08-18-2016, 15:36 | #1 (permalink) |
No Life Poster Join Date: Mar 2008 Location: FOCSANI Age: 39
Member: 718470 Status: Offline Thanks Meter: 79 | a500fu unlock problem ??? [Solved] ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-A500FU Detected phone model: SM-A500FU Firmware compiled date: Fri Jul 8 22:40:08 KST 2016 PDA version: A500FUXXU1CPG2 CSC version: A500FUVFR1CPG2 SW version: A500FUXXU1CPG2 Phone SN: RF8G41ETS9V Android version: 6.0.1 (MMB29M) Sales code: VD2 Country: Germany HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: a5ultexx Checking Root: Phone is Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.3.3 software version and fast unlocking Welcome to Octoplus/Octopus Box Samsung software version 2.3.3 ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-A500FU Detected phone model: SM-A500FU Firmware compiled date: Fri Jul 8 22:40:08 KST 2016 PDA version: A500FUXXU1CPG2 CSC version: A500FUVFR1CPG2 SW version: A500FUXXU1CPG2 Phone SN: RF8G41ETS9V Android version: 6.0.1 (MMB29M) Sales code: VD2 Country: Germany HW platform: msm8916 HW Chip: MSM8916 HW Modem: MSM8916 Codename: a5ultexx Checking Root: Phone is Rooted. Unlocking phone... Phone is successfully unlocked To finish the operation, please restart the phone via phone's menu. Performed by 2.3.3 software version ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM22 Selected model: SM-A500FU Reading info... Mode: Normal Firmware compiled date: May 20 2016 Firmware compiled time: 01:00:00 Firmware released date: Jul 18 2016 Firmware released time: 14:11:20 SW Version: MPSS.DPM.2.0.c5-00150-M8936FAAAANUZM-1 Unlocking phone... Fast Unlock method is not supported for current security settings in your phone! Try to downgrade firmware! Phone unlocking failed Performed by 2.3.3 software version but phone locked android 6.0.1 hard reset root unlock done but the phone remains encrypted require network code Last edited by Octopus box; 08-18-2016 at 17:05. |
08-18-2016, 15:55 | #2 (permalink) |
Member: 1146942 Status: Offline Sonork: 100.1587278 Thanks Meter: 27,413 | Hello. Try to enter 00000000, 11111111 and 12345678 codes. If phone won't accept codes - try to write older (by release date) firmware, then repeat "Unlock" operation. |
