07-05-2014, 18:18 | #1 (permalink) |
Freak Poster Join Date: Mar 2005 Location: TURKEY Age: 42
Member: 127987 Status: Offline Thanks Meter: 6 | İ9300 İmeİ null/null imei null null Platform: Samsung Android Selected port: COM86 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Sun May 13 11:49:07 KST 2012 PDA version: I9300BUALE6 CSC version: I9300VFGALE6 SW version: Unknown Phone IMEI: Unknown Android version: 4.0.4 (IMM76D) Checking Root: Phone is Rooted. Reading security backup, please wait... Write IMEI failed |
07-05-2014, 18:32 | #2 (permalink) | |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. As You can see from your Software log, phone's modem part is damaged: Quote:
It is not possible to repair IMEI, if phone's modem part is damaged. Please make Repair EFS. Then re-flash the phone with different firmwares and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. | |
07-05-2014, 18:35 | #3 (permalink) |
No Life Poster Join Date: Mar 2014 Location: Rawalpindi, Pakistan Age: 35
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | please share the pic on software download mode. First step is to determine phone is software faulty or hardware. |
07-05-2014, 18:54 | #4 (permalink) |
Member: 2157308 Status: Offline Sonork: 100.1655088 Thanks Meter: 677 | here is your efs repair file flash it using odin. i9300_repair_efs.tar - Download - 4shared - Sanjeev Chauhan |
07-08-2014, 16:56 | #7 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | @ ozturkcep As I have written above, make Repair EFS, then re-flash the phone with different firmwares form the Support Area and check, whether modem is correct (not Unknown). And only then (when phone's modem part will be correct) perform the "Repair IMEI" operation. If after of writing all firmwares which You have, phone's baseband is still Unknown - most likely, this is HW problem (problem with eMMC flash chip). |
07-09-2014, 09:39 | #10 (permalink) |
Member: 127987 Status: Offline Thanks Meter: 6 | Welcome to Octoplus/Octopus Box Samsung software version 1.6.0 ----------------------------------------------------------------------------------- To connect GT-I9300 phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->Developer options. 3. Turn on "USB Debugging" option. 4. When message is appear press "Yes". 5. Connect usb cable to phone. 6. Go to dial window. 7. Enter *#9090# number. 8. Set speed to 115200. 9. Reboot phone. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9300 To put GT-I9300 phone into download mode you have to perform the following steps: 1. Reconnect phone battery. 2. Press and hold "Volume - " + "Home" + "Power" buttons. 3. When phone turns on press "Volume+" button. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Thu Nov 28 21:07:41 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300OXXGML1 SW version: Unknown Phone IMEI: Unknown Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9300-Unknown09-07-2014_11-30-25-.asec file Cheking security type... Old security type is detected Old IMEI: Unknown New IMEI: 353975-05------- Repairing IMEI ... Executing exploit... Exploit has been executed successfully Unknown security Write IMEI failed ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM8 Selected model: GT-I9300 Detected phone model: GT-I9300 Firmware compiled date: Thu Nov 28 21:07:41 KST 2013 PDA version: I9300XXUGMK6 CSC version: I9300OXXGML1 SW version: Unknown Phone IMEI: Unknown Android version: 4.3 (JSS15J) Checking Root: Phone is Rooted. Reading security backup, please wait... Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung \BACKUP\Security-GT-I9300-Unknown09-07-2014_11-31-55-.asec file Cheking security type... Old security type is detected Old IMEI: Unknown New IMEI: 353975--------- Repairing IMEI ... Executing exploit... Exploit has been executed successfully Unknown security Write IMEI failed |
