IQ Doctor iq-doctorbox |
05-28-2011, 11:04 | #1 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | --IQ Doctor Box--Problems and Solutions-- Error: Unsaft EFS Address, Please input the right format address and try again. Failed to auto format. Solution- Auto Format not supported ATM, search for good working same firmware and write it to your phone. Wr. |
The Following User Says Thank You to PASSIONATE_BOYS For This Useful Post: |
05-28-2011, 11:15 | #3 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Problem- Reading FileSystem info... Failed to read FS info. Solution- Need to full flash the phone with same firmware. Wr. |
05-28-2011, 11:19 | #4 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Problem- Nor Flash ID: 0000000000000000 Nand Flash ID: 0000000000000000 Nor Flash not found. Solution- Reflow heat on flash, if still doesn't works out change it. Wr. |
05-28-2011, 13:07 | #6 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Problem- Unsupport CPU, Please select another boot and retry again! Solution- Select another Boot version from "Boots" tab. Most of the times boot v3.952 works well, so set boot v3.952 as default. Wr. |
05-28-2011, 13:32 | #7 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Problem- It is sensing the pinout fast... D-=3 D+=0 BOOT set failure, continue to scan... Sense failure Solution- Keep pressing "0" or "*" button of your phone until the process is completed. Wr. |
05-29-2011, 11:27 | #8 (permalink) |
Member: 541591 Status: Offline Sonork: 100.1611509 Thanks Meter: 7,361 | Problem-Error while reading flash. Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast,please hold on the phone Power key RXD=13 TXD=14 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Nor Flash ID: 00EC240400000000 Nand Flash ID: 0000000000000000 Unknow NOR Flash. Solution- First try with Boot v3.1016, and still get error then Select "InternalRamBoot" option from "Boots" tab. Here is log after selelcting "InternalRamBoot"- Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast,please hold on the phone Power key RXD=13 TXD=14 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6253T Flash: NOR_K5N2833ATB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Reading Flash... Saved file to: I:\GPG Dragon\GNext-Diamond-S338-CREATONE53_K011E_2_MULTI_PCB01_GPRS_MT6253_S00.CRE ATONE_K011E_1_ZHM_MULTI All Done. Wr. Last edited by PASSIONATE_BOYS; 05-29-2011 at 11:36. |
IR between 6150 and IBM TP 600 | favdijck | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-15-2011 13:08 |
wt603 and .pkd | ARt | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 06-13-1999 19:18 |
