Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > IQ Doctor
IQ Doctor iq-doctorbox
Old 07-11-2011, 09:37   #1 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
Tips>Problem>Solution> IQ Doctor Box
ERROR
"SPD USB TO SERIAL NOT FOUND"
Solution:
You need to install the USB drivers for SpreadTrum.
If already install than uninstall it first again install SPD the driver.
Old 07-11-2011, 09:38   #2 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Error: Unsaft EFS Address, Please input the right format address and try again.
Failed to auto format.
Solution
Try "Reset" option, If still problem than search 4 a same handset read the flashfile from that working set again write it back to the faulty set.
Old 07-11-2011, 09:40   #3 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Nor Flash ID: 0000000000000000
Nand Flash ID: 0000000000000000
Nor Flash not found.
Solution
First try to shake the flash ic at middle heat if still same then replace cpu.
Old 07-11-2011, 09:46   #4 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Read info is done.
CPU: SC6600R Flash: NOR_K5L6331CAA
Set FLASH Parameters...
Settings have been completed!
Reading FileSystem info...
Failed to read FS info.
Solution
Flash the set with same file or read flash from a working handset and then flash it to faulty handset.
Old 07-11-2011, 09:47   #5 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
FAILED TO RUN BOOTLOADER
Solution
Press and hold the * button and keep pressed untill all completed if still same shake the flash ic at middle heat.
Old 07-11-2011, 09:48   #6 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
FAILED TO RXD
Solution
Select 6600l-USB from mode list
Old 07-11-2011, 09:49   #7 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Nor Flash ID: 007F22F600000000
Read Hardware Information is
Get Project ID from phone...
ProjectID Not Found
Solution
Change the boot type to 3.952 if still same than shake the CPU at middle heat or change CPU
Old 07-11-2011, 09:51   #8 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
ERROR: MTK_DA_GET_FAT_INFO_NOT_FOUND
Solution
Try Boot "Ver. 3.1108" from Boot options, if still same than shake the flash ic at middle heat.
Old 07-11-2011, 09:51   #9 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Formatting Flash...
AutoFormat address: start=0x00E00000, size=0x00200000
Failed to format Flash...
Solution
Try with different Boots from list if still same then rehot flash chip than CPU
Old 07-11-2011, 09:52   #10 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Initializing...
DA_LIB_VER_3.2.0.7
It is sensing the pinout fast...
D-=4 D+=3
Searching commport...please wait...
Solution
Check connection with phone or connect from RX TX points from board if still same than rehot the CPU
Old 07-11-2011, 09:52   #11 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
NOR FLASH NOT FOUND
Solution
There is NAND flash Plz select NAND from Mode and use Boot 3.1108
Old 07-11-2011, 09:53   #12 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Initializing...
DA_LIB_VER_3.2.1.3
D-=3 D+=0
BOOT set failure, continue to scan...
Sense failure
Solution
Press and hold 0+Power button of your handset until process
Old 07-11-2011, 09:54   #13 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
Selected collating sequence not supported by the operating system
Solution
You need windows XP DISC
Go to Control Panel > Regional Language> Language> Install East language
Old 07-11-2011, 09:56   #14 (permalink)
SoniaTel's Avatar
Member: 1582197
Sonork: Not Use
ERROR
"Conjuction Error" while updating your box
SOLUTION
To fix this. you need to upgrade the firmware by using "Emmergency UpGrade" feature.
Disconnect IQ Doctor Box from USB, connect the main cable to IQ Doctor Box.
Now short the "+" and "-" wires of the main cable
Connect computer with USB to IQ Doctor Box.
Open the latest Box firmware Updater software forIQ Doctor Box. Press "ScanPort", Select your IQ Doctor Box comm port number, tick the "Exigency UpGrade" and press "UpGrade-BOX"
FLASH BOX WANTED!!!!!! J Wanted Products 9 07-14-2012 20:42
i WANT TO BUY NOKIA BOX !!! Eric Wanted Products 8 02-14-2011 12:23
NOKEY BOX FOR SALE - FULL Zorz Main Sales Section 0 12-05-2000 09:56
New NOKIA BOX - New Prices gsmEsteve Main Sales Section 0 12-03-2000 02:43
New Nokia BOX for you!!! gsmEsteve Main Sales Section 0 11-18-2000 16:09
Page generated in 0.33262 seconds with 11 queries
