07-21-2005, 15:20 | #1 (permalink) |
No Life Poster Join Date: Sep 2002 Location: mauritius
Member: 15162 Status: Offline Thanks Meter: 61 | Need soft to unlock z5 ver 6.71??????? [Model:Z5][Ver:6.7.1][IMEI:350094402333701][SP:76A5D4C00C0A6D60475D57C0O2F8802023B52EA601814DA C0]THIS ONE IT GENERATE THE CODE BUT THE CODE DOES NOT WORK. Any solution to unlock this version please |
08-06-2005, 14:26 | #4 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | calculate code for this log [Model:Z5][Ver:6.7.1][IMEI:350094402333701][SP:76A5D4C00C0A6D60475D57C0O2F8802023B52EA601814DA C0] Got this code 51431368 sim lock 87761800 wap lock when enter this code *#7465625*32*51431368# it says unavailable on phone.have try other method too still unavailable Please help me |
08-06-2005, 14:34 | #5 (permalink) |
Insane Poster Join Date: Jun 2005 Location: bulgaria Age: 42
Member: 153263 Status: Offline Thanks Meter: 0 | the phone could be blocked(trying 10 times) *#7465625# to see how many times the code is tryed. if it is blocked try to flash it. hope to help you. regards |
08-08-2005, 10:25 | #6 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | Thanks for your code .Count =10 that means i need to flash the phone, Is there any flasher that works with normal cable .that does not need max232 etc.. or any other solution?? |
08-08-2005, 14:03 | #9 (permalink) |
No Life Poster Join Date: Sep 2002 Location: ALGERIA
Member: 15439 Status: Offline Sonork: 100.43816 Thanks Meter: 52 | flasher do not need any cable modification just run flasher select your com port and set speed 115200 clic start select your flash when soft ask u to power phone plug battery . br |
08-08-2005, 14:42 | #11 (permalink) | |
Member: 15162 Status: Offline Thanks Meter: 61 | Quote:
the flasher i have is not working with normal cable. Can you please sent me the z5 flasher ?? Thanks in advance yash | |
08-08-2005, 16:51 | #13 (permalink) |
Member: 15162 Status: Offline Thanks Meter: 61 | i have try to flash but it don't found the phone ,cable is 100% ok cause i can read log . If any solution please let me know. Thanks blida for helping. Cheers Djyash |
how to unlock moto v3x 6.71 | surfeur31 | Smart-Clip | 9 | 07-28-2007 11:11 |
I need soft to unlock GRUNDIG G402i | LordMen007 | Various | 4 | 01-11-2006 19:05 |
please i need soft to unlock alcatel old phone ( HD1 ola operator) | leroi | Alcatel & TCL Old Models | 3 | 11-19-2005 15:08 |
Need-soft-to-unlock-8310-5.57 | TAZMAN | Nokia Digital Core Technology 4 ( DCT-4 ) | 11 | 12-22-2002 00:03 |
