Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > GPGWorkshop
Old 01-24-2013, 22:49   #1 (permalink)
Member: 345732
Exclamation Dongle problem! --- SOLVED ----
Hi,
I just purchased a GPGWorkshop dongle, and after i installed it, for the first time i encountred this problem (attached photo), the dongle serial number is ok but the firmware version is unavailable. Also when i run the gpgworkshop program it shows an error message.
Please advise.
Thank you
Old 01-25-2013, 06:19   #2 (permalink)
Member: 465933
gpgworkshop 4.0 does not start, hangs in the process
windows 8 / x64
GPGWorkshop new update ver 4.0
Old 02-06-2013, 15:22   #3 (permalink)
Member: 345732
I'm still waiting for a solution, can anyone help please? this is urgent
Old 02-06-2013, 17:05   #4 (permalink)
GPGWORKSHOP's Avatar
Member: 1544746
Sonork: 100.1579955
hi
is ok but the firmware version is unavailable - thats mean that dongle is updated
which windows ver do you use?
Old 02-06-2013, 17:13   #5 (permalink)
Member: 345732
Hi,
thank you for the reply
I'm using windows xp sp2, and now everytime i open the main program (gpgworkshop) it keeps telling card not found.
I gave it back to the reseller to test it and he encountered same problem, even him couldn't find out what was the problem, then he tested 2 other dongles then he found that even the other dongles show firmware unavailable.
Old 02-06-2013, 18:43   #6 (permalink)
Member: 1544746
Sonork: 100.1579955
hi
plz send me in PM dongle serial ill check is it updated
and if its possible contact me in sonork ill check over Teamviewer
Old 02-13-2013, 17:01   #7 (permalink)
Member: 345732
i need help here, plz it's urgent!
Old 02-13-2013, 19:46   #8 (permalink)
..::GsmHelp::..'s Avatar
Member: 230301
Sonork: 100.106864
contact me tomorow on yahoo messenger id liberul1979
The Following User Says Thank You to ..::GsmHelp::.. For This Useful Post:
Old 02-13-2013, 21:57   #9 (permalink)
Member: 345732
Thank you, but i can't tomorrow, cos i don't have the dongle with me, i returned it to the reseller to check it but he couldn't find out what the problem is! Anyway, before i get it back from the reseller i need to be sure if the problem is only with the drivers and not with the dongle itself.
So is the firmware version unavailable normal or there's something with the dongle?
If it's ok, i'll get it back from the reseller next week then i'll contact you to help with it.
Thank you
Old 02-19-2013, 17:26   #10 (permalink)
Member: 345732
now i tried it on another PC (after i got it back from the reseller yesterday, adn he couldn't find out what to do also) with windows 7 x86, and i'm getting "card not found" error!
I tried to uninstall the drivers, reboot and install them again, but no luck with it, i keep getting the same error can you please help me, it's really urgent i need to use software as soon as possible.
Old 02-19-2013, 20:59   #11 (permalink)
Member: 1544746
Sonork: 100.1579955
sure ill help you
download and install sonork
this my id Sonork: 100.1579955
contact me and ill solve your problem
also tel to reseller to contact me
The Following User Says Thank You to GPGWORKSHOP For This Useful Post:
Old 02-19-2013, 23:05   #12 (permalink)
Member: 345732
Originally Posted by GPGWORKSHOP View Post
sure ill help you
Thank you for the reply!
I'll contact you tomorrow noon.
Old 02-20-2013, 17:09   #13 (permalink)
Member: 345732
sure ill help you
problem solved thanks to GPGWORKSHOP thank you my friend! he was really helpful
Page generated in 0.31378 seconds with 11 queries
