03-05-2014, 11:10 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: UK
Member: 1544746 Status: Offline Sonork: 100.1579955 Thanks Meter: 4,822 | IPhone repair solution added! Phone – APPLE - IPHONE 3G – MICROPHONE NOT WORKING Phone – APPLE - IPHONE 4 – ESTART WHEN CHARGING & FAKE CHARGING Phone – APPLE - IPHONE 4 – AUDIO IC PAD Phone – APPLE - IPHONE 4 – BATTERY CONNECTOR Phone – APPLE - IPHONE 4 – BATTERY CONNECTOR SOLUTION! Phone – APPLE - IPHONE 4 – CAP WIFI Phone – APPLE - IPHONE 4 – CHARGE PROBLEM Phone – APPLE - IPHONE 4 – CHARGING AND USB SOLUTION Phone – APPLE - IPHONE 4 – CHARGING IC SHORTING Phone – APPLE - IPHONE 4 – CHARGING IC SHORTING2 Phone – APPLE - IPHONE 4 – CRACKED COILS Phone – APPLE - IPHONE 4 – FIND SHORT SOLUTION Phone – APPLE - IPHONE 4 – FULL SHORTING Phone – APPLE - IPHONE 4 – LCD CHIP MISSING Phone – APPLE - IPHONE 4 – LCD NASTY PROBLEM Phone – APPLE - IPHONE 4 – LOW OR NO WIFI SIGNAL FULL SOLUTION Phone – APPLE - IPHONE 4 – LOW SOUND ON SPEAKER Phone – APPLE - IPHONE 4 – MIC NOT WORKING Phone – APPLE - IPHONE 4 – MIC NOT WORKING THREAD Phone – APPLE - IPHONE 4 – MIC NOT WORKING THREAD2 Phone – APPLE - IPHONE 4 – MIC NOT WORKING THREAD3 Phone – APPLE - IPHONE 4 – NEED TO IDENTIFY THIS IC Phone – APPLE - IPHONE 4 – NO DISPLAY AFTER REHEAT Phone – APPLE - IPHONE 4 – NO POWER ON WITH BATTERY CONNECTED Phone – APPLE - IPHONE 4 – NO RINGTONE JUMPER Phone – APPLE - IPHONE 4 – NO SIGNAL PROBLEM JUST SERCHING AND NO SERVCE Phone – APPLE - IPHONE 4 – NO SOUND DURING CALL Phone – APPLE - IPHONE 4 – NOT CHARGING Phone – APPLE - IPHONE 4 – PCB FRONT Phone – APPLE - IPHONE 4 – PIECE Phone – APPLE - IPHONE 4 – REPAIRS Phone – APPLE - IPHONE 4 – RINGER PROBLEM Phone – APPLE - IPHONE 4 – SOLVED GREY WIFI ON WATER DAMAGE Phone – APPLE - IPHONE 4 – STOPS CHARGING Phone – APPLE - IPHONE 4 – U62 LIFTED BGA SOLDER PAD Phone – APPLE - IPHONE 4 – WEAK WIFI Phone – APPLE - IPHONE 4 – WIFI SOLUTION Phone – APPLE - IPHONE 4S – HARGING IC LOCATION Phone – APPLE - IPHONE 4S – A SMALL PART LOST Phone – APPLE - IPHONE 4S – AFTER WATER DAMAGE TURN ON ITSELF Phone – APPLE - IPHONE 4S – AUDIO U60 IC RABAL OR CHANGE Phone – APPLE - IPHONE 4S – BATT SHORT Phone – APPLE - IPHONE 4S – BATTERY JUMPER WAYS SOLUTION Phone – APPLE - IPHONE 4S – CAMERA SOLUTION Phone – APPLE - IPHONE 4S – CAMERA SOLUTION BY RIAJUL ISLAM Phone – APPLE - IPHONE 4S – CAMERA SOLUTION IC JUMPER Phone – APPLE - IPHONE 4S – ERROR SOLUTION Phone – APPLE - IPHONE 4S – ERROR SOLUTION2 Phone – APPLE - IPHONE 4S – FAKE CHARGING SOLUTION Phone – APPLE - IPHONE 4S - KEEPS SEARCHING AFTER SCREEN REPLACEMENT Phone – APPLE - IPHONE 4S – MIC NOT WORKING Phone – APPLE - IPHONE 4S – MIC PROBLEM ANY ONE SOLVED Phone – APPLE - IPHONE 4S – MISSING COMPONENT Phone – APPLE - IPHONE 4S – MISSING COMPONENTS Phone – APPLE - IPHONE 4S – MOTHERBOARD PMIC SHORT Phone – APPLE - IPHONE 4S – NETWORK LOW OR NO SIGNAL Phone – APPLE - IPHONE 4S – NETWORK WORKS ONLY IN 3G NETWORK ONLY Phone – APPLE - IPHONE 4S – NO BACKLIGHT ON LCD(SOLUTION) Phone – APPLE - IPHONE 4S – NO SIGNAL , SOLUTION Phone – APPLE - IPHONE 4S – PROXIMITY SENSOR Phone – APPLE - IPHONE 4S – REAR CAMERA TWO PARTS MISSING Phone – APPLE - IPHONE 4S – SHORT PIN 1 TO 4 Phone – APPLE - IPHONE 4S – SHORT SOLUTUON Phone – APPLE - IPHONE 4S – TOUCH SCREEN NOT RESPONDING Phone – APPLE - IPHONE 4S – USB SOLUTION Phone – APPLE - IPHONE 4S – WIFI CONNECTOR BROKE, PAD LIFTED Phone – APPLE - IPHONE 4S – WORKS WELL WITHIN CHARGER Phone – APPLE - IPHONE 5 – CHARGE IC IS DAMAGE HOW JUMPER Phone – APPLE - IPHONE 5 – CHARGING WAYS Phone – APPLE - IPHONE 5 – NO IMEI Phone – APPLE - IPHONE 5 – NO SERVICE AFTER POWER FLEX CHANGE Phone – APPLE - IPHONE 5 – NO SIM SOLUTION Phone – APPLE - IPHONE 5 – STRANGE PROBLEM Phone – APPLE - IPHONE 5 – WATER DAMAGED Phone – APPLE - IPHONE 5 – WHITE (GREY) VERTICAL STRIPES OR BLOCKS Phone – APPLE - IPHONE 5 – WITH MIC NOT WORKING |
The Following 5 Users Say Thank You to GPGWORKSHOP For This Useful Post: |
09-19-2015, 13:29 | #8 (permalink) |
Junior Member Join Date: Aug 2007
Member: 575757 Status: Offline Thanks Meter: 0 | To my understanding, you need to download program called GPGWORKSHOP, which is free. Then you need to buy dongle from them, which will give you access to their Repair DB through the program GPGWORKSHOP you installed. The initial list above is just the list of topics you will find there. Hope this helps |
