07-26-2017, 16:02 | #1 (permalink) |
No Life Poster Join Date: Apr 2008 Location: In My ThinkPad
Member: 756569 Status: Offline Thanks Meter: 185 | A500FU Hang On Logo After Successful EFS Repair !! In Recovery E: failed to mount /efs (invalid argument) I Don't have EFS Backup ... Any Help ? BR Welcome to Octoplus/Octopus Box Samsung software version 2.5.4 ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM3 Selected model: SM-A500FU Selected file: D:\SAMSUNG\CERT\A\A 500FU\cert-sm-a500fu_ 359536019154806_rf8g105m6pd.cert Perform the following steps: 1. Connect phone via UART cable to the Box. 2. Note: phone screen must be active Connecting to phone, please wait... Phone was not found Writing Certificate failed Performed by 2.5.4 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM54 Selected model: SM-A500FU To put SM-A500FU into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Repairing EFS... Searching for a phone. Please wait... Phone found. EFS Repair successfully Performed by 2.5.4 Software version. |
07-26-2017, 16:20 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | Hello. What was initial state of the phone? Was it booting correctly? Try to make Factory Reset and Wipe cache partition from Recovery Mode. If problem will remain the same - try to reflash the phone. |
07-28-2017, 14:51 | #5 (permalink) | ||
Member: 756569 Status: Offline Thanks Meter: 185 | Quote:
Yes...Everything Was Ok. Only No Service Problem. I Was Wright Qce. Cert. And Repair NVM But Problem Not Solved. Then I Repair EFS . Show Me Repair Successfully but Now Phone Hang On Logo. Factory Reset And Wipe Cache Partition Done But Not Solved. Try To Flash Quote:
ODIN: Invalid ext4 image. Flash Without Hidden Is Ok But Problem Not Solved Please Help Me Sir.....i am in big problem. Last edited by nazrul islam; 07-28-2017 at 14:59. | ||
07-28-2017, 14:57 | #6 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | If "E: failed to mount /efs (invalid argument)" error still remains in Recovery Mode - You can try to manually write EFS of another, correctly working SM-A500FU. |
07-29-2017, 07:50 | #8 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,409 | All files what we have at the moment are available at the Support Area. To enter Support Area, press "Go to support" button on "Support & options" tab of the Software. |
