04-21-2003, 11:51 | #1 (permalink) |
Insane Poster Join Date: Dec 2001 Location: Lithuania Age: 47
Member: 8009 Status: Offline Thanks Meter: 1 | Sony J70 unlock problem (001-01) I have problem with Sony J70 I get to unlock but hei is locked to unknown network 001 01 ??? i try to unlock with code but not sucefull (always OK > restarting and agin locked). i think somthing damage on it. Please any solutions to repair network locks. BTW: Imei is OK. |
05-08-2003, 07:03 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | @bacila Do you have IMEI like 000...000? Sound like your J have damaged NVM area. Hint - try to upload good NVM from other working phone or full flash image and repair IMEI after uploading! |
10-01-2004, 15:15 | #6 (permalink) |
Freak Poster Join Date: Aug 2003 Location: Romania Age: 53
Member: 37255 Status: Offline Thanks Meter: 3 | Yes CTE terminal is working 100%. Read instuction. 1. Calculate WAP code of the phone (Log reader + Code Maker). 2. Write correct NVM area *good.nvm (File -> open ->) (Flash3.exe). 3. In CTE Terminal (phone must be on): File -> Connect or push green arrow. When "Phone ready" message appears, You must enter : PW 12345678 - 12345678 - Your phone WAP code OK - CTE Terminal answer Power OFF and ON the phone. IF WAP code is correct, You'll get access to extended commands. SLDefault - Reset all locks (Sim,Net,Subnet etc.) OK FactoryReset writeimei 0x12 0x34 0x56 0x78 0x90 0x12 0x34 0x5- 123456789012345 - 15 digits of IME(350668 34 470923 3) OK SLDefault OK FactoryReset If You need to adjust LCD contrast, You can use : LCDcont - Get real value of the contrast (Default) xx 0 - CTE Terminal answer LCDcont xx 0 - Set xx value of the contrast (Default) OK If you need something I can send you on mail. BR Dans |
SONY J70 unlocking problem ???????/ | mark3 | Sony | 2 | 05-19-2005 10:34 |
Sony J70 buzzer problem | Porter | Sony Ericsson Hardware Repair | 9 | 03-16-2005 11:36 |
Sony J70 flash problem | golden_gate | Sony | 3 | 10-29-2003 02:28 |
Unkowne ver for sony J70 Unlocker what to do??? | maher_teamoo | Sony | 1 | 08-27-2002 20:54 |
SONY J70 unlocked-simlocked | melsoft | Sony | 2 | 08-16-2002 07:25 |
