Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Sony Ericsson > Old Ericsson Phones & Sony Phones > Sony
Old 10-29-2003, 16:26   #1 (permalink)
mourad_t's Avatar
Member: 26438
Lightbulb J7 imei 000000000000000, how to put original?
Hi
I have one J7 with imei 00000000.... I tried to unlock it, says Ok then return Simlock. I have CTE software I tried to set IMEI to original: still 0000... Can someone tell me what to do, or give me instruction to use CTE (phone on/off?....)
YhankS
Old 10-29-2003, 16:55   #2 (permalink)
Super Moderator
DrMobile's Avatar
Location: P A K I S T A N ___________________ ___Wahab_ul_Haq___ ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ
Member: 5932
I make:
1. pw (wap code)
2. power off phone and on
3.SLDefault - Clear all SIMLOCKs
4.FactoryReset
5.writeimei (real phone imei)
6.SLDefault
7.FactoryReset
And phone work fine.
P.S. For pw and writeimei
pw 12345678
writeimei 0x35 0x01 0x77 0x40 0x44 0x01 0x04 0x6
35 01 77 40 44 01 04 6
Old 10-31-2003, 23:03   #3 (permalink)
Member: 4695
Hi friend!
Ihave same problem to.
The J7 phone have this imei:
356FC2 F7 201F9F 0
bur first time have allways -0-
I tryed few solution, but can't help it.
I readed old topics and not found new idea.
I would like to please new solution or new link for eeprom repair and unlocking solution via cable, but now the phone still simlock.
After unlock via keybord the state does not change!
Thanks in advance
BR Keni
Old 11-01-2003, 00:04   #4 (permalink)
UHK
UHK's Avatar
Member: 13737
Sonork: 100.100725
yes you need to use sdefault and writeimei command
c old post
Old 11-01-2003, 09:01   #5 (permalink)
megone's Avatar
Member: 31594
FOR DR MOBILE
pls help me with sony j70 dead
software problem
i try to flash but my phone don t power on
how to revive?
thanks
Old 11-01-2003, 20:14   #6 (permalink)
Member: 4695
Originally posted by megone
FOR DR MOBILE
software problem
how to revive?
thanks
@megone
use the new flasher ans get back nvm area!
you can download from here
I solved my problem, removed leading 0 from wap code and voila
work fine everything.
BR Keni
Old 11-06-2003, 11:32   #7 (permalink)
Member: 20740
I need good nvm for j70...any one can send me link
Old 11-10-2003, 14:37   #8 (permalink)
patric's Avatar
Member: 8228
my problem that i had a sony j7 that have imei 0000 ; i try to repair it using cte => phone imei is ok ;
Phone now is unlocked and have original imei but it can't make a call!!!
when i tried to change some options in the phone menu its says always 'error' ...
help
EEPROM RESET: #*7337# How to recover ORIGINAL IMEI gsmbrands Samsung Hardware Repair Area 2 10-17-2009 14:16
:::::: REPAIR DAMAGED IMEI 12345xxxxx WITH RPL - HOW TO GET ORIGINAL IMEI HERE :::: GSMman187 Nokia Base Band 5 ( BB-5 ) 30 08-09-2009 06:58
M620 imei 000000000000000.how solution?? guo_xiaoguang UST Pro II 7 11-11-2008 18:21
How to put imei to pm? yoya Nokia Hardware & Hardware-Repair Area 1 06-14-2005 09:01
Page generated in 0.33064 seconds with 11 queries
