12-14-2011, 11:09 | #183 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Coding Hyper-Box Age: 52
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=4 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1234 Code=7409 |
12-29-2011, 12:52 | #185 (permalink) |
Banned Join Date: Jun 2011
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks Meter: 142 | Code: Initializing... DA_LIB_VER_3.6.7.1 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00AD00A100000015 Read Hardware Information is done. Get Project ID from phone... Project ID: LUAEB01.8.52.1.3T18J0907_M111 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x03000000, size=0x05000000 All Done |
12-29-2011, 12:53 | #186 (permalink) |
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks Meter: 142 | Code: Initializing... DA_LIB_VER_3.6.7.1 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM43 Connected...sending boot... FDL test...OK ArmBootMode: 6600700100005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_S29GL064A_T setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007B0000, Size=0x00040000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
02-10-2012, 19:17 | #187 (permalink) |
Insane Poster Join Date: Oct 2011 Location: Cuba
Member: 1674044 Status: Offline Thanks Meter: 7 | this bo y wonderfull see the log Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900026A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
03-15-2012, 20:10 | #188 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_3.6.0.0 It is sensing the pinout fast,please hold on the phone Power key D-=2 D+=3 Done. Detecting USB device... USB mass storage device found[ J:] Loading bootloader... Done. Reading H/W Info... RamSize=0x00400000 BB: MSW85xx Flash: SPANSION_S71VS128RC0 Read information has been completed. Reading Flash... Saved file to: C:\Documents and Settings\Hyperbox\Desktop\Symphony D25 All Done. |
03-17-2012, 13:24 | #189 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=4 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1265 Code=79909 |
03-18-2012, 05:38 | #190 (permalink) |
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks Meter: 142 | Code: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0001007E00630001 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 6253_C48E_JWT_A_ML_V02 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
03-18-2012, 05:38 | #191 (permalink) |
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks Meter: 142 | Code: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM80 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000E85A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D8000, Size=0x00028000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
03-18-2012, 05:40 | #192 (permalink) |
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks Meter: 142 | Code: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: TC80_HT3000_DT_05 Changing baudrate to 115200... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
03-18-2012, 05:41 | #193 (permalink) |
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks Meter: 142 | Code: Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=21 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=910042509424355 IMEI=910042509524360 Rebulid IMEI1=353056378181330 Rebulid IMEI2=353056210457136 |
03-18-2012, 08:53 | #194 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CF00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... Get Project ID from phone... Project ID: S598_53_HW23_5876_HB1_FR6_V1.4 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\hyper\Desktop\0000000 All Done. |
03-18-2012, 15:00 | #195 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00AD007900A50000 Read Hardware Information is done. Get Project ID from phone... Project ID: E950_02A_PR1_F1_HY1GB_12 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x03000000, size=0x05000000 -------------Info------------- Total Blocks=0x00001400 Bad Blocks =0x00000002 Error Blocks=0x00000000 ------------------------------- All Done |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
