11-26-2002, 17:06 | #16 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [☾✫ ] Age: 58
Member: 8159 Status: Offline Thanks Meter: 98 | i repaired tue j7 phone not any problem special thanks to chuk 1. Calculate WAP code of the phone (Log reader + Code Maker). 2. Write correct NVM area *good.nvm (File -> open ->) (Flash3.exe). 3. In CTE Terminal (phone must be on): File -> Connect or push green arrow. When "Phone ready" message appears, You must enter : PW 12345678 - 12345678 - Your phone WAP code OK - CTE Terminal answer Power OFF and ON the phone. IF WAP code is correct, You'll get access to extended commands. SLDefault - Reset all locks (Sim,Net, Subnet etc.) OK FactoryReset writeimei 0x12 0x34 0x56 0x78 0x90 0x12 0x34 0x5 - 123456789012345 - 15 digits of IMEI OK SLDefault OK FactoryReset If You need to adjust LCD contrast, You can use : LCDcont - Get real value of the contrast (Default) xx 0 - CTE Terminal answer LCDcont xx 0 - Set xx value of the contrast (Default) OK |
12-24-2002, 02:05 | #20 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Bombay , India Age: 41
Member: 10543 Status: Offline Thanks Meter: 0 | hi ombossman , can u please tell me if it is the same cable used for flashing the nvm file and also for getting the codes ? and can u please give me a link where i can see the cable please |
12-24-2002, 11:10 | #21 (permalink) |
Member: 8159 Status: Offline Thanks Meter: 98 | @ simlockboy hi simlockboy i use standart made in china data cable i dont use special cablo some soft link here http://www.r00t.host.sk/ wbr Last edited by OMBOSSMAN; 12-24-2002 at 11:38. |
12-30-2002, 08:46 | #25 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Novi Sad, Serbia Age: 44
Member: 17193 Status: Offline Thanks Meter: 16 | pw xxxxxxxx??? Each time i type this command, the prog says "wrong command"... I revived a j6 by flashing it with full flash but now imei is in hex(?) something like 35d9880b... Is the wap code wrong or what??? ___________________ ***zero cool*** ___________________________ |
12-30-2002, 09:43 | #26 (permalink) |
No Life Poster Join Date: Dec 2001 Location: Ukraine Age: 46
Member: 7767 Status: Offline Thanks Meter: 3 | Try again calculate wap code. Connect this phone and read with logger. Write REAL imei from backside sticker, when logger ask it. Run calculator, choose this IMEI and read code in WAP section. |
12-30-2002, 10:09 | #27 (permalink) |
No Life Poster Join Date: Sep 2002 Location: ALGERIA
Member: 15439 Status: Offline Sonork: 100.43816 Thanks Meter: 52 | i read wap entered it and phone say ok ,but with cte always wrong command.i try step by step like it's explain but nothing .what's wrong please need help. thanks |
01-01-2003, 19:00 | #28 (permalink) |
No Life Poster Join Date: Apr 2001 Location: IN CASTLE Age: 46
Member: 3925 Status: Offline Thanks Meter: 22 | hi guys my phone is j70. turn on, enter pin code and freez. always restart. i'm flashing not help. how resolve my problem. this soft work in my problem. please help me thank you |
01-02-2003, 19:19 | #29 (permalink) |
Member: 17193 Status: Offline Thanks Meter: 16 | cte enabler This is how I've done it: Download cte enabler This is the cable . Connect (turned on) phone on DATA cable and start the prog. Now phone is in cte mode Disconnect cable and transform it in SERVICE type DO NOT switch the phone off!!! Connect service cable and start cte terminal Now you don't have to know the exact wap code, enter imei (explained above) and do the 'sldefault' thing (also explained, thx to Chuk & OMBOSSMAN) , and that should be it. Happy new year!!!!!!!!!! Last edited by ReviveR; 01-02-2003 at 19:27. |
V3xx no charge, no power | Colombia430 | Motorola Hardware Repair | 0 | 12-17-2009 23:42 |
gx 25 no charging, no power on but flash ok | the sorrow | Sharp | 4 | 08-29-2007 21:39 |
3310 no charging no current being drawn | bayleaf | Nokia Hardware & Hardware Repair | 3 | 03-09-2007 19:07 |
E770 no charge , no pc comunication | TRABEL | Motorola Hardware Repair | 6 | 02-06-2007 08:32 |
T28s No Charge, No Network, Dark Displey and no Light | Sultan | Sony Ericsson Hardware Repair | 2 | 05-15-2002 00:57 |
