Need J70 IMEI Changer My J70 Phone IMEI all 0000000000000000000 and sim lock. All ready Try by Wap code & sim code. Can't open simlock. Please anybody link or IMEI Changer Software. Thanks Hamid |
You have solution for these problem Find link on the forum Use CteTerminal |
question Hi all! I have a question. What can I do, if I can enable or disable the CTE mode, but the CTE Terminal doesn't connect with my J70? I tried all methods (first power on the phone, then plug the service cable in, then click on "PLAY" ikon; or first time click on the ikon, then plug the powerd on phone to the service cable) but I received EEEEEEEEEEEEEEEEEEEEEEEE all the time. Before this, I could write a clean NVM because the phone was totally dead, and the warranty has been expired. Now the phone is alive, but the IMEI has been changed, and I want to restore the original value! How can I solve this problem? THX to all... |
Sorry about the mistakes (icon, powered...)! I forgot it: I have original SONY SERVICE CABLE. Can I repair my phone with it? THX |
Hi-hi! I solved the problem. I shorted the pin 3, and pin 8 to each other, started the cte terminal, powerd on the phone. Now the IMEI number and locks are good, but I still can't make any calls. It found the operator, and work fine, but no calls. How can I solve this? THX |
Nobody can help me to solve this "bug"? And I have an other problem with that phone: the battery can't live, just for 1 day. But before the has been dead, it was fine. |
See hardware or charger. |
i have problem i read wap code and use cte to change imei. i have dead j70 now phone power up (after flashing nvm and flash) but i have IMIEI 3556CCC02026917 and when i write in to cte (after connect, phone ready) pw 03340576 cte write ok but if i wanna use command WRITEIMEI or other, i have unknown command (i read my wapcode loger + calc sony j5). It is possible to read bad id?? i read something about that after read bad id i have bad wapcode..... I dont know what to do.....can anybody help me i read old topic but & nothing found. |
problem solved just need pw witout 0 |
i have this same problem and i am still findin it difficult to repair hope somebody will endevour to give a little lecture on the imei repair thanks |
