Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #226 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jan 2008 Location: Gazipur-Dhaka-Bangladesh
Member: 670820 Status: Offline Sonork: 100.1583728 Thanks: 616
| SYMPHONY X95 UNLOCKING DONE Initializing... DA_LIB_VER_5.0.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=21 TXD=23 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1122 Code=8888 |
| | #227 (permalink) |
| SYMPHONY FT04 IMEI REPAIR DONE Initializing... DA_LIB_VER_5.0.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Connecting, Please turn on the phone... Connected! Checking IMEI... Original IMEI 1= 359690004059440 IMEI 1 rebuild has been implemented: 359690004059440 Original IMEI 2= 359690004059640 IMEI 2 rebuild has been implemented: 359690004059640 Need to restart the phone to verify new imei. |
| | #228 (permalink) |
| SYMPHONY FT30 PHONE LOCK DONE Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=23 TXD=22 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8B00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0001 Code=1379 |
| | #229 (permalink) |
| NEXUS NF19 SPD 6620 FORMAT DONE Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM37 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000005A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 115200 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x003D8000, Size=0x00028000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
| | #230 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Sep 2011 Location: GaZiPuR-Bangladesh
Member: 1648232 Status: Offline Sonork: 100.1627232 Thanks: 705
| forme unlock dane Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=2 TXD=8 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6610000000A26A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 230400 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD25Q32 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Connect and search Security Code... Privacy protect: 8911 PhoneLock: 8911 Done. |
| | #231 (permalink) |
| symphony m70 flashing done Initializing... DA_LIB_VER_5.0.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... BB:6253, HardwareVer:8A00, SoftwareVer:8A04 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6253T Flash: NOR_K5N2833ATB setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Analysis the file, Some file may need a long time... The file has not been encrypted. Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
| | #232 (permalink) |
| SYMPHONY D61 UNLOCK DONE Initializing... DA_LIB_VER_5.0.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=16 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA05 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=0022 Code=2618] |
| | #233 (permalink) |
| sprint D515 format done Initializing... DA_LIB_VER_4.0.3.2 It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6253, HardwareVer:8A00, SoftwareVer:8A02 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098009E00000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: P01A_PLDv01.01B07_Bengal Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
| | #234 (permalink) | |
| sprint D515 read done Quote:
| | #235 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jun 2011 Location: HYPER BOX
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks: 15
| Code: Initializing... DA_LIB_VER_4.3.6.8 It is sensing the pinout fast... RXD=4 TXD=7 Connecting... Connected...sending boot... FDL test...OK ArmBootMode: 6600700100026A00_00 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6600L2 Flash: NOR_S29GL128N_T setting the Flash Parameters... Settings have been completed! Reading FileSystem info... FileSystem Version: 0A Start=0x00F00000, Size=0x00100000 Unlocking all blocks before program/erase... Unlock Done. Auto formatting... Done. |
| | #236 (permalink) | |
| smart 8533d flashing done Quote:
| | #237 (permalink) | |
| symphony s110 read code done Quote:
| | #238 (permalink) | |
| nony s213 6800h read done.. Quote:
| | #239 (permalink) |
| Zte-g n281 IMEI REPAIR DONE. Initializing... DA_LIB_VER_4.0.3.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=3 TXD=4 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8A04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=355473026000000 Rebulid IMEI1=357692030738385 |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 07-31-2012 20:09 |
| 6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 11-21-2011 00:44 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
