07-11-2019, 13:53 | #1 (permalink) |
No Life Poster Join Date: Apr 2016 Location: B A N G L A D E S H
Member: 2556542 Status: Offline Thanks Meter: 1,790 | samsung j100h after flash dead and after write dump file no downld mode final solutio Code: Setting frequence to 21 MHz CMD Pullup Level: 2083 mV CMD Active Level: 2371 mV EMMC Device Information : EMMC CID: 90014A48344732621101D700B4E922DA EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: D700B4E9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_D700B4E9_20190711_183513.extcsd EMMC Init completed. Scanning soft partitions Partition table not found Setting frequence to 21 MHz CMD Pullup Level: 2083 mV CMD Active Level: 2371 mV EMMC Device Information : EMMC CID: 90014A48344732621101D700B4E922DA EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: D700B4E9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_D700B4E9_20190711_183621.extcsd EMMC Init completed. Operation: Universal Factory Format Please, wait ... Successfully Setting frequence to 21 MHz CMD Pullup Level: 2083 mV CMD Active Level: 2382 mV EMMC Device Information : EMMC CID: 90014A48344732621101D700B4E922DA EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: D700B4E9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_D700B4E9_20190711_183651.extcsd EMMC Init completed. Operation: Changing GP sizes (test mode) ... GP1 size: 0 MB , WR_REL: 1 , ENH 0 GP2 size: 0 MB , WR_REL: 1 , ENH 0 GP3 size: 0 MB , WR_REL: 1 , ENH 0 GP4 size: 0 MB , WR_REL: 1 , ENH 0 Zero sizes. This may damage your eMMC Do you want to continue? HW_PART error. Reason: Card already partitioned Error: Security_CryptValidate fail Setting frequence to 21 MHz CMD Pullup Level: 2093 mV CMD Active Level: 2382 mV EMMC Device Information : EMMC CID: 90014A48344732621101D700B4E922DA EMMC CSD: D07F01320F5903FFFFFFFFEF8A4040DA EMMC Manufacture : SKHYNIX , EMMC NAME: H4G2b , HEX: 483447326200 , S/N: D700B4E9 , rev. 0x01 EMMC Manufacture ID: 0x90 , OEM ID: 0x4A , Device Type: BGA (Discrete embedded) , Date: 2/2015 EMMC ROM 1 (Main User Data) Capacity: 3728 MB (0000E9000000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) Counter: 0 , Response: Clean EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.6 (MMC 4.5, MMC 4.51) Boot configuration [PARTITION_CONFIG]: 0x08 , Boot from: ROM2 (Boot partition 1) Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x00, RST_n signal is temporarily disabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x01 Backup saved: H4G2b_D700B4E9_20190711_183729.extcsd EMMC Init completed. Operation: Writing all eMMC Regions... Operation: Writing BootConfig ... Reg: 179 Value: 0x08 Reg: 177 Value: 0x00 Reg: 162 Value: 0x00 Done Writing to: ROM2 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_ROM2_H4G2b_2165950698_00000000_00400000.bin eMMC switching to ROM2 Writing partition... Done writing partition. Write speed: 333.18 KB/s Writing to: ROM3 , start: 0x000000000000 , size: 0x000000400000 Filename: EMMC_ROM3_H4G2b_2165950698_00000000_00400000.bin eMMC switching to ROM3 Writing partition... Done writing partition. Write speed: 333.88 KB/s Writing to: ROM1 , start: 0x000000000000 , size: 0x000010000000 Filename: EMMC_ROM1_H4G2b_2165950698_00000000_10000000.bin eMMC switching to ROM1 Writing partition... Done writing partition. Write speed: 511.28 KB/s All done time: [00:08:59:776] |
