Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Sep 2005 Location: TR-LAZ
Member: 178227 Status: Offline Sonork: 100.1597371 Thanks: 1,306
| Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=6 TXD=5 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6223, HardwareVer:8A05, SoftwareVer:8A00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Failed to set MTK_cmd_JumpToAddr |
| | #2 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Jun 2011 Location: Coding Hyper-Box Age: 41
Member: 1600926 Status: Offline Sonork: 100.64977 Thanks: 93
| Quote:
what is the status of phone ? yes its hardware problem , you know why hyper box not read the project id , becoz inside the phone have low power problem , box give some power but its not enough for phone , check with hardware | |
| | #5 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2006 Location: Kashmir mangoge bhoon denge Age: 29
Member: 398557 Status: Offline Sonork: 100.1578489 Thanks: 554
| Thats a fault by voltage issue,the proper voltage not come to CPU. Check supply in the PCB. Thats an hardware fault. Vijendra Saini. |
| | #6 (permalink) |
| Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=19 TXD=20 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 User abort, freeing Download Agent, please wait... TimeOut...Force Quit! |
| | #7 (permalink) | |
| Quote:
Failed to read HardCode, REG=0x80000008 check votage supply in the pcb. Vijendra Saini. | |
| | #8 (permalink) |
| Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Connected...sending boot... Spd USB-to-Serial=COM55 FDL test...OK ArmBootMode: 6610000000005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading FileSystem info... Error: Get Flash die baseaddress |
| | #9 (permalink) |
| DA_LIB_VER_3.9.0.0 It is sensing the pinout fast... D-=8 D+=9 Searching commport...please wait... Connecting... Spd USB-to-Serial=COM55 Connected...sending boot... FDL test...OK ArmBootMode: 6610000000005A00_01 Wait for init Commzero Security Engine... Done. Loading bootloader... Done. Changing baudrate... Set baudrate to 921600 is ok Reading phone HW info... Read info is done. CPU: SC6610/20 Flash: SF_GD27Q64 setting the Flash Parameters... Settings have been completed! setting the Serial Flash Parameters... Settings have been completed! Reading Flash... Saved file to: C:\Documents and Settings\TR_LAZ\Desktop\ztc All Done. Reading Project Version... Error: Unsupport FileSystem. |
| | #11 (permalink) | |
| Quote:
You have to manually select flash chip format area. Br. Vijendra Saini. | |
| | #12 (permalink) |
| READ INFO OK Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8B00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 002000F10000001D Read Hardware Information is done. Get Project ID from phone... Project ID: MAUI.08B.GEMINI.W09.12.HH.V0.1 ------------------------BOX NO PROBLEM--- FORMAT OK Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8B00 Loading boot... INT_SYSRAM_BOOT test completed. Loading boot... Boot2 test completed. Nor Flash ID: 0000000000000000 Nand Flash ID: 002000F10000001D Read Hardware Information is done. Get Project ID from phone... Project ID: MAUI.08B.GEMINI.W09.12.HH.V0.1 Changing baudrate to 460800... Done. Formatting Flash... AutoFormat address: start=0x04000000, size=0x04000000 All Don İMEİ OK.. DA_LIB_VER_3.9.0.0 Tip: The phone must be able to power-on normally It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the ON/OFF key... Any errors please select another boot and try again. BB:6235, HardwareVer:8A01, SoftwareVer:8B00 Read info...ok, Waitting enter meta... Connected...can release Power button now, tracking... IMEI=358688000000158 Rebulid IMEI1=351546012373898 --------------------------------- TR_LAZ |
| | #13 (permalink) |
| http://www.ressim.net/i/5618723] help.. MT 6219_AT CPU Initializing... DA_LIB_VER_3.9.0.0 It is sensing the pinout fast,please hold on the phone Power key RXD=2 TXD=3 Connecting...Please hold on the POWER key until the red gauge is going... Any errors please select another boot and try again. Failed to read HardCode, REG=0x80000008 Error: Failed to read REG=0x80010008 Error: Failed to read REG=0x84010008 Error: Failed to read REG=0x80001008 ----------------------------- check votage supply in the pcb. no problem.. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| How to add a language in 51xx/61xx | tati | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 8 | 05-21-2013 19:20 |
| How to upload a new firmware... | Brand | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 28 | 08-30-2012 03:40 |
| news headlines to gsm phone | mos | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 6 | 12-18-2011 11:00 |
| Copy from one 6110 to another | Leif Nielsen | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-10-1999 22:36 |
