12-31-2013, 05:15 | #1 (permalink) |
No Life Poster Join Date: Mar 2012 Location: gsm world
Member: 1741973 Status: Offline Thanks Meter: 115 | z3x easy jtag card not found All the driver installed correctly booth win 7 and xp sp3 OS |
01-02-2014, 16:24 | #2 (permalink) | |
Freak Poster Join Date: Dec 2013
Member: 2085703 Status: Offline Thanks Meter: 14 | Quote:
i have same problem i open box clean card and resold jack but do it on your risk worranty void | |
The Following User Says Thank You to accusoft For This Useful Post: |
06-25-2015, 10:01 | #10 (permalink) |
Freak Poster Join Date: Jan 2014 Location: ADUM PZ,KUMASI
Member: 2117988 Status: Offline Sonork: 100.1667932 Thanks Meter: 44 | [QUOTE=chmsc_ELX;9987235]What should I do for this new box z3x easy jtag? card not found in shell, when I open or run the software always giving error after the firmware of the box updating. Updating ok, error comes and always said That my smart card is not a z3x smart card. Box can regestered successfully, when I tried to press the show card info the result is error card not found. I run the dianostic tool of easy jtag, only the box can be seen on the. Logs. Smart card not found... All the driver installed correctly booth win 7 and xp sp3 OS the card has lost contact with the tray so remove the card and place it back |
08-22-2015, 11:45 | #11 (permalink) |
Junior Member Join Date: May 2012
Member: 1763555 Status: Offline Thanks Meter: 2 | Thanks it work I just update easy jtag to latest version but i got problem to download its support file. card not detected. Then i found what Hendry umar suggested woks for me. Make sure you're connect to internet then run Hardware Wizard from shell. it done. |
03-20-2018, 13:31 | #13 (permalink) |
Insane Poster Join Date: Feb 2003 Location: Brasil Age: 53
Member: 22054 Status: Offline Thanks Meter: 8 | I'm facing same problem: I was Jtag firs generation and buy a the new one 2° gen, but I cant update and still no use new device. When run wizard just "card info" is enable. When try open Jtag says: "You have no required activation card.... |
03-25-2018, 11:08 | #15 (permalink) | |
Member: 22054 Status: Offline Thanks Meter: 8 | Quote:
The problem is that old Easy Jtag use a Sim card different size of new one. I had to open my box (loose warranty) to fit sim card as well. I confess I'm a little frustrated with z3x team, they could at least use same size jacket sim card. The other problem is the support, take long time to answer... | |
The Following User Says Thank You to dbfonseca For This Useful Post: |
