09-11-2018, 11:46 | #1 (permalink) |
Major Poster Join Date: Jan 2016 Location: iraq-baghdad
Member: 2510651 Status: Offline Thanks Meter: 13 | z3x jtag sm-j250f repair dead boot sulotion i have j250f and after flash is dead !! and i tried to repair it by z3x jtag and this is the log ? and its say all done but the device still dead any help Setting frequence to 21 Mhz CMD Pullup Level: 1990 mV CMD Active Level: 2330 mV EMMC Device Information : EMMC CID: 150100515831334D4200BCA0D44035AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: BCA0D440 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_BCA0D440_20180911_113033.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) Partition: ddr, [000000500000 - 000000508000], size: 000000008000 (32.0 KB) Partition: limits, [000000508000 - 000000510000], size: 000000008000 (32.0 KB) Partition: aboot, [000000510000 - 000000710000], size: 000000200000 (2.00 MB) Partition: rpm, [000000710000 - 000000790000], size: 000000080000 (512. KB) Partition: tz, [000000790000 - 000000990000], size: 000000200000 (2.00 MB) Partition: hyp, [000000990000 - 000000A10000], size: 000000080000 (512. KB) Partition: devcfg, [000000A10000 - 000000A50000], size: 000000040000 (256. KB) Partition: fsg, [000000A50000 - 000000D50000], size: 000000300000 (3.00 MB) Partition: sec, [000000D50000 - 000000D54000], size: 000000004000 (16.0 KB) Partition: keymaster, [000000D54000 - 000000DD4000], size: 000000080000 (512. KB) Partition: cmnlib, [000000DD4000 - 000000E14000], size: 000000040000 (256. KB) Partition: cmnlib64, [000000E14000 - 000000E54000], size: 000000040000 (256. KB) Partition: lksecapp, [000000E54000 - 000000ED4000], size: 000000080000 (512. KB) Partition: apdp, [000000ED4000 - 000000F14000], size: 000000040000 (256. KB) Partition: msadp, [000000F14000 - 000000F54000], size: 000000040000 (256. KB) Partition: pad, [000000F54000 - 000001000000], size: 0000000AC000 (688. KB) Partition: modemst1, [000001000000 - 000001300000], size: 000000300000 (3.00 MB) Partition: modemst2, [000001300000 - 000001600000], size: 000000300000 (3.00 MB) Partition: param, [000001600000 - 000002000000], size: 000000A00000 (10.0 MB) Partition: efs, [000002000000 - 000002E00000], size: 000000E00000 (14.0 MB) Partition: boot, [000002E00000 - 000004E00000], size: 000002000000 (32.0 MB) Partition: recovery, [000004E00000 - 000006E00000], size: 000002000000 (32.0 MB) Partition: bota, [000006E00000 - 000007500000], size: 000000700000 (7.00 MB) Partition: fota, [000007500000 - 000007A00400], size: 000000500400 (5.00 MB) Partition: backup, [000007A00400 - 000007FFF000], size: 0000005FEC00 (6.00 MB) Partition: fsc, [000007FFF000 - 0000082FF000], size: 000000300000 (3.00 MB) Partition: ssd, [0000082FF000 - 000008301000], size: 000000002000 (8.00 KB) Partition: persist, [000008301000 - 00000A301000], size: 000002000000 (32.0 MB) Partition: persistent, [00000A301000 - 00000A381000], size: 000000080000 (512. KB) Partition: steady, [00000A381000 - 00000A781000], size: 000000400000 (4.00 MB) Partition: keystore, [00000A781000 - 00000A801000], size: 000000080000 (512. KB) Partition: config, [00000A801000 - 00000A809000], size: 000000008000 (32.0 KB) Partition: mota, [00000A809000 - 00000A889000], size: 000000080000 (512. KB) Partition: dpo, [00000A889000 - 00000A8C9000], size: 000000040000 (256. KB) Partition: mdtp, [00000A8C9000 - 00000A8D9000], size: 000000010000 (64.0 KB) Partition: dip, [00000A8D9000 - 00000A9D9000], size: 000000100000 (1.00 MB) Partition: oem, [00000A9D9000 - 00000A9E9000], size: 000000010000 (64.0 KB) Partition: mcfg, [00000A9E9000 - 00000ADE9000], size: 000000400000 (4.00 MB) Partition: dsp, [00000ADE9000 - 00000BDE9000], size: 000001000000 (16.0 MB) Partition: modem, [00000BDE9000 - 000011980000], size: 000005B97000 (91.5 MB) Partition: apnhlos, [000011980000 - 000013580000], size: 000001C00000 (28.0 MB) Partition: reserved2, [000013580000 - 000013800000], size: 000000280000 (2.50 MB) Partition: system, [000013800000 - 0000E5000000], size: 0000D1800000 (3.27 GB) Partition: cache, [0000E5000000 - 0000F1800000], size: 00000C800000 (200. MB) Partition: hidden, [0000F1800000 - 0000F5400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000F5400000 - 000747BFBE00], size: 0006527FBE00 (25.2 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J250F Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 7.1.1 Firmware version = NMF26X.J250FXWU2ARC6 Firmware date = Fri Mar 16 15:05:26 KST 2018 Setting frequence to 21 Mhz Error: First select the Pit-file CMD Pullup Level: 1980 mV CMD Active Level: 2330 mV EMMC Device Information : EMMC CID: 150100515831334D4200BCA0D44035AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: BCA0D440 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_BCA0D440_20180911_113044.extcsd EMMC Init completed. Opening file: J2Y18LTE_MEA_OPEN.pit Pit: J2Y18LTE_MEA_OPEN.pit Entry count: 52 The size of the last section has been updated BL_J250FXWU2ARC6_CL13211865_QB17352985_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: aboot.mbn sbl1.mbn rpm.mbn tz.mbn devcfg.mbn non-hlos.bin cmnlib.mbn keymaster.mbn lksecapp.mbn sec.dat apdp.mbn msadp.mbn Setting frequence to 21 Mhz CMD Pullup Level: 1969 mV CMD Active Level: 2330 mV EMMC Device Information : EMMC CID: 150100515831334D4200BCA0D44035AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: BCA0D440 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_BCA0D440_20180911_113250.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: devcfg.mbn Unpacking file: sec.dat Unpacking file: keymaster.mbn Unpacking file: cmnlib.mbn Unpacking file: lksecapp.mbn Unpacking file: apdp.mbn Unpacking file: msadp.mbn Unpacking file: non-hlos.bin Partition name: SBL1 Filename: sbl1.mbn , Offset: 000000400000 , filesize: 380100 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 460.82 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000000510000 , filesize: 1179272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 883.03 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000000710000 , filesize: 218656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 845.14 KB/s Partition name: TZ Filename: tz.mbn , Offset: 000000790000 , filesize: 1572352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 882.41 KB/s Partition name: DEVCFG Filename: devcfg.mbn , Offset: 000000A10000 , filesize: 94428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 792.86 KB/s Partition name: SEC Filename: sec.dat , Offset: 000000D50000 , filesize: 692 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 69.04 KB/s Partition name: KEYMASTER Filename: keymaster.mbn , Offset: 000000D54000 , filesize: 259032 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 851.79 KB/s Partition name: CMNLIB Filename: cmnlib.mbn , Offset: 000000DD4000 , filesize: 238496 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 861.38 KB/s Partition name: LKSECAPP Filename: lksecapp.mbn , Offset: 000000E54000 , filesize: 270944 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 829.94 KB/s Partition name: APDP Filename: apdp.mbn , Offset: 000000ED4000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 680.50 KB/s Partition name: MSADP Filename: msadp.mbn , Offset: 000000F14000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 709.13 KB/s Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000011980000 , filesize: 25401088 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 871.96 KB/s Writing BootConfig ... Reg: 179 Value: 0x00 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [00:00:47:156] Setting frequence to 21 Mhz CMD Pullup Level: 1980 mV CMD Active Level: 2330 mV EMMC Device Information : EMMC CID: 150100515831334D4200BCA0D44035AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: BCA0D440 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_BCA0D440_20180911_114804.extcsd EMMC Init completed. Scanning soft partitions GPT header is found and is valid Partition: sbl1, [000000400000 - 000000480000], size: 000000080000 (512. KB) Partition: sbl1bak, [000000480000 - 000000500000], size: 000000080000 (512. KB) Partition: ddr, [000000500000 - 000000508000], size: 000000008000 (32.0 KB) Partition: limits, [000000508000 - 000000510000], size: 000000008000 (32.0 KB) Partition: aboot, [000000510000 - 000000710000], size: 000000200000 (2.00 MB) Partition: rpm, [000000710000 - 000000790000], size: 000000080000 (512. KB) Partition: tz, [000000790000 - 000000990000], size: 000000200000 (2.00 MB) Partition: hyp, [000000990000 - 000000A10000], size: 000000080000 (512. KB) Partition: devcfg, [000000A10000 - 000000A50000], size: 000000040000 (256. KB) Partition: fsg, [000000A50000 - 000000D50000], size: 000000300000 (3.00 MB) Partition: sec, [000000D50000 - 000000D54000], size: 000000004000 (16.0 KB) Partition: keymaster, [000000D54000 - 000000DD4000], size: 000000080000 (512. KB) Partition: cmnlib, [000000DD4000 - 000000E14000], size: 000000040000 (256. KB) Partition: cmnlib64, [000000E14000 - 000000E54000], size: 000000040000 (256. KB) Partition: lksecapp, [000000E54000 - 000000ED4000], size: 000000080000 (512. KB) Partition: apdp, [000000ED4000 - 000000F14000], size: 000000040000 (256. KB) Partition: msadp, [000000F14000 - 000000F54000], size: 000000040000 (256. KB) Partition: pad, [000000F54000 - 000001000000], size: 0000000AC000 (688. KB) Partition: modemst1, [000001000000 - 000001300000], size: 000000300000 (3.00 MB) Partition: modemst2, [000001300000 - 000001600000], size: 000000300000 (3.00 MB) Partition: param, [000001600000 - 000002000000], size: 000000A00000 (10.0 MB) Partition: efs, [000002000000 - 000002E00000], size: 000000E00000 (14.0 MB) Partition: boot, [000002E00000 - 000004E00000], size: 000002000000 (32.0 MB) Partition: recovery, [000004E00000 - 000006E00000], size: 000002000000 (32.0 MB) Partition: bota, [000006E00000 - 000007500000], size: 000000700000 (7.00 MB) Partition: fota, [000007500000 - 000007A00400], size: 000000500400 (5.00 MB) Partition: backup, [000007A00400 - 000007FFF000], size: 0000005FEC00 (6.00 MB) Partition: fsc, [000007FFF000 - 0000082FF000], size: 000000300000 (3.00 MB) Partition: ssd, [0000082FF000 - 000008301000], size: 000000002000 (8.00 KB) Partition: persist, [000008301000 - 00000A301000], size: 000002000000 (32.0 MB) Partition: persistent, [00000A301000 - 00000A381000], size: 000000080000 (512. KB) Partition: steady, [00000A381000 - 00000A781000], size: 000000400000 (4.00 MB) Partition: keystore, [00000A781000 - 00000A801000], size: 000000080000 (512. KB) Partition: config, [00000A801000 - 00000A809000], size: 000000008000 (32.0 KB) Partition: mota, [00000A809000 - 00000A889000], size: 000000080000 (512. KB) Partition: dpo, [00000A889000 - 00000A8C9000], size: 000000040000 (256. KB) Partition: mdtp, [00000A8C9000 - 00000A8D9000], size: 000000010000 (64.0 KB) Partition: dip, [00000A8D9000 - 00000A9D9000], size: 000000100000 (1.00 MB) Partition: oem, [00000A9D9000 - 00000A9E9000], size: 000000010000 (64.0 KB) Partition: mcfg, [00000A9E9000 - 00000ADE9000], size: 000000400000 (4.00 MB) Partition: dsp, [00000ADE9000 - 00000BDE9000], size: 000001000000 (16.0 MB) Partition: modem, [00000BDE9000 - 000011980000], size: 000005B97000 (91.5 MB) Partition: apnhlos, [000011980000 - 000013580000], size: 000001C00000 (28.0 MB) Partition: reserved2, [000013580000 - 000013800000], size: 000000280000 (2.50 MB) Partition: system, [000013800000 - 0000E5000000], size: 0000D1800000 (3.27 GB) Partition: cache, [0000E5000000 - 0000F1800000], size: 00000C800000 (200. MB) Partition: hidden, [0000F1800000 - 0000F5400000], size: 000003C00000 (60.0 MB) Partition: userdata, [0000F5400000 - 000747BFBE00], size: 0006527FBE00 (25.2 GB) GPT header successfully parsed Get firmware version Brand = samsung Manufacturer = samsung Model = SM-J250F Phone platform = msm8937 CPU Abi = armeabi-v7a Android release = 7.1.1 Firmware version = NMF26X.J250FXWU2ARC6 Firmware date = Fri Mar 16 15:05:26 KST 2018 COMBINATION_FAC_FA71_J250FXXU2ARD2_FAC2ARD2_CL1277 9810_QB17931135_REV00_user_mid_noship_MULTI_CERT.t ar.md5 The list of files in the firmware: aboot.mbn sbl1.mbn rpm.mbn tz.mbn devcfg.mbn non-hlos.bin cmnlib.mbn keymaster.mbn lksecapp.mbn sec.dat apdp.mbn msadp.mbn boot.img recovery.img system.img.ext4 persist.img.ext4 modem.bin adspso.bin j2y18lte_mea_open.pit cache.img.ext4 File: sbl1.mbn - skip, as it has already been added File: aboot.mbn - skip, as it has already been added File: rpm.mbn - skip, as it has already been added File: tz.mbn - skip, as it has already been added File: devcfg.mbn - skip, as it has already been added File: sec.dat - skip, as it has already been added File: keymaster.mbn - skip, as it has already been added File: cmnlib.mbn - skip, as it has already been added File: lksecapp.mbn - skip, as it has already been added File: apdp.mbn - skip, as it has already been added File: msadp.mbn - skip, as it has already been added File: non-hlos.bin - skip, as it has already been added BL_J250FXWU2ARG4_CL13363106_QB19005161_REV00_user_ low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: aboot.mbn sbl1.mbn rpm.mbn tz.mbn devcfg.mbn non-hlos.bin cmnlib.mbn keymaster.mbn lksecapp.mbn sec.dat apdp.mbn msadp.mbn AP_J250FXWU2ARG4_CL13363106_QB19005161_REV00_user_ low_ship_MULTI_CERT_meta.tar.md5 The list of files in the firmware: boot.img recovery.img system.img.ext4 persist.img.ext4 userdata.img.ext4 meta-data/ meta-data/fota.zip CP_J250FXWU2ARF3_CP10046862_CL13363106_QB18730722_ REV00_user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: modem.bin adspso.bin CSC_OXE_J250FOXE2ARG5_CL13363106_QB19111584_REV00_ user_low_ship_MULTI_CERT.tar.md5 The list of files in the firmware: j2y18lte_mea_open.pit cache.img.ext4 hidden.img.ext4 Setting frequence to 21 Mhz CMD Pullup Level: 1969 mV CMD Active Level: 2330 mV EMMC Device Information : EMMC CID: 150100515831334D4200BCA0D44035AE EMMC CSD: D02701320F5903FFF6DBFFEF8E40400C EMMC Manufacture : SAMSUNG , EMMC NAME: QX13MB , HEX: 515831334D42 , S/N: BCA0D440 , rev. 0x00 EMMC Manufacture ID: 0x15 , OEM ID: 0x00 , Device Type: BGA (Discrete embedded) , Date: 3/2018 EMMC ROM 1 (Main User Data) Capacity: 29820 MB (000747C00000) EMMC ROM 2/3 (Boot Partition 1/2) Capacity: 4096 KB (000000400000) EMMC RPMB (Replay Protected Memory Block) Capacity: 4096 KB (000000400000) EMMC Permanent Write Protection: No EMMC Temporary Write Protection: No Extended CSD Information : Extended CSD rev: 1.8 (MMC 5.1) Boot configuration [PARTITION_CONFIG]: 0x00 , Boot from: no boot Boot Bus Config: 0x00 , width 1bit H/W Reset Function [RST_N_FUNCTION]: 0x01, RST_n signal is permanently enabled Supported partition features [PARTITIONING_SUPPORT]: 0x07 Device supports partitioning features Device can have enhanced technological features in partitions and user data area Device can have extended partitions attribute Partition Settings [PARTITION_SETTING_COMPLETED]: 0x00 Backup saved: QX13MB_BCA0D440_20180911_114909.extcsd EMMC Init completed. Operation: Write by vendor (Samsung) Creating GPT-partitioninig Writing PrimaryGPT at address: 000000000000 Writing BackupGPT at address: 000747BFBE00 Writing PIT at address: 000000004400 GPT-partitioning done Unpacking file: sbl1.mbn Unpacking file: aboot.mbn Unpacking file: rpm.mbn Unpacking file: tz.mbn Unpacking file: devcfg.mbn Unpacking file: sec.dat Unpacking file: keymaster.mbn Unpacking file: cmnlib.mbn Unpacking file: lksecapp.mbn Unpacking file: apdp.mbn Unpacking file: msadp.mbn Unpacking file: boot.img Unpacking file: recovery.img Unpacking file: persist.img.ext4 Unpacking file: adspso.bin Unpacking file: modem.bin Unpacking file: non-hlos.bin Unpacking file: system.img.ext4 Unpacking file: cache.img.ext4 Unpacking file: hidden.img.ext4 Unpacking file: userdata.img.ext4 Partition name: SBL1 Filename: sbl1.mbn , Offset: 000000400000 , filesize: 380108 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 417.20 KB/s Partition name: ABOOT Filename: aboot.mbn , Offset: 000000510000 , filesize: 1179232 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 837.15 KB/s Partition name: RPM Filename: rpm.mbn , Offset: 000000710000 , filesize: 218656 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 714.20 KB/s Partition name: TZ Filename: tz.mbn , Offset: 000000790000 , filesize: 1572352 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 815.86 KB/s Partition name: DEVCFG Filename: devcfg.mbn , Offset: 000000A10000 , filesize: 94428 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 593.99 KB/s Partition name: SEC Filename: sec.dat , Offset: 000000D50000 , filesize: 692 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 39.17 KB/s Partition name: KEYMASTER Filename: keymaster.mbn , Offset: 000000D54000 , filesize: 259032 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 664.32 KB/s Partition name: CMNLIB Filename: cmnlib.mbn , Offset: 000000DD4000 , filesize: 238496 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 710.65 KB/s Partition name: LKSECAPP Filename: lksecapp.mbn , Offset: 000000E54000 , filesize: 270944 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 729.71 KB/s Partition name: APDP Filename: apdp.mbn , Offset: 000000ED4000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 396.59 KB/s Partition name: MSADP Filename: msadp.mbn , Offset: 000000F14000 , filesize: 46272 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 497.43 KB/s Partition name: BOOT Filename: boot.img , Offset: 000002E00000 , filesize: 14289168 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 886.26 KB/s Partition name: RECOVERY Filename: recovery.img , Offset: 000004E00000 , filesize: 15868176 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 876.64 KB/s Partition name: PERSIST Filename: persist.img.ext4 , Offset: 000008301000 , filesize: 4743292 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 8 Done writing partition. Write speed: 865.55 KB/s Partition name: DSP Filename: adspso.bin , Offset: 00000ADE9000 , filesize: 16777216 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 872.04 KB/s Partition name: MODEM Filename: modem.bin , Offset: 00000BDE9000 , filesize: 63216384 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 886.02 KB/s Partition name: APNHLOS Filename: non-hlos.bin , Offset: 000011980000 , filesize: 25483008 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Done writing partition. Write speed: 880.54 KB/s Partition name: SYSTEM Filename: system.img.ext4 , Offset: 000013800000 , filesize: 2861843828 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 4210 Done writing partition. Write speed: 868.68 KB/s Partition name: CACHE Filename: cache.img.ext4 , Offset: 0000E5000000 , filesize: 63041756 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 16 Done writing partition. Write speed: 895.41 KB/s Partition name: HIDDEN Filename: hidden.img.ext4 , Offset: 0000F1800000 , filesize: 61022464 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 19 Done writing partition. Write speed: 888.69 KB/s Partition name: USERDATA Filename: userdata.img.ext4 , Offset: 0000F5400000 , filesize: 859848068 bytes eMMC switching to ROM1 Erasing partition... Writing partition... Sparse image found v.1.0 Total chunks: 286 Done writing partition. Write speed: 885.75 KB/s Writing BootConfig ... Reg: 179 Value: 0x00 Reg: 177 Value: 0x00 Reg: 162 Value: 0x01 Done All done time: [01:45:43:210] |
