IQ Doctor iq-doctorbox |
03-25-2012, 06:51 | #1 (permalink) |
Freak Poster Join Date: Apr 2010 Location: Bangladesh
Member: 1292009 Status: Offline Sonork: 100.1586379 Thanks Meter: 802 | How to connect * use IQ Doctor with SpreadTrum CPU based handsets. Correct Steps to connect and work on a SpreadTrum CPU based handset: 1. First u need to read information of the handset. Go to “SpreadTrum” tab, select “ReadInfo”, select option according to CPU type. If you don't know the CPU boot type then you can try “Auto-USB”, “Auto-COM”, “6600L-USB*quot; or *quot;6600L-COM*quot; one-by-one. 2. Press “Start”. 3. Now you don't need to power on the phone in SPD handsets. It will automatically start sensing the pinouts. After finding the pinouts the phone will ask for usb drivers. SPD drivers are located under folder “SpreadTrum_USB_Driver”. If you have already installed the drivers 4. then system will not ask for drivers next time. After installing drivers, software will connect to your SpreadTrum handset and will read information which will be displayed on the bottom. 5. You can now read in it that which type is the CPU and flash memory of the handset. Example: CPU: SC6600E-xxxx Flash: NAND_xxxx Here the CPU type is 6600E and the memory type in NAND, so in this case you need to select the option “6600M/E/I-NAND” and then proceed further. 6. After you have selected the correct CPU type in the options, now you can start with Format, Read Flash, Write Flash, Repair IMEI, etc. |
The Following User Says Thank You to gsmsumon For This Useful Post: |
How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 06-08-2012 18:29 |
