!! Hyper-Box !! Success Report Of Flash-Backup-Format-Unlock-Change IMEI !! Post All Success Story { Flash/Backup/Format/Change Imie } Using Hyper-Box http://www.ipmart.com/contents/produ...-BOX_2_662.jpg |
MTK CPU FORMATTING LOGS Code: Initializing... |
SPD CHIP FORMATTING LOG Code: Initializing... |
READING INFO LOG Code: Initializing... |
SPD CHIP INFO LOG Code: Initializing... |
BASSOON F800 FULL FLASHING Code: Initializing... |
MTK FORMATTING LOG Code: Initializing... |
LAVA ARC02 IMEI CHANGE Code: Initializing... |
WING M25 FORMATTING LOG Code: Initializing... |
Initializing... DA_LIB_VER_3.3.1.6 It is sensing the pinout fast,please hold on the phone Power key RXD=12 TXD=13 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: C71_T312832_HY1_11G_MYPHONE_V01 Changing baudrate to 460800... Done. |
Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=12 TXD=13 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 002088C400000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: C71_T312832_HY1_11G_MYPHONE_V01 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=4321 Code=8864 |
DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=24 TXD=22 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009600000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 111616_7432_V1515 Changing baudrate to 921600... Done. Reading full Flash... Saved file to: C:\Documents and Settings\Hyper Box\Desktop\Symphony A90 All Done. |
Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=4 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00C2002500370000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: NINE.10A.W11.08.MP.V1.F2.V1.0.07 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00768000, size=0x00098000 All Done |
