09-04-2016, 20:37 | #1 (permalink) |
Freak Poster Join Date: Nov 2009
Member: 1168485 Status: Offline Thanks Meter: 36 | y530-u00 repair boot this the log info ,FW Ver.: 01.55CMD Pullup Level:1763 mV CMD Active Level:2299 mV Box IO Level:2800 mV CLK Rate:14000 khz HiPower mode is off! ---------- eMMC Device Information ----------EMMC CID : 90014A4834473164040302A2B712A1D6 EMMC CSD : D02701320F5903FFFFFFFFEF8A4040D2 EMMC Manufacturer ID: 0090 , OEM ID: 014A EMMC Date: 10/2014 Rev.0x3 EMMC NAME: H4G1d , S/N: 44218130 EMMC NAME (HEX): 48344731642000 EMMC ROM1 (Main User Data) Capacity: 3728 MB EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No EMMC Password Locked: No Extended CSD rev 1.6 (MMC 4.5) Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area) Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38. H/W reset function [RST_N_FUNCTION]: 0x00 High-capacity W protect group size [HC_WP_GRP_SIZE: 0x00000000] Partitioning Support [PARTITIONING_SUPPORT]: 0x07 Device support partitioning feature Device can have enhanced tech. Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00 --------------------------------------------- Backup saved: H4G1d _ 44218130_20160831_2131.extcsd Done. now i am try to write dump files EMMC_ROM1_00000000_100000000 EMMC_ROM2_00000000_00400000 EMMC_ROM3_00000000_00400000 004G90_2677974583_20151002_2142.extcsd i select WRITE ALL EMMC REQIONS AT ONCE and select in rom1 section ROM1 automatic all dump selected and in preset select 512mb and press write after 1 hour write the phone still dead please help me by any advice |
The Following User Says Thank You to boudi_hakerz For This Useful Post: |
09-05-2016, 22:25 | #12 (permalink) |
Member: 1168485 Status: Offline Thanks Meter: 36 | thank you my brother it is work but the phone still dead Processing file...C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM1_00000000_100000000.bin Z3X EasyJtag Software ver. 2.3.0.0Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mVCMD Active Level:2258 mV Input file : C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM1_00000000_100000000. binWriting 00EC000000 bytes to 00000000 ...ROM1 (USER ROM) Optimisations Disabled! Write Length has been corrected to 0x00E9000000 bytes... Done. Write Speed: 1023 kB/s Checking NAND Image : C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM2_00000000_00400000.bin File successefuly loaded! Processing file...C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM2_00000000_00400000.b in Z3X EasyJtag Software ver. 2.3.0.0Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mVCMD Active Level:2258 mV Input file : C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM2_00000000_00400000.b inWriting 0000200000 bytes to 00000000 ...ROM2 (BOOT1 ROM) Optimisations Disabled! Done. Write Speed: 1222 kB/s Checking NAND Image : C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM3_00000000_00400000.bin File successefuly loaded! Processing file...C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM3_00000000_00400000.b in Z3X EasyJtag Software ver. 2.3.0.0Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mVCMD Active Level:2258 mV Input file : C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\EMMC_ROM3_00000000_00400000.b inWriting 0000200000 bytes to 00000000 ...ROM3 (BOOT2 ROM) Optimisations Disabled! Done. Write Speed: 1233 kB/s extCSD file...C:\Users\ABOU MHAMAD\Desktop\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\HUAWEI_ASCEND_Y530-U00_emmc_direct_dump\004G90_2677974583_20151002_2142.extcsd Running:Repair extCSD...Z3X EasyJtag Software ver. 2.3.0.0 Skip loading eMMC Addon Firmware CMD Pullup Level:1753 mVCMD Active Level:2258 mV Box IO Level:2800 mV CLK Rate:14000 khz Writing... Done. i am select : rom1 => rom1(main user) preset : 4gb rom2 => rom2 preset : 2mb rom3 => rom3 preset : 2mb and write from support extcsd and my phone still no boot |
09-05-2016, 22:54 | #15 (permalink) |
Member: 1168485 Status: Offline Thanks Meter: 36 | and please bro if you can check and answer here http://forum.gsmhosting.com/vbb/f672...g-z3x-2129964/ |
