10-19-2018, 11:03 | #1 (permalink) |
Junior Member Join Date: Sep 2018 Location: FRANCE
Member: 2865074 Status: Offline Thanks Meter: 0 | Z3X Easy Jyag Plus .bin file Problem I tested on several samsung models with different eMMC sizes, setting the "Preset" field according to these sizes ... and I always get a 4 GB .bin file. Could someone tell me what I'm doing wrong? Thank you. |
10-19-2018, 14:24 | #2 (permalink) | |
Product Supporter Join Date: Jun 2002 Location: Belarus Age: 47
Member: 13148 Status: Offline Thanks Meter: 2,948 | Quote:
use NTFS | |
The Following 2 Users Say Thank You to layder For This Useful Post: |
10-20-2018, 18:28 | #5 (permalink) |
Member: 2865074 Status: Offline Thanks Meter: 0 | Thank you but that's not it ... My hard drives are in NTFS. I even changed computers and same problem. In EasyJtag Tool, tab JTAG Tool, I want to make a dump of the ROM1 indicated at 16 GB. I set the "Preset" field to 16 GB. At the end of the operation, the dump .bin file is only 4 GB. Is it possible that there is a bug in the program or the box? Is there any manipulation to reset the box? Thank you in advance. |
10-20-2018, 19:49 | #6 (permalink) | |
Please post screenshot of you actions and log of program. We cannot see problem at you messages. We need to see what you do. | |
10-23-2018, 11:27 | #9 (permalink) |
Member: 2865074 Status: Offline Thanks Meter: 0 | OK, i will try that with google drive That's what I'm told "Upload of file failed. " or "You must have 10 posts in order to post links. Your current post count is 6." So, I'll post screenshots when I count 10 posts... Last edited by layder; 10-23-2018 at 22:19. Reason: merge posts |
10-25-2018, 15:49 | #11 (permalink) |
Member: 2865074 Status: Offline Thanks Meter: 0 | https://drive.google.com/open?id=1l3...uiovgaE4mlRud9 https://drive.google.com/file/d/1aI_...ew?usp=sharing The phone memory is 7.3 GB but my dump is not only 4 GB. I tested other devices whose memory is 16 GB, but in the end the dump is always 4 GB. |
10-25-2018, 23:25 | #12 (permalink) | |
EasyJTAG Plus - is a software, also know as "eMMC Tool Shuite", named "EasyJTAG plus" at z3x shell But your screenshots - from EasyJTAG classic software, and JTAG tab. We will check JTAG tab and save files from it. JTAG is rarely used at the modern phones. Now we use eMMC ISP connection or work with desoldered eMMC chip at socket | |
The Following User Says Thank You to layder For This Useful Post: |
