Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #16 (permalink) |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2011 Location: Coding Hyper-Box Age: 41
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks: 93
| Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=22 TXD=23 Connecting...Please hold on the POWER key until the red gauge is going... BB:6225, HardwareVer:8A03, SoftwareVer:8A00 Loading boot... Boot init completed. Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Reading phone HW info... Read info is done. BB: MT6225 Flash: NOR_TV00578002DABD setting the Flash Parameters... Settings have been completed! Changing baudrate... Set baudrate to 921600 ...ok Unlocking all blocks before program/erase... Unlock Done. Formatting... Done. |
| | #17 (permalink) |
| Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=1 TXD=3 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=1122 Code=2011 |
| | #18 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jan 2009 Location: KERALA / SWAMI SARANAM Age: 25
Member: 1334005 Status: Offline Sonork: 100.1601457 Thanks: 241
| Mtk bb:6252 imei changing success Code: Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=9 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6252, HardwareVer:8B00, SoftwareVer:CA04 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=351111111111111 IMEI=351111111111111 Rebulid IMEI1=352023049529026 Rebulid IMEI2=355702028256894 |
| | #19 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Jun 2011 Location: HYPER BOX
Member: 1597797 Status: Offline Sonork: 100.1607258 Thanks: 15
| MTK 6226 FORMATTING LOGS Code: Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6226, HardwareVer:8A02, SoftwareVer:8A01 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098004900000000 Nand Flash ID: 009800F000800095 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: 7S7339IN00-001-R1B Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
| | #20 (permalink) |
| LG KP199 IMEI CHANGE Code: Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=7 TXD=4 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6226, HardwareVer:8A02, SoftwareVer:8A01 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=135790246811220 Rebulid IMEI1=353225035629530 |
| | #21 (permalink) |
| Code: Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=7 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: TC72A_HT150I_DM_12 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
| | #22 (permalink) |
| Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM10 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_TV00560002EDGB setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
| | #23 (permalink) |
| Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8B00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... Code=79674669 |
| | #24 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
Member: 192810 Status: Offline Thanks: 624
| iphone(888) Security Code read Done ![]() Video Manual Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu |
| | #25 (permalink) |
| Initializing... DA_LIB_VER_3.2.2.8 It is sensing the pinout fast... D-=2 D+=3 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM33 Connected...sending boot... FDL test...OK ArmBootMode: 6600700900005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 ok Reading phone HW info... Read info is done. CPU: SC6600L7 Flash: NOR_ST_M58WR064KT setting the Flash Parameters... Settings have been completed! Unlocking all blocks before program/erase... Unlock Done. Programming... Compare Image: Enable All Done. |
| | #26 (permalink) |
| Nokia C2 (spd) Flashing succeeded by Hyper-box ![]() Video Manual Free File Hosting & Video Downloads, Free File Sharing, Online Friends Network - Ziddu |
| The Following User Says Thank You to DUNIYA JAMAL For This Useful Post: |
| | #27 (permalink) |
| Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=5 TXD=8 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC257E25082501 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: X12_S9325_V3.0_0507_1 Changing baudrate to 460800... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
| | #28 (permalink) |
| Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=18 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0098000300000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Config EMI(Nor Flash only)... H/W detection ok. Get Project ID from phone... Project ID: R202AD_GH_N208_F10A_V02_100108 Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E40000, size=0x001C0000 All Done |
| | #29 (permalink) |
| Initializing... DA_LIB_VER_3.4.1.2 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=18 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6225, HardwareVer:8A05, SoftwareVer:8A00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358994030047338 IMEI=358994030047346 IMEI=358994030047346 Rebulid IMEI1=358994030047338 Rebulid IMEI2=358994030047346 |
| | #30 (permalink) |
| Code: Initializing... DA_LIB_VER_3.4.1.2 It is sensing the pinout fast,please hold on the phone Power key RXD=9 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 00EC240200000000 Nand Flash ID: 0000000000000000 Read Hardware Information is done. Get Project ID from phone... Project ID: PN-SC_CN_LLNUMLD_203_YYMMDD_CAM_MCPMCP_O Changing baudrate to 921600... Done. Formatting Flash... AutoFormat address: start=0x00E00000, size=0x00200000 All Done |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Unlocking 5190 | Ryu | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 23 | 09-16-2012 23:57 |
| what prog changes imei on 6110 and how do i do it? | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 3 | 07-31-2012 20:09 |
| 6110 imei changer !!!!!! | Ravetrancer | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 11-21-2011 00:44 |
| Seeking for flash nokia 5110 old version (3 version) can exchange for new | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 7 | 11-17-2011 17:08 |
