Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Hyper-Box
Old 11-19-2011, 09:27   #181 (permalink)
Hyper Box's Avatar
Member: 1600926
Sonork: 100.64977
Thanks Meter: 399
Old 12-04-2011, 12:55   #182 (permalink)
Hyper Box's Avatar
Member: 1600926
Sonork: 100.64977
Thanks Meter: 399
Old 12-14-2011, 11:09   #183 (permalink)
Hyper Box's Avatar
Member: 1600926
Sonork: 100.64977
Thanks Meter: 399
Initializing...
DA_LIB_VER_3.4.1.2
Tip: The phone must be able to power-on normally
It is sensing the pinout fast,please hold on the phone Power key
RXD=6 TXD=4
Connecting...Please hold on the ON/OFF key...
Any errors please select another boot and try again.
BB:6223, HardwareVer:8A05, SoftwareVer:8A00
Read info...ok, Waitting enter meta...
Connected...can release Power button now, tracking...
Code=1234
Code=7409
Old 12-28-2011, 13:39   #184 (permalink)
mobilecare.vcl's Avatar
Member: 1334005
Sonork: 100.1601457
Thanks Meter: 362
Micromax Q7
The Following User Says Thank You to mobilecare.vcl For This Useful Post:
Old 12-29-2011, 12:52   #185 (permalink)
Member: 1597797
Sonork: 100.1607258
Thanks Meter: 142
Initializing...
 DA_LIB_VER_3.6.7.1
 RXD=3  TXD=4
 Connecting...Please hold on the POWER key until the red gauge is going...
 BB:6235,    HardwareVer:8A01,    SoftwareVer:8A04
 Loading boot...
 INT_SYSRAM_BOOT test completed.
 Loading boot...
 Boot2 test completed.
 Nor Flash ID: 0000000000000000
 Nand Flash ID: 00AD00A100000015
 Read Hardware Information is done.
 Get Project ID from phone...
 Project ID: LUAEB01.8.52.1.3T18J0907_M111
 Changing baudrate to 921600...
 Done.
 Formatting Flash...
 AutoFormat address: start=0x03000000, size=0x05000000
 All Done
Old 12-29-2011, 12:53   #186 (permalink)
Member: 1597797
Sonork: 100.1607258
Thanks Meter: 142
 Initializing...
 DA_LIB_VER_3.6.7.1
 It is sensing the pinout fast...
 D-=2  D+=3
 Searching commport...please wait...
 Connecting...
 Spd USB-to-Serial=COM43
 Connected...sending boot...
 FDL test...OK
 ArmBootMode: 6600700100005A00_01
 Wait for init Commzero Security Engine...
 Done.
 Loading bootloader...
 Done.
 Changing baudrate...
 Set baudrate to 921600 is ok
 Reading phone HW info...
 Read info is done.
 CPU: SC6600L2      Flash: NOR_S29GL064A_T
 setting the Flash Parameters...
 Settings have been completed!
 Reading FileSystem info...
 FileSystem Version: 0A
 Start=0x007B0000, Size=0x00040000
 Unlocking all blocks before program/erase...
 Unlock Done.
 Auto formatting...
 Done.
Old 02-10-2012, 19:17   #187 (permalink)
Member: 1674044
Thanks Meter: 7
this bo y wonderfull
see the log
Connecting...
FDL test...OK
ArmBootMode: 6600700900026A00_01
Done.
Done.
Read info is done.
CPU: SC6600L7 Flash: NOR_ST_M58WR064KT
Unlock Done.
Analyzing FileSystem...
Done.
Reset the user data area...
Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action.
All Done.
Old 03-15-2012, 20:10   #188 (permalink)
Hyper Box's Avatar
Member: 1600926
Sonork: 100.64977
Thanks Meter: 399
Initializing...
DA_LIB_VER_3.6.0.0
D-=2 D+=3
Done.
Detecting USB device...
USB mass storage device found[ J:]
Done.
Reading H/W Info...
RamSize=0x00400000
BB: MSW85xx Flash: SPANSION_S71VS128RC0
Read information has been completed.
Reading Flash...
Saved file to:
C:\Documents and Settings\Hyperbox\Desktop\Symphony D25
All Done.
Old 03-17-2012, 13:24   #189 (permalink)
Hyper Box's Avatar
Member: 1600926
Sonork: 100.64977
Thanks Meter: 399
Initializing...
DA_LIB_VER_3.4.1.2
RXD=6 TXD=4
Code=1265
Code=79909
Old 03-18-2012, 05:38   #190 (permalink)
Member: 1597797
Sonork: 100.1607258
Thanks Meter: 142
Initializing...
 DA_LIB_VER_4.0.3.2
 RXD=2  TXD=5
 BB:6253,    HardwareVer:8A00,    SoftwareVer:8A02
 Loading boot...
 Loading boot...
 Nor Flash ID: 0001007E00630001
 Nand Flash ID: 0000000000000000
 Config EMI(Nor Flash only)...
 H/W detection ok.
 Project ID: 6253_C48E_JWT_A_ML_V02
 Done.
 Formatting Flash...
 AutoFormat address: start=0x00E00000, size=0x00200000
 All Done
Old 03-18-2012, 05:38   #191 (permalink)
Member: 1597797
Sonork: 100.1607258
Thanks Meter: 142
Initializing...
 DA_LIB_VER_4.0.3.2
 D-=8  D+=9
 Connecting...
 Spd USB-to-Serial=COM80
 FDL test...OK
 ArmBootMode: 6610000000E85A00_00
 Done.
 Done.
 Set baudrate to 115200 is ok
 Read info is done.
 CPU: SC6610/20      Flash: SF_GD25Q32
 setting the Serial Flash Parameters...
 Start=0x003D8000, Size=0x00028000
 Unlock Done.
 Auto formatting...
 Done.
Old 03-18-2012, 05:40   #192 (permalink)
Member: 1597797
Sonork: 100.1607258
Thanks Meter: 142
Initializing...
 DA_LIB_VER_4.0.3.2
 RXD=4  TXD=3
 BB:6225,    HardwareVer:8A05,    SoftwareVer:8A00
 Loading boot...
 Loading boot...
 Nor Flash ID: 0098000300000000
 H/W detection ok.
 Project ID: TC80_HT3000_DT_05
 Changing baudrate to 115200...
 Done.
 Formatting Flash...
 All Done
Old 03-18-2012, 05:41   #193 (permalink)
Member: 1597797
Sonork: 100.1607258
Thanks Meter: 142
 Initializing...
 DA_LIB_VER_4.0.3.2
 RXD=16  TXD=21
 IMEI=910042509424355
 IMEI=910042509524360
 Rebulid IMEI1=353056378181330
 Rebulid IMEI2=353056210457136
Old 03-18-2012, 08:53   #194 (permalink)
Hyper Box's Avatar
Member: 1600926
Sonork: 100.64977
Thanks Meter: 399
Initializing...
DA_LIB_VER_4.0.3.2
RXD=9 TXD=8
BB:6252, HardwareVer:8B00, SoftwareVer:CF00
Loading boot...
Loading boot...
Nor Flash ID: 00EF004000170000
Project ID: S598_53_HW23_5876_HB1_FR6_V1.4
Done.
Reading full Flash...
Saved file to:
C:\Documents and Settings\hyper\Desktop\0000000
All Done.
Old 03-18-2012, 15:00   #195 (permalink)
Hyper Box's Avatar
Member: 1600926
Sonork: 100.64977
Thanks Meter: 399
Initializing...
DA_LIB_VER_4.0.3.2
RXD=23 TXD=22
Loading boot...
Loading boot...
Nand Flash ID: 00AD007900A50000
Project ID: E950_02A_PR1_F1_HY1GB_12
Done.
Formatting Flash...
-------------Info-------------
Total Blocks=0x00001400
Bad Blocks =0x00000002
Error Blocks=0x00000000
All Done
Unlocking 5190 Ryu Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 23 01-07-2018 17:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
6110 imei changer !!!!!! Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 11-21-2011 01:44
Page generated in 0.21162 seconds with 9 queries
