GSM-Forum (https://forum.gsmhosting.com/vbb/)
-   Sony (https://forum.gsmhosting.com/vbb/f68/)
-   -   Sony Z5 Unlock -» Help (https://forum.gsmhosting.com/vbb/f68/sony-z5-unlock-help-133789/)
GsmCyber 03-25-2004 11:31
I have the logger+ calculator but i can't create a log :( i can't read the info phone...
Can someone give me another solution?!
Regards
gjurobrod 03-25-2004 12:54
1 Attachment(s)
Hi,I can send you flasher,working 100%,you have to use external power cable.
i_seeque 03-25-2004 13:02
@GSMCyber
U must first check the correct pinouts of the cable you have got. Logger works perfectly. Let me know which cable u r using for Logger. You may have to modify your cable, i suppose.
Uvedovle 03-25-2004 13:04
Dowload looger http://www.movilcom.org/software/z5logger.zip.zip and send me log.
Power on phone, plug cable,select comport and read.
The soft will ask you the imei, put it and send me the log.
Regards
GsmCyber 03-25-2004 19:32
[email protected]
thankx a lot
@ Uvedovle
I can't read with logger :( thankx anyway...
Uvedovle 03-26-2004 13:39
Connet phone, press read and turn it on.
Must read it.
If you need help just contact me.
Regards from Spain :D
tozitom 04-13-2004 17:58
I have problem to unlock a Z5, I can cretae log, decript code, enter unlock code, code is accepted, all ok...
but always same result whith any SIM CARD = SIM LOCK
What can I do? I tried to full flash it but nothing.
Page generated in 0.09947 seconds with 6 queries
