcfg, [000000320000 - 000000340000], size: 000000020000 (128 KB) Partition: aboot, [000000360000 - 0000004E0000], size: 000000180000 (1,50 MB) Partition: cmnlib, [0000004E0000 - 000000520000], size: 000000040000 (256 KB) Partition: cmnlib64, [000000520000 - 000000560000], size: 000000040000 (256 KB) Partition: keymaster, [000000560000 - 0000005A0000], size: 000000040000 (256 KB) Partition: prov, [0000005A0000 - 0000005D0000], size: 000000030000 (192 KB) Partition: sbl1bak, [0000005E0000 - 000000660000], size: 000000080000 (512 KB) Partition: rpmbak, [000000660000 - 0000006A0000], size: 000000040000 (256 KB) Partition: tzbak, [0000006E0000 - 0000008A0000], size: 0000001C0000 (1,75 MB) Partition: devcfgbak, [0000008E0000 - 000000900000], size: 000000020000 (128 KB) Partition: abootbak, [000000920000 - 000000AA0000], size: 000000180000 (1,50 MB) Partition: cmnlibbak, [000000AA0000 - 000000AE0000], size: 000000040000 (256 KB) Partition: cmnlib64bak, [000000AE0000 - 000000B20000], size: 000000040000 (256 KB) Partition: keymasterbak, [000000B20000 - 000000B60000], size: 000000040000 (256 KB) Partition: provbak, [000000B60000 - 000000B90000], size: 000000030000 (192 KB) Partition: modem, [000000BA0000 - 000006FA0000], size: 000006400000 (100 MB) Partition: fsc, [000006FA0000 - 000006FA0400], size: 000000000400 (1,00 KB) Partition: ssd, [000006FA0400 - 000006FA2400], size: 000000002000 (8,00 KB) Partition: dsp, [000006FA2400 - 000007FA2400], size: 000001000000 (16,0 MB) Partition: DDR, [000007FC0000 - 000007FC8000], size: 000000008000 (32,0 KB) Partition: sec, [000007FC8000 - 000007FCC000], size: 000000004000 (16,0 KB) Partition: utags, [000007FE0000 - 000008060000], size: 000000080000 (512 KB) Partition: utagsBackup, [000008060000 - 0000080E0000], size: 000000080000 (512 KB) Partition: modemst1, [0000080E0000 - 0000082E0000], size: 000000200000 (2,00 MB) Partition: modemst2, [0000082E0000 - 0000084E0000], size: 000000200000 (2,00 MB) Partition: fsg, [0000084E0000 - 000008CE0000], size: 000000800000 (8,00 MB) Partition: persist, [000008CE0000 - 00000ACE0000], size: 000002000000 (32,0 MB) Partition: frp, [00000ACE0000 - 00000AD60000], size: 000000080000 (512 KB) Partition: cid, [00000AD60000 - 00000AD80000], size: 000000020000 (128 KB) Partition: logo, [00000AD80000 - 00000BD80000], size: 000001000000 (16,0 MB) Partition: carrier, [00000BD80000 - 00000CD80000], size: 000001000000 (16,0 MB) Partition: metadata, [00000CD80000 - 00000CE00000], size: 000000080000 (512 KB) Partition: kpan, [00000CE00000 - 00000D600000], size: 000000800000 (8,00 MB) Partition: boot, [00000D600000 - 00000E600000], size: 000001000000 (16,0 MB) Partition: recovery, [00000E600000 - 00000F619000], size: 000001019000 (16,1 MB) Partition: misc, [00000F620000 - 00000F720000], size: 000000100000 (1,00 MB) Partition: limits, [00000F720000 - 00000F728000], size: 000000008000 (32,0 KB) Partition: mota, [00000F740000 - 00000F7C0000], size: 000000080000 (512 KB) Partition: dip, [00000F7C0000 - 00000F8C0000], size: 000000100000 (1,00 MB) Partition: syscfg, [00000F8C0000 - 00000F940000], size: 000000080000 (512 KB) Partition: logs, [00000F940000 - 00000FB40000], size: 000000200000 (2,00 MB) Partition: apdp, [00000FB40000 - 00000FB80000], size: 000000040000 (256 KB) Partition: msadp, [00000FB80000 - 00000FBC0000], size: 000000040000 (256 KB) Partition: dpo, [00000FBC0000 - 00000FBC2000], size: 000000002000 (8,00 KB) Partition: padA, [00000FBE0000 - 000010000000], size: 000000420000 (4,13 MB) Partition: sp, [000010000000 - 000010800000], size: 000000800000 (8,00 MB) Partition: hw, [000010800000 - 000011000000], size: 000000800000 (8,00 MB) Partition: oem, [000011000000 - 00003A000000], size: 000029000000 (656 MB) Partition: cache, [00003A000000 - 00004A000000], size: 000010000000 (256 MB) Partition: system, [00004A000000 - 000122000000], size: 0000D8000000 (3,38 GB) Partition: userdata, [000122000000 - 000747BFBE00], size: 000625BFBE00 (24,5 GB) GPT header successfully parsed Get firmware version Brand = motorola Manufacturer = motorola Device = montana Model = Moto G (5S) Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 8.1.0 Firmware date = Wed Jun 26 05:52:45 CDT 2019 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_123152.extcsd EMMC Init completed. Opening file: flashfile.xml Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_123156.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_123239.extcsd EMMC Init completed. Opening file: flashfile.xml |
08-16-2019, 13:17 | #3 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Hi layder I tried to do as video. But now phone no power. Before it was normal (stoped logo moto). I did backup partitions before write flashxml(unpacked). Can help me ? Code: eMMC_tool Suite ver. 1.6.2.0 (release date: 30.06.2019) Microsoft Windows 10 (64 bit) build 17763 (10.0.17763.1) Looking for EasyJTAG box... EasyJTAG API ver. 3307 EasyJTAG Box Serial = 15AEEBC0126DD0AB Card Serial = AAB79EC2 EasyJTAG Box Firmware = 2.44 Changelog: 30.06.2019 (ver 1.6.1.0) Fix: Bugs that have been found through your crash report Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1798 mV CMD Active Level: 1878 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_135958.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000020000 - 0000000A0000], size: 000000080000 (512 KB) Partition: rpm, [0000000A0000 - 0000000E0000], size: 000000040000 (256 KB) Partition: tz, [000000120000 - 0000002E0000], size: 0000001C0000 (1,75 MB) Partition: devcfg, [000000320000 - 000000340000], size: 000000020000 (128 KB) Partition: aboot, [000000360000 - 0000004E0000], size: 000000180000 (1,50 MB) Partition: cmnlib, [0000004E0000 - 000000520000], size: 000000040000 (256 KB) Partition: cmnlib64, [000000520000 - 000000560000], size: 000000040000 (256 KB) Partition: keymaster, [000000560000 - 0000005A0000], size: 000000040000 (256 KB) Partition: prov, [0000005A0000 - 0000005D0000], size: 000000030000 (192 KB) Partition: sbl1bak, [0000005E0000 - 000000660000], size: 000000080000 (512 KB) Partition: rpmbak, [000000660000 - 0000006A0000], size: 000000040000 (256 KB) Partition: tzbak, [0000006E0000 - 0000008A0000], size: 0000001C0000 (1,75 MB) Partition: devcfgbak, [0000008E0000 - 000000900000], size: 000000020000 (128 KB) Partition: abootbak, [000000920000 - 000000AA0000], size: 000000180000 (1,50 MB) Partition: cmnlibbak, [000000AA0000 - 000000AE0000], size: 000000040000 (256 KB) Partition: cmnlib64bak, [000000AE0000 - 000000B20000], size: 000000040000 (256 KB) Partition: keymasterbak, [000000B20000 - 000000B60000], size: 000000040000 (256 KB) Partition: provbak, [000000B60000 - 000000B90000], size: 000000030000 (192 KB) Partition: modem, [000000BA0000 - 000006FA0000], size: 000006400000 (100 MB) Partition: fsc, [000006FA0000 - 000006FA0400], size: 000000000400 (1,00 KB) Partition: ssd, [000006FA0400 - 000006FA2400], size: 000000002000 (8,00 KB) Partition: dsp, [000006FA2400 - 000007FA2400], size: 000001000000 (16,0 MB) Partition: DDR, [000007FC0000 - 000007FC8000], size: 000000008000 (32,0 KB) Partition: sec, [000007FC8000 - 000007FCC000], size: 000000004000 (16,0 KB) Partition: utags, [000007FE0000 - 000008060000], size: 000000080000 (512 KB) Partition: utagsBackup, [000008060000 - 0000080E0000], size: 000000080000 (512 KB) Partition: modemst1, [0000080E0000 - 0000082E0000], size: 000000200000 (2,00 MB) Partition: modemst2, [0000082E0000 - 0000084E0000], size: 000000200000 (2,00 MB) Partition: fsg, [0000084E0000 - 000008CE0000], size: 000000800000 (8,00 MB) Partition: persist, [000008CE0000 - 00000ACE0000], size: 000002000000 (32,0 MB) Partition: frp, [00000ACE0000 - 00000AD60000], size: 000000080000 (512 KB) Partition: cid, [00000AD60000 - 00000AD80000], size: 000000020000 (128 KB) Partition: logo, [00000AD80000 - 00000BD80000], size: 000001000000 (16,0 MB) Partition: carrier, [00000BD80000 - 00000CD80000], size: 000001000000 (16,0 MB) Partition: metadata, [00000CD80000 - 00000CE00000], size: 000000080000 (512 KB) Partition: kpan, [00000CE00000 - 00000D600000], size: 000000800000 (8,00 MB) Partition: boot, [00000D600000 - 00000E600000], size: 000001000000 (16,0 MB) Partition: recovery, [00000E600000 - 00000F619000], size: 000001019000 (16,1 MB) Partition: misc, [00000F620000 - 00000F720000], size: 000000100000 (1,00 MB) Partition: limits, [00000F720000 - 00000F728000], size: 000000008000 (32,0 KB) Partition: mota, [00000F740000 - 00000F7C0000], size: 000000080000 (512 KB) Partition: dip, [00000F7C0000 - 00000F8C0000], size: 000000100000 (1,00 MB) Partition: syscfg, [00000F8C0000 - 00000F940000], size: 000000080000 (512 KB) Partition: logs, [00000F940000 - 00000FB40000], size: 000000200000 (2,00 MB) Partition: apdp, [00000FB40000 - 00000FB80000], size: 000000040000 (256 KB) Partition: msadp, [00000FB80000 - 00000FBC0000], size: 000000040000 (256 KB) Partition: dpo, [00000FBC0000 - 00000FBC2000], size: 000000002000 (8,00 KB) Partition: padA, [00000FBE0000 - 000010000000], size: 000000420000 (4,13 MB) Partition: sp, [000010000000 - 000010800000], size: 000000800000 (8,00 MB) Partition: hw, [000010800000 - 000011000000], size: 000000800000 (8,00 MB) Partition: oem, [000011000000 - 00003A000000], size: 000029000000 (656 MB) Partition: cache, [00003A000000 - 00004A000000], size: 000010000000 (256 MB) Partition: system, [00004A000000 - 000122000000], size: 0000D8000000 (3,38 GB) Partition: userdata, [000122000000 - 000122000200], size: 000000000200 (512 B) GPT header successfully parsed Get firmware version Brand = motorola Manufacturer = motorola Device = montana Model = Moto G (5S) Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 8.1.0 Firmware date = Wed Jun 26 05:52:45 CDT 2019 Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1800 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_140019.extcsd EMMC Init completed. Operation: Writing eMMC... Writing to: ROM1 , start: 0x000000000000 , size: 0x000000008000 Input file: R:\Downloads 2019\MONTANA_RETAIL_8.1.0_OPPS28.65-37-7-6_cid50_subsidy-DEFAULT_regulatory-DEFAULT_CFC.xml\gpt_main0.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 537,04 KB/s All done time: [00:00:00:347] Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1799 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_140025.extcsd EMMC Init completed. Operation: Try to read table from emmc Vendor: Qualcomm Searching GPT ... GPT header is found and is valid Checking for ROM2 ... ROM2 is blank Checking for ROM3 ... ROM3 is blank GPT header successfully parsed Setting interface to EasyJtag2/ISP Setting bus width to 1 Bit Setting frequence to 18 MHz CMD Pullup Level: 1800 mV CMD Active Level: 1877 mV EMMC Device Information : EMMC CID: 90014A484247346132A55923A4B794BF EMMC CSD: D02701328F5903FFFFFFFFE78A400017 EMMC Manufacture : SKHYNIX , EMMC NAME: HBG4a2 , HEX: 484247346132 , S/N: 5923A4B7 , rev. 0xA5 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 9/2017 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 36882 , Response: Not Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x38 , Boot from: ROM1 (Main User Area) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: HBG4a2_5923A4B7_20190815_141406.extcsd EMMC Init completed. Operation: Write by vendor (Qualcomm/HiSilicon/Omap) Partition name: sbl1 Filename: sbl1.mbn , Offset: 000000020000 , filesize: 519296 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 871,98 KB/s Partition name: rpm Filename: rpm.mbn , Offset: 0000000A0000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 931,91 KB/s Partition name: tz Filename: tz.mbn , Offset: 000000120000 , filesize: 1835008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1635,92 KB/s Partition name: devcfg Filename: devcfg.mbn , Offset: 000000320000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1621,36 KB/s Partition name: aboot Filename: emmc_appsboot.mbn , Offset: 000000360000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1956,69 KB/s Partition name: cmnlib Filename: cmnlib.mbn , Offset: 0000004E0000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1518,29 KB/s Partition name: cmnlib64 Filename: cmnlib64.mbn , Offset: 000000520000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1353,73 KB/s Partition name: keymaster Filename: keymaster.mbn , Offset: 000000560000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1520,72 KB/s Partition name: prov Filename: prov.mbn , Offset: 0000005A0000 , filesize: 191616 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1396,94 KB/s Partition name: sbl1bak Filename: sbl1.mbn , Offset: 0000005E0000 , filesize: 519296 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1671,10 KB/s Partition name: rpmbak Filename: rpm.mbn , Offset: 000000660000 , filesize: 262144 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2065,32 KB/s Partition name: tzbak Filename: tz.mbn , Offset: 0000006E0000 , filesize: 1835008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 2033,01 KB/s Partition name: devcfgbak Filename: devcfg.mbn , Offset: 0000008E0000 , filesize: 131072 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1700,35 KB/s Partition name: abootbak Filename: emmc_appsboot.mbn , Offset: 000000920000 , filesize: 1572864 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1964,43 KB/s Partition name: cmnlibbak Filename: cmnlib.mbn , Offset: 000000AA0000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1519,11 KB/s Partition name: cmnlib64bak Filename: cmnlib64.mbn , Offset: 000000AE0000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1552,95 KB/s Partition name: keymasterbak Filename: keymaster.mbn , Offset: 000000B20000 , filesize: 257152 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1544,75 KB/s Partition name: provbak Filename: prov.mbn , Offset: 000000B60000 , filesize: 191616 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 1356,15 KB/s All done time: [00:00:27:657] |
08-16-2019, 13:57 | #4 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Read Info after write flashfilexml (unpacked) Code: Z3X EasyJtag Software ver. 3.6.1.4 Loading eMMC GEN2 Firmware... IO: 1800 mV Box S/N: 15AEEBC0126DD0AB, ,FW Ver.: 02.44 CMD Pullup Level:1799 mV CMD Active Level:1878 mV Box IO Level:1800 mV CLK Rate:18000 kHz Bus Width:1bit,SDR HiPower mode is off! ---------- eMMC Device Information ---------- eMMC CID : 90014A484247346132A55923A4B794BF eMMC CSD : D02701328F5903FFFFFFFFE78A400017 eMMC Manufacturer ID: 0090 , OEM ID: 014A eMMC Date: 09/2017 Rev.0xA5 eMMC NAME: HBG4a2 , S/N: 1495508151 eMMC NAME (HEX): 484247346132 EMMC ROM1 (Main User Data) Capacity: 29820 MB , 0x3A3E000 pages , 0x747C00000 bytes EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC RPMB is programmed and written 36882 times EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x01 High-capacity WP group size [HC_WP_GRP_SIZE: 0x00002000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: HBG4a2_1495508151_20190815_1458.extcsd ============================================= Extended CSD rev 1.8 (MMC 5.1) ============================================= Card Supported Command sets [S_CMD_SET: 0x01] HPI Features [HPI_FEATURE: 0x01]: implementation based on CMD13 Background operations support [BKOPS_SUPPORT: 0x01] Max Packet Read Cmd [MAX_PACKED_READS: 0x3f] Max Packet Write Cmd [MAX_PACKED_WRITES: 0x3f] Data TAG support [DATA_TAG_SUPPORT: 0x01] Data TAG Unit Size [TAG_UNIT_SIZE: 0x00] Tag Resources Size [TAG_RES_SIZE: 0x00] Context Management Capabilities [CONTEXT_CAPABILITIES: 0x78] Large Unit Size [LARGE_UNIT_SIZE_M1: 0x01] Extended partition attribute support [EXT_SUPPORT: 0x03] Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB ------------------------- eMMC v5+ ------------------------- Supported modes [SUPPORTED_MODES: 0x01] FFU features [FFU_FEATURES: 0x00] Operation codes timeout [OPERATION_CODE_TIMEOUT: 0x00] FFU Argument [FFU_ARG: 0xfffafff0] Number of FW sectors correctly programmed[NUM_OF_FW_SECT_CORR_PROG: 0] Vendor proprietary health report: [VENDOR_PROPRIETARY_HEALTH_REPORT[301]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[300]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[299]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[298]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[297]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[296]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[295]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[294]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[293]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[292]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[291]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[290]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[289]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[288]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[287]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[286]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[285]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[284]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[283]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[282]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[281]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[280]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[279]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[278]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[277]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[276]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[275]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[274]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[273]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[272]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[271]]:0x00 [VENDOR_PROPRIETARY_HEALTH_REPORT[270]]:0x00 _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_B: 0x02] i.e. 10% - 20% device life time used _(Device life time estimation type B [DEVICE_LIFE_TIME_EST_TYP_A: 0x01] i.e. 0% - 10% device life time used Pre EOL information [PRE_EOL_INFO: 0x01] i.e. Normal Optimal read size [OPTIMAL_READ_SIZE: 0x40] Optimal write size [OPTIMAL_WRITE_SIZE: 0x40] Optimal trim unit size [OPTIMAL_TRIM_UNIT_SIZE: 0x07] Device version [DEVICE_VERSION: 0x42 - 0x05] Firmware version: [FIRMWARE_VERSION[261]]: 0x00 [FIRMWARE_VERSION[260]]: 0x00 [FIRMWARE_VERSION[259]]: 0x00 [FIRMWARE_VERSION[258]]: 0x00 [FIRMWARE_VERSION[257]]: 0x00 [FIRMWARE_VERSION[256]]: 0x00 [FIRMWARE_VERSION[255]]: 0x00 [FIRMWARE_VERSION[254]]: 0xa5 Power class for 200MHz, DDR at VCC= 3.6V [PWR_CL_DDR_200_360: 0x22] ------------------------------------------------------------- Generic CMD6 Timer [GENERIC_CMD6_TIME: 0x0a] Power off notification [POWER_OFF_LONG_TIME: 0x64] Cache Size [CACHE_SIZE] is 1024 KiB Background operations status [BKOPS_STATUS: 0x00] 1st Initialisation Time after programmed sector [INI_TIMEOUT_AP: 0x0a] Power class for 52MHz, DDR at 3.6V [PWR_CL_DDR_52_360: 0x11] Power class for 52MHz, DDR at 1.95V [PWR_CL_DDR_52_195: 0x00] Power class for 200MHz at 3.6V [PWR_CL_200_360: 0x22] Power class for 200MHz, at 1.95V [PWR_CL_200_195: 0x00] Minimum Performance for 8bit at 52MHz in DDR mode: [MIN_PERF_DDR_W_8_52: 0x78] [MIN_PERF_DDR_R_8_52: 0x8c] TRIM Multiplier [TRIM_MULT: 0x02] Secure Feature support [SEC_FEATURE_SUPPORT: 0x55] Boot Information [BOOT_INFO: 0x07] Device supports alternative boot method Device supports dual data rate during boot Device supports high speed timing during boot Boot partition size [BOOT_SIZE_MULTI: 0x20] Access size [ACC_SIZE: 0x06] High-capacity erase unit size [HC_ERASE_GRP_SIZE: 0x01] High-capacity erase timeout [ERASE_TIMEOUT_MULT: 0x02] Reliable write sector count [REL_WR_SEC_C: 0x01] High-capacity W protect group size [HC_WP_GRP_SIZE: 0x08] Sleep current (VCC) [S_C_VCC: 0x07] Sleep current (VCCQ) [S_C_VCCQ: 0x07] Sleep/awake timeout [S_A_TIMEOUT: 0x11] Sector Count [SEC_COUNT: 0x03a3e000] Minimum Write Performance for 8bit: [MIN_PERF_W_8_52: 0x8c] [MIN_PERF_R_8_52: 0x8c] [MIN_PERF_W_8_26_4_52: 0x46] [MIN_PERF_R_8_26_4_52: 0x46] Minimum Write Performance for 4bit: [MIN_PERF_W_4_26: 0x1e] [MIN_PERF_R_4_26: 0x1e] Power classes registers: [PWR_CL_26_360: 0x00] [PWR_CL_52_360: 0x00] [PWR_CL_26_195: 0x00] [PWR_CL_52_195: 0x00] Partition switching timing [PARTITION_SWITCH_TIME: 0x01] Out-of-interrupt busy timing [OUT_OF_INTERRUPT_TIME: 0x05] I/O Driver Strength [DRIVER_STRENGTH: 0x1f] Card Type [CARD_TYPE: 0x57] CSD structure version [CSD_STRUCTURE: 0x02] Command set [CMD_SET: 0x00] Command set revision [CMD_SET_REV: 0x00] Power class [POWER_CLASS: 0x00] High-speed interface timing [HS_TIMING: 0x00] Erased memory content [ERASED_MEM_CONT: 0x00] Boot configuration bytes [PARTITION_CONFIG: 0x38] No access to boot partition Boot config protection [BOOT_CONFIG_PROT: 0x00] Boot bus Conditions [BOOT_BUS_CONDITIONS: 0x00] High-density erase group definition [ERASE_GROUP_DEF: 0x00] Boot write protection status registers [BOOT_WP_STATUS]: 0x00 Boot Area Write protection [BOOT_WP]: 0x00 Power ReadOnly locking: possible Permanent ReadOnly locking: possible Read Only lock status: not locked User area write protection register [USER_WP]: 0x10 FW configuration [FW_CONFIG]: 0x00 RPMB Size [RPMB_SIZE_MULT]: 0x20 Write reliability setting register [WR_REL_SET]: 0x1f Write reliability parameter register [WR_REL_PARAM]: 0x15 Enable background operations handshake [BKOPS_EN]: 0x02 H/W reset function [RST_N_FUNCTION]: 0x01 HPI management [HPI_MGMT]: 0x00 Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Max Enhanced Area Size [MAX_ENH_SIZE_MULT]: 0x000e8f Partitions attribute [PARTITIONS_ATTRIBUTE]: 0x00 Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 General Purpose Partition Size [GP_SIZE_MULT_4]: 0x000000 [GP_SIZE_MULT_3]: 0x000000 [GP_SIZE_MULT_2]: 0x000000 [GP_SIZE_MULT_1]: 0x000000 Enhanced User Data Area Size [ENH_SIZE_MULT]: 0x000000 Enhanced User Data Start Address [ENH_START_ADDR]: 0x000000 Bad Block Management mode [SEC_BAD_BLK_MGMNT]: 0x00 Periodic Wake-up [PERIODIC_WAKEUP]: 0x00 Program CID/CSD in DDR mode support [PROGRAM_CID_CSD_DDR_SUPPORT]: 0x00 Native sector size [NATIVE_SECTOR_SIZE]: 0x01 Sector size emulation [USE_NATIVE_SECTOR]: 0x00 Sector size [DATA_SECTOR_SIZE]: 0x00 1st initialization after disabling sector size emulation [INI_TIMEOUT_EMU]: 0x0a Class 6 commands control [CLASS_6_CTRL]: 0x00 Number of addressed group to be released[DYNCAP_NEEDED]: 0x00 Exception events control [EXCEPTION_EVENTS_CTRL]: 0x0000 Exception events status [EXCEPTION_EVENTS_STATUS]: 0x0000 Extended Partitions Attribute [EXT_PARTITIONS_ATTRIBUTE]: 0x0000 Packed command status [PACKED_COMMAND_STATUS]: 0x00 Packed command failure index [PACKED_FAILURE_INDEX]: 0x00 Power Off Notification [POWER_OFF_NOTIFICATION]: 0x00 Control to turn the Cache ON/OFF [CACHE_CTRL]: 0x00 Caution: invalid backup GPT header, but valid main header! Warning! Main and backup partition tables differ!n Warning! One or more CRCs don't match. You should repair the disk! Partition table scan: GPT: damaged Caution: Found protective or hybrid MBR and corrupt GPT. Real (Hardware) Disk/Image size: 3A3E000 sectors 29.1 GiB Soft (Partitioned) Disk/Image size: FFFFFFFFFFFFFFDE sectors 16.0 EiB Logical sector size: 0x200 bytes Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20 First usable sector: 34 Last usable sector: 0 Partition info successfully found Found Data areas (firmware parts) count is: 54 --------------------------------------------- P0 (SBL1) [0x20000 0x80000] Size: 512.0KB P1 (RPM) [0xa0000 0x40000] Size: 256.0KB P2 (TZ) [0x120000 0x1c0000] Size: 1.750MB P3 (DEVCFG) [0x320000 0x20000] Size: 128.0KB P4 (ABOOT) [0x360000 0x180000] Size: 1.500MB P5 (CMNLIB) [0x4e0000 0x40000] Size: 256.0KB P6 (CMNLIB64) [0x520000 0x40000] Size: 256.0KB P7 (KEYMASTER) [0x560000 0x40000] Size: 256.0KB P8 (PROV) [0x5a0000 0x30000] Size: 192.0KB P9 (SBL1BAK) [0x5e0000 0x80000] Size: 512.0KB P10 (RPMBAK) [0x660000 0x40000] Size: 256.0KB P11 (TZBAK) [0x6e0000 0x1c0000] Size: 1.750MB P12 (DEVCFGBAK) [0x8e0000 0x20000] Size: 128.0KB P13 (ABOOTBAK) [0x920000 0x180000] Size: 1.500MB P14 (CMNLIBBAK) [0xaa0000 0x40000] Size: 256.0KB P15 (CMNLIB64BAK) [0xae0000 0x40000] Size: 256.0KB P16 (KEYMASTERBAK) [0xb20000 0x40000] Size: 256.0KB P17 (PROVBAK) [0xb60000 0x30000] Size: 192.0KB P18 (MODEM) [0xba0000 0x6400000] Size: 100.0MB P19 (FSC) [0x6fa0000 0x400] Size: 1.0KB P20 (SSD) [0x6fa0400 0x2000] Size: 8.0KB P21 (DSP) [0x6fa2400 0x1000000] Size: 16.0MB P22 (DDR) [0x7fc0000 0x8000] Size: 32.0KB P23 (SEC) [0x7fc8000 0x4000] Size: 16.0KB P24 (UTAGS) [0x7fe0000 0x80000] Size: 512.0KB P25 (UTAGSBACKUP) [0x8060000 0x80000] Size: 512.0KB P26 (MODEMST1) [0x80e0000 0x200000] Size: 2.0MB P27 (MODEMST2) [0x82e0000 0x200000] Size: 2.0MB P28 (FSG) [0x84e0000 0x800000] Size: 8.0MB P29 (PERSIST) [0x8ce0000 0x2000000] Size: 32.0MB P30 (FRP) [0xace0000 0x80000] Size: 512.0KB P31 (CID) [0xad60000 0x20000] Size: 128.0KB P32 (LOGO) [0xad80000 0x1000000] Size: 16.0MB P33 (CARRIER) [0xbd80000 0x1000000] Size: 16.0MB P34 (METADATA) [0xcd80000 0x80000] Size: 512.0KB P35 (KPAN) [0xce00000 0x800000] Size: 8.0MB P36 (BOOT) [0xd600000 0x1000000] Size: 16.0MB P37 (RECOVERY) [0xe600000 0x1019000] Size: 16.97MB P38 (MISC) [0xf620000 0x100000] Size: 1.0MB P39 (LIMITS) [0xf720000 0x8000] Size: 32.0KB P40 (MOTA) [0xf740000 0x80000] Size: 512.0KB P41 (DIP) [0xf7c0000 0x100000] Size: 1.0MB P42 (SYSCFG) [0xf8c0000 0x80000] Size: 512.0KB P43 (LOGS) [0xf940000 0x200000] Size: 2.0MB P44 (APDP) [0xfb40000 0x40000] Size: 256.0KB P45 (MSADP) [0xfb80000 0x40000] Size: 256.0KB P46 (DPO) [0xfbc0000 0x2000] Size: 8.0KB P47 (PADA) [0xfbe0000 0x420000] Size: 4.125MB P48 (SP) [0x10000000 0x800000] Size: 8.0MB P49 (HW) [0x10800000 0x800000] Size: 8.0MB P50 (OEM) [0x11000000 0x29000000] Size: 656.0MB P51 (CACHE) [0x3a000000 0x10000000] Size: 256.0MB P52 (SYSTEM) [0x4a000000 0xd8000000] Size: 3.375GB P53 (USERDATA) [0x122000000 0x200] Size: 512.0B ------ Android information ------ Detected LINUX(Android) SYSTEM : 0x004A000000 (3.375GB) Build ID: OPPS28.65-37-7-6 Release Incremental ID: 4cc5a Release Base ID: 8.1.0 Device Model: Moto G (5S) Device Name: montana_retail Architecture ABI: armeabi-v7a Device manufacturer: motorola Product ID: montana Device Platform: msm8937 Device Platform: msm8937 --------------------------------------------- Detected USERDATA USERDATA : 0x0122000000 (512.0B) Unable to mount USERDATA , code : 22 Done. Selected eMMC Interface |
08-17-2019, 12:37 | #5 (permalink) |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | New devices now have many protections. It will take time and experience to find out which protections are being applied. Boot recovery is used on devices that cannot connect to a computer using fastboot or recovery modes. The fact that you started to record boots in the device that started, means that you have done unnecessary actions. Now you need to restore backup, and look for another solution to the problem. |
08-17-2019, 13:19 | #6 (permalink) |
Freak Poster Join Date: Jul 2012 Location: brazil
Member: 1789551 Status: Offline Thanks Meter: 90 | Hi, The phone power on after back full backup. But continue with same problem. It write without error latest firmware (using fastboot commands) , but it show same version old after finish flash (fastboot getvar all). i am using firmware 8.1.0 and it show 7.1.1 (but easy jtag to get android version show 8.1.0) Someone have good full backup this model XT1792 ? I want try write full backup and after (write my cid backup). Sorry me for my bad ingles. |
08-17-2019, 14:03 | #7 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | First you need always backup CID partitions on Motorola phones Second - you need check firmware revision, what you upload to phone Third - you need check SMART of flash IC and try to run Random Write verify test |
08-17-2019, 15:59 | #8 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Hi I did smart test and random Code: Operation: Reading S.M.A.R.T Report ... Device Life Time Estimation (MLC) [269]: 0x02 10% - 20% device life time used Device Life Time Estimation (SLC) [268]: 0x01 0% - 10% device life time used Pre EOL information [267]: 0x01 Normal Optimal Read Size [266]: 0x40 256 KB Optimal Write Size [265]: 0x40 256 KB Optimal Trim Unit Size [264]: 0x07 28 KB |
08-17-2019, 23:03 | #9 (permalink) |
Member: 13148 Status: Offline Thanks Meter: 2,948 | SMART and test is good. You may try to write original firmware by files to partition. I can't more help you At our country Motorola are rarely phones |
08-19-2019, 04:09 | #13 (permalink) | |
Member: 1789551 Status: Offline Thanks Meter: 90 | Quote:
It show moto logo and after enter recovery(no comnand) after hold volume + and power it enter recovery. Flash using fastboot commands. No error. But after flash you enter fastboot getvar all. It show old fw version. (Ex write 8.1.0 and show olé 7.1.1) | |
08-20-2019, 17:44 | #14 (permalink) |
Member: 1789551 Status: Offline Thanks Meter: 90 | Hi JefMaximo Flash LOG below: Phone restart and stop "no command" and after enter recovery (if hold volume up and power). Code: ####### [ Flashing Script Criado via Android Tool By LigtelGSM V1.0.14 ] ####### Visite-nos: ...:::: www.LigtelGSM.com.br ::::... ----------- Informações do Firmware ----------- Fw. Modelo: montana Fw. Versão: montana-user 8.1.0 OPPS28.65-37-7-6 4cc5a release-keysM8937_37.13.03.72R ----------------------------------------------- Dispositivo encontrado [ 0043055945 fastboot ]. Pressione qualquer tecla para iniciar, ou CTRL + C para sair Executando flash partition gpt.bin... target max-sparse-size: 256MB sending 'partition' (45 KB)... OKAY [ 0.008s] writing 'partition'... (bootloader) Validating 'gpt.default.xml' (bootloader) Committing 'gpt.default.xml' (bootloader) - flashing 'gpt_main0.bin' to 'partition:0' (bootloader) Flashing primary GPT image... (bootloader) Flashing backup GPT image... OKAY [ 0.079s] finished. total time: 0.089s Executando flash bootloader bootloader.img... target max-sparse-size: 256MB sending 'bootloader' (5179 KB)... OKAY [ 0.165s] writing 'bootloader'... (bootloader) Validating 'bootloader.default.xml' (bootloader) Committing 'bootloader.default.xml' (bootloader) - flashing 'emmc_appsboot.mbn' to 'aboot' (bootloader) - flashing 'rpm.mbn' to 'rpm' (bootloader) - flashing 'tz.mbn' to 'tz' (bootloader) - flashing 'devcfg.mbn' to 'devcfg' (bootloader) - flashing 'cmnlib.mbn' to 'cmnlib' (bootloader) - flashing 'cmnlib64.mbn' to 'cmnlib64' (bootloader) - flashing 'keymaster.mbn' to 'keymaster' (bootloader) - flashing 'prov.mbn' to 'prov' (bootloader) - flashing 'sbl1.mbn' to 'sbl1' OKAY [ 0.345s] finished. total time: 0.513s Executando flash modem NON-HLOS.bin... target max-sparse-size: 256MB sending 'modem' (67974 KB)... OKAY [ 2.142s] writing 'modem'... OKAY [ 0.574s] finished. total time: 2.720s Executando flash fsg fsg.mbn... target max-sparse-size: 256MB sending 'fsg' (3560 KB)... OKAY [ 0.115s] writing 'fsg'... OKAY [ 0.056s] finished. total time: 0.174s Executando erase modemst1 ... erasing 'modemst1'... OKAY [ 0.017s] finished. total time: 0.018s Executando erase modemst2 ... erasing 'modemst2'... OKAY [ 0.017s] finished. total time: 0.020s Executando flash dsp adspso.bin... target max-sparse-size: 256MB sending 'dsp' (16384 KB)... OKAY [ 0.517s] writing 'dsp'... OKAY [ 0.141s] finished. total time: 0.661s Executando flash logo logo.bin... target max-sparse-size: 256MB sending 'logo' (2195 KB)... OKAY [ 0.071s] writing 'logo'... OKAY [ 0.064s] finished. total time: 0.139s Executando flash boot boot.img... target max-sparse-size: 256MB sending 'boot' (16384 KB)... OKAY [ 0.520s] writing 'boot'... OKAY [ 0.301s] finished. total time: 0.828s Executando flash recovery recovery.img... target max-sparse-size: 256MB sending 'recovery' (16484 KB)... OKAY [ 0.522s] writing 'recovery'... OKAY [ 0.310s] finished. total time: 0.835s Executando flash system system.img_sparsechunk.0... target max-sparse-size: 256MB sending 'system' (256294 KB)... OKAY [ 8.072s] writing 'system'... OKAY [ 4.967s] finished. total time: 13.044s Executando flash system system.img_sparsechunk.1... target max-sparse-size: 256MB sending 'system' (256762 KB)... OKAY [ 8.095s] writing 'system'... OKAY [ 3.911s] finished. total time: 12.012s Executando flash system system.img_sparsechunk.2... target max-sparse-size: 256MB sending 'system' (255764 KB)... OKAY [ 8.048s] writing 'system'... OKAY [ 4.360s] finished. total time: 12.412s Executando flash system system.img_sparsechunk.3... target max-sparse-size: 256MB sending 'system' (260630 KB)... OKAY [ 8.202s] writing 'system'... OKAY [ 4.002s] finished. total time: 12.210s Executando flash system system.img_sparsechunk.4... target max-sparse-size: 256MB sending 'system' (257481 KB)... OKAY [ 8.108s] writing 'system'... OKAY [ 7.468s] finished. total time: 15.583s Executando flash system system.img_sparsechunk.5... target max-sparse-size: 256MB sending 'system' (246309 KB)... OKAY [ 7.762s] writing 'system'... OKAY [ 4.804s] finished. total time: 12.569s Executando flash system system.img_sparsechunk.6... target max-sparse-size: 256MB sending 'system' (258569 KB)... OKAY [ 8.141s] writing 'system'... OKAY [ 3.864s] finished. total time: 12.010s Executando flash system system.img_sparsechunk.7... target max-sparse-size: 256MB sending 'system' (251493 KB)... OKAY [ 7.927s] writing 'system'... OKAY [ 4.956s] finished. total time: 12.886s Executando flash system system.img_sparsechunk.8... target max-sparse-size: 256MB sending 'system' (257933 KB)... OKAY [ 8.130s] writing 'system'... OKAY [ 5.138s] finished. total time: 13.279s Executando flash system system.img_sparsechunk.9... target max-sparse-size: 256MB sending 'system' (213640 KB)... OKAY [ 6.724s] writing 'system'... OKAY [ 6.816s] finished. total time: 13.548s Executando flash oem oem.img... target max-sparse-size: 256MB sending 'oem' (247426 KB)... OKAY [ 7.799s] writing 'oem'... OKAY [ 7.379s] finished. total time: 15.185s Executando erase cache ... erasing 'cache'... OKAY [ 0.006s] finished. total time: 0.007s Executando erase userdata ... erasing 'userdata'... OKAY [ 0.037s] finished. total time: 0.038s Executando erase DDR ... erasing 'DDR'... OKAY [ 0.003s] finished. total time: 0.004s Reiniciando o dispositivo... rebooting... finished. total time: 0.001s Processo finalizado com sucesso. Pressione qualquer tecla para sair. |
08-23-2019, 18:36 | #15 (permalink) |
Insane Poster Join Date: Oct 2017
Member: 2772222 Status: Offline Thanks Meter: 9 | I dont understand wehy its happenning. Full dump. Dont forget untick FRP. https://drive.google.com/open?id=1wa...48maVRaYTHcfks |
