Y9 2019 need dump Ihave 2 y9 jkm-lx1 with dead emmc need work and good dump please |
i will share testd dump bro befor write dump bacup security this is important |
this dump tested https://drive.google.com/open?id=1d6..._CtUwjT1AXgqSb bacup your security write dump restor security |
1 Attachment(s) thx sir for dump but old emmc full dead link not work please chick it what firmware should i use after dump |
1 Attachment(s) flash cert check FLASH DEVICE REPLACE ILLEGAL i try many emmc same problem and link not work |
please any one can fix this |
can you help???jkm-lx1 1 Attachment(s) hi all gsm i have 4 pcs of yhis jkm-lx1 all dead by soft all nand damage no any backup so i change emms and write all above dump 1 by 1 all ok writing but after yhat phone in fastboot with redlines in it i dont know i use the same micron 64gb every thing is ok i talk and try many times in this condition imean fastboot i use eft to flash fastboot upgrade mode it working fastboot flash then go to upgrade mod automatically then update complate but again in fastboot with red line i test many firmwares operation inset emms in ufi or medusa pro the format it the program nand (have sevral dumps ) then install in board but allways in fastboot mode Attached Thumbnails i need your whatsapp nomber |
to restore new Huawey devices with new eMMC, you need flash ENGINEERING software to it I do not know full information how it work. But some people flash ENG Board software to repair device |
you just need security backup from old emmc and write dump in new emmc then write security backup which you take from old emmc done no need board firmware, board firmware is use in old chipset like 659 to downgrade device and change security like serial number, bla bla and for huawei id remove and more on |
try to copy from old emmc cid and write on new emmc but you cannot write cid on emmc 1.8 csd you need emmc 1.7 csd |
huawei devices not used CID |
if emmc totally cant read anymore, any solution for fix this issue? |
