03-19-2012, 13:38 | #196 (permalink) |
Freak Poster Join Date: Jun 2011 Location: Coding Hyper-Box Age: 52
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=8 TXD=10 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 00AD007900A50000 Read Hardware Information is done. Get Project ID from phone... Project ID: E560_MP_BEGNALI_01_08 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x02000000, size=0x06000000 All Done |
03-31-2012, 07:37 | #197 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CF00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EF004000170000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... Failed to check H/W. Get Project ID from phone... Project ID: S598_53_HW23_5876_HB1_FR3_V1.4 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
03-31-2012, 07:37 | #198 (permalink) |
04-01-2012, 14:30 | #199 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_4.0.3.2 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700500026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L3 Flash: NOR_SVME64322UTA setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
04-02-2012, 13:22 | #200 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8B00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 009800C0008000D5 Read Hardware Information is done. Get Project ID from phone... Project ID: HX8000_V3.2_SINGLE_OS_WIFI Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x02000000, size=0x02000000 All Done |
04-03-2012, 08:38 | #201 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Unable to locate LID, Force write... Lid=0x2_0x0073, Val=FFFFFFFFFFFFFF0F0000 Lid=0x1_0x0073, Val=FFFFFFFFFFFFFF0F0000 Lid=0x2_0x00B1, Val=00000000000000000000 Lid=0x1_0x00B1, Val=00000000000000000000 All done. |
04-03-2012, 14:47 | #202 (permalink) |
No Life Poster Join Date: Nov 2006 Location: Back after long time :-) Age: 40
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0001227E22202200 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: E671_PR_F2_Micromax_01.16 Changing baudrate to 460800... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x001F0000 All Done Br. Vijendra Saini. |
04-05-2012, 08:34 | #203 (permalink) |
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks Meter: 399 | Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM23 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000385A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\Hyper Box\Desktop\0000000 All Done. Reading Project Version... Platform Version: 09A_MP.W11.16_P4_L1202_TJ_6620_3232_V1.03_111220 Project Version: SC6600L_6620 MMI Version: SC6600L_6620 BASE Version: BASE_10A.W11.24.08 HW Version: SC6620 Project Bulid Time: 12-20-2011 12:19:4 |
04-08-2012, 14:03 | #204 (permalink) |
No Life Poster Join Date: Jan 2009 Location: KERALA / SWAMI SARANAM Age: 36
Member: 1334005 Status: Offline Sonork: 100.1601457 Thanks Meter: 362 | Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: TC72A_HT150I_DM_12 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E10000, size=0x01200000 All Done |
04-09-2012, 11:18 | #205 (permalink) |
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=10 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC257E25062501 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: FXD_A03_01_V1_0_009_100825 Changing baudrate to 57600... Done. Formatting Flash... AutoFormat address: start=0x00770000, size=0x00090000 All Done |
04-09-2012, 11:26 | #206 (permalink) |
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=20 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: L_2013A3_UI2_T2.21.7.T4_DAPS Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
04-10-2012, 15:25 | #207 (permalink) |
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... RXD=4 TXD=3 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100006A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x007A0000, Size=0x00050000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
04-14-2012, 11:37 | #208 (permalink) |
Banned Join Date: Jun 2011
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks Meter: 142 | Code: Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... RXD=5 TXD=6 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700900026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_K5N6433ATB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Analyzing FileSystem... Done. Reset the user data area... Note: if user partition size is more than 4MB, The phone would may take 1 minute to rebuild FileSystem after Reset Action. All Done. |
04-17-2012, 10:06 | #209 (permalink) |
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks Meter: 1,516 | Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6227, HardwareVer:8A02, SoftwareVer:8A01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0089890100000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: KAA280_INA_EN_1.02.C18 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x01400000, size=0x00C00000 All Done |
04-20-2012, 12:36 | #210 (permalink) |
No Life Poster Join Date: Sep 2005 Location: TR-LAZ
Member: 178227 Status: Offline Sonork: 100.1597371 Thanks Meter: 176 | N8 Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0001227E22202200 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: LSCA702_TR8_NS5_SD_V2.3ATEST |
what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 07-31-2012 20:09 |
6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2011 01:44 |
