Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Old Ericsson Phones & Sony Phones > Sony
Old 07-06-2004, 18:18   #1 (permalink)
Member: 12612
Thanks Meter: 15
j70 dead after flash
Please help me with Sony J70.Phone was blocking (freezing) from time to time and I tryed to flash it. I've did that many times on other phones j70 without a problem.
On the end of flashing procedure flasher said "Checksum Error". I trayed to flash again but no success - phone was loosed comunication with PC.
Please any solution???
maybe a bootloader i erased but I am not shure.
Please help its a customer phone.
Old 07-10-2004, 12:21   #2 (permalink)
Member: 65365
Did you make a back up. If not did you note down the software version and SAT no of his original firmware. If yes try flashing it with a similar SAT no firmware.
If your answer to both the above thing is no than you are in for some trouble. Not that it cant be fixed, but you will have to spend quite some time on it.
You have to get a clean NVM file and a official firmware file and flash it. If the phone starts to boot very good if not try with a fullfalsh file. If that does not work you will have to keep trying with differnt NVM and firmware files. Dont use the same file again and again. From what I remeber the EEPROM will die after about 500 flashes.
Best of luck do post your result on the forum.
Old 03-05-2005, 14:22   #3 (permalink)
Member: 10679
Thanks Meter: 34
I have a J5 with the same problem - since then absolutely no communication with PC. How can it be solved?
6300 dead after flash 6233 dead after flash mobileZONE MXKEY Nokia Flasher and Unlocker (by Alim Hape) 4 03-27-2010 01:17
Dead 9210e Orange UK Dead after flashing :( PhantomGSM Trisha & Matrix Flasher 4 05-06-2009 12:02
Sony J70 deads after repair imei barvik Sony Ericsson Hardware Repair 0 03-24-2004 21:59
J70 dead after flash error Headmade Sony 0 08-21-2003 09:43
Page generated in 0.23051 seconds with 8 queries
