01-13-2017, 21:55 | #1 (permalink) |
Freak Poster Join Date: Jun 2008
Member: 786918 Status: Offline Thanks Meter: 13 | a 510f 2016 problem frp |
The Following User Says Thank You to dword2 For This Useful Post: |
01-14-2017, 09:33 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Hello. Please, post here full Software log with all performed operations. Also, read this: http://forum.gsmhosting.com/vbb/f684...leted-2165824/. Last edited by Octopus box; 01-14-2017 at 13:00. |
01-15-2017, 17:50 | #3 (permalink) |
Member: 786918 Status: Offline Thanks Meter: 13 | Support hi i am trying to write the combination file but I get this error how to solve this problem thanks. Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 -------------------------------------------------------------------- --------------- Platform: Samsung Android Selected port: COM11 Selected model: SM-A510F Reading info, please wait... Proper android device not found. Make shure that "USB debug" option on the device is turned on. Performed by 2.4.7 Software version. Selected AP file: C:\Users\windows\Downloads \A510FXXU3BPK4_A510FOXA3BPK4_ITV \A510FXXU3BPK4_A510FOXA3BPK4 _A510FXXU3BPK4_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing CM section... CM section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. Selected firmware file: combination_a510f_a510fxxu2apg1_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Selected firmware file: combination_a510f_a510fxxu1aol7_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Selected firmware file: combination_a510f_a510fxxu1aol7_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. |
01-16-2017, 09:07 | #4 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Most likely the firmware is not compatible with the phone. You should try to use different Combination firmwares. Also, problem with writing of SM-A510F could occur if it is not compatible with current firmware of the phone. |
01-18-2017, 15:41 | #5 (permalink) |
Member: 786918 Status: Offline Thanks Meter: 13 | prejudice 'cause I keep saying unsupported combination solution files that you have to run through. Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 Selected firmware file: a510fxxu2bpf9_a510foxy2bpf9_ser_android_ 6.0.1.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Selected AP file: C:\Users\windows\Downloads\A510FXXU3BPK4 _A510FOXA3BPK4_ITV\A510FXXU3BPK4_A510FOXA3BPK4 _A510FXXU3BPK4_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Firmware write started. Writing BOOT section... BOOT section has been written successfully. Writing CACHE section... CACHE section has been written successfully. Writing CM section... CM section has been written successfully. Writing HIDDEN section... HIDDEN section has been written successfully. Writing RADIO section... RADIO section has been written successfully. Writing RECOVERY section... RECOVERY section has been written successfully. Writing BOOTLOADER section... BOOTLOADER section has been written successfully. Writing SYSTEM section... SYSTEM section has been written successfully. Firmware writing successfully completed. Performed by 2.4.7 Software version. Selected firmware file: combination_a510f_a510fxxu2apg1_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Selected firmware file: combination_a510f_a510fxxu2apc2_boot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. |
01-18-2017, 16:00 | #6 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | Quote:
02-24-2017, 17:53 | #7 (permalink) |
Freak Poster Join Date: Sep 2000 Age: 57
Member: 2200 Status: Offline Thanks Meter: 44 | cant remove frp Welcome to Octoplus/Octopus Box Samsung software version 2.4.7 Selected firmware file: a510f_rootedboot.oct Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Operation was canceled Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. |
02-28-2017, 10:01 | #8 (permalink) | |
Major Poster Join Date: May 2014
Member: 2196653 Status: Offline Thanks Meter: 5 | Quote:
i have no files in test software. have a510f 6.0.1 and can not get rid of frp, tried all combination files. also tried other boxes. | |
02-28-2017, 10:08 | #9 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,407 | You should use the latest Software version. |
