02-29-2016, 18:09 | #1 (permalink) |
No Life Poster Join Date: Aug 2004 Location: In my country Age: 56
Member: 77002 Status: Offline Sonork: 100.1657194 Thanks Meter: 79 | 2.2.1 Many Problems. Cant connect G360m This is other problem with the last version 2.2.1 or with the last card firmware. Please allow to use old softwares versions ! |
02-29-2016, 18:57 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,411 | Hello. To connect SM-G360M phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Connect the phone directly to PC. 11. Press "Read Info" in software. Also, try to make "Read Info" on different COM ports, with enabled "Manual select" option. |
