Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Easy-Jtag
Old 05-16-2020, 13:06   #1 (permalink)
Member: 1129019
Sonork: first aider
Thanks Meter: 16
Z3x Easy Jtag cant detect emmc on good board
hi sir .good evening .pls help on my z3x easy jtag.i wotn detect any emmc .i have Oppo A3s here that has passcode problem but it wont detect emmc i am using Gpg adoptor
[IMG][/IMG]
here is the logs always like this .even i have put resistors
[IMG][/IMG]
Old 05-16-2020, 14:48   #2 (permalink)
Member: 13148
Thanks Meter: 1,588
Check voltage, check connection, try to use hipower mode with modded adapter
Old 05-17-2020, 03:27   #3 (permalink)
Member: 1129019
Sonork: first aider
Thanks Meter: 16
hi sir .thank you for your reply.you mean i will not use adoptor and connect this point from box to direct board ?
Old 05-17-2020, 09:47   #4 (permalink)
Member: 13148
Thanks Meter: 1,588
adapter only need for convert 5v from USB conector to get 2,8 and 1,8 voltage for isp connection
hi power mode not need 1,8v and 2,8v wires - only D_0/CMD/CLK, GND and need power device from usb charger or (battary + press power button)
"Hi power CLK mode" need 4 wires CLK (for old box) and "hi-power" settings at software
The Following User Says Thank You to layder For This Useful Post:
Old 05-18-2020, 08:18   #5 (permalink)
Member: 1129019
Sonork: first aider
Thanks Meter: 16
thank you for your reply sir oppoA3s passcode is now removed
eMMC CID : 150100514536334D42068821AA57B526
eMMC CSD : D02701320F5903FFF6DBFFEF8E40400C
eMMC Manufacturer ID: 0015 , OEM ID: 0100
eMMC Date: 11/2018 Rev.0x6
eMMC NAME: QE63MB , S/N: 2283907671
eMMC NAME (HEX): 514536334D42
IC Name: Samsung , KMQE60013M-B318/16GB @BGA221
EMMC ROM1 (Main User Data) Capacity: 14910 MB , 0x1D1F000 pages , 0x3A3E00000 bytes
EMMC ROM2 (Boot Partition 1) Capacity: 4096 kB
EMMC ROM3 (Boot Partition 2) Capacity: 4096 kB
EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 kB
EMMC RPMB is programmed and written 14564 times
EMMC Permanent Write Protection: No
EMMC Temporary Write Protection: No
EMMC Password Locked: No
Extended CSD rev 1.8 (MMC 5.1)
Boot configuration [PARTITION_CONFIG: 0x38] Boot from:ROM1 (Main User Area)
Boot bus config [177]: 0x00 , width 1bit , Partition config [179]: 0x38.
H/W reset function [RST_N_FUNCTION]: 0x01
High-capacity WP group size [HC_WP_GRP_SIZE: 0x00004000]
Partitioning Support [PARTITIONING_SUPPORT]: 0x07
Device support partitioning feature
Device can have enhanced tech.
Partitioning Setting [PARTITION_SETTING_COMPLETED]: 0x00
Found valid GPT with protective MBR; using GPT.
Real (Hardware) Disk/Image size: 1D1F000 sectors 14.6 GiB
Soft (Partitioned) Disk/Image size: 1D1EFBC sectors 14.6 GiB
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Logical sector size: 0x200 bytes ,First/Last usable sector: 34,30535646
Partition info successfully found
------ Android information ------
Detected (Android Userdata) USERDATA : 0x0158000000 (9.184GB)
Erasing...
Done.
Detected (Android Cache)) CACHE : 0x001FB00000 (256.0MB)
Erasing...
Done.
Done.
Running:Format FRP Partition...
Z3X EasyJtag Software ver. 3.6.2.0
Loading eMMC GEN1 Firmware... IO: 2800 mV
Box S/N: 07FFA01D5E51D525, ,FW Ver.: 01.63
CMD Pullup Level:2031 mV
CMD Active Level:2681 mV
Box IO Level:2800 mV
CLK Rate:3000 kHz
Bus Width:1bit,SDR
HiPower mode is off!
---------- eMMC Device Information ----------
Formatting FRP...
Detected LINUX(Android) CACHE : 0x001FB00000 (256.0MB) , formatting...
Done.
Detected LINUX(Android) CONFIG : 0x002FC80000 (32.0KB) formatting...
Done.
Detected LINUX(Android) USERDATA : 0x0158000000 (9.184GB) , formatting...
Done.
Done.
Done.
Page generated in 0.24974 seconds with 8 queries
