Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Octopus/Octoplus > Octopus Samsung/Octoplus Samsung
Old 08-05-2015, 14:17   #1 (permalink)
Bruno Rafael's Avatar
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
A500M write cert Ok but no Network!
Platform: Samsung Android
INFO : 31/07/2015 15:15:12 > Selected port: COM20
INFO : 31/07/2015 15:15:12 > Selected model: SM-A500M
INFO : 31/07/2015 15:15:12 > Detected phone model: SM-A500M
INFO : 31/07/2015 15:15:12 > Firmware compiled date: Thu Mar 12 03:31:02 KST 2015
INFO : 31/07/2015 15:15:13 > PDA version: A500MUBU1AOC1
INFO : 31/07/2015 15:15:13 > CSC version: A500MZTR1AOC1
INFO : 31/07/2015 15:15:14 > SW version: A500MUBU1AOC1
INFO : 31/07/2015 15:15:15 > Phone IMEI: 356632060732997
INFO : 31/07/2015 15:15:15 > Phone SN: RX8G203MFTR
INFO : 31/07/2015 15:15:15 > Android version: 4.4.4 (KTU84P)
INFO : 31/07/2015 15:15:15 > Reading info...
INFO : 31/07/2015 15:15:15 > Mode: Normal
INFO : 31/07/2015 15:15:15 > Firmware compiled date: Nov 28 2014
INFO : 31/07/2015 15:15:15 > Firmware compiled time: 03:00:00
INFO : 31/07/2015 15:15:15 > Firmware released date: Mar 11 2015
INFO : 31/07/2015 15:15:15 > Firmware released time: 21:10:57
INFO : 31/07/2015 15:15:15 > SW Version: MPSS.DPM.1.0.c7.1-00045-M8916EAAAANVZM-1.7069.1.7297.1.7615.1
INFO : 31/07/2015 15:15:15 > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\QCN-SM-A500M-356632060732997-31-07-2015_15-15-15-.qcn file
INFO : 31/07/2015 15:15:15 > Checking Root:
INFO : 31/07/2015 15:15:16 > Phone is Rooted.
INFO : 31/07/2015 15:15:16 > Reading security backup, please wait...
INFO : 31/07/2015 15:16:09 > Backup saved as C:\Program Files\Octoplus\Octoplus_Samsung\BACKUP\Security-SM-A500M-356632060732997-31-07-2015_15-15-16-.asec file
INFO : 31/07/2015 15:16:09 > Wiping EFS...
INFO : 31/07/2015 15:16:47 > EFS wipe successfully
WARN : 31/07/2015 15:16:48 > Phone will restart now. Please don't disconnect cable!
INFO : 31/07/2015 15:16:48 > Searching for a phone. Please wait...
INFO : 31/07/2015 15:17:18 > Reading info...
INFO : 31/07/2015 15:17:18 > Mode: Normal
INFO : 31/07/2015 15:17:18 > Firmware compiled date: Nov 28 2014
INFO : 31/07/2015 15:17:18 > Firmware compiled time: 03:00:00
INFO : 31/07/2015 15:17:18 > Firmware released date: Mar 11 2015
INFO : 31/07/2015 15:17:18 > Firmware released time: 21:10:57
INFO : 31/07/2015 15:17:18 > SW Version: MPSS.DPM.1.0.c7.1-00045-M8916EAAAANVZM-1.7069.1.7297.1.7615.1
INFO : 31/07/2015 15:17:18 > Wipe security successfully complete.
WARN : 31/07/2015 15:17:18 > Phone will restart now. Please don't disconnect cable!
INFO : 31/07/2015 15:19:46 > -----------------------------------------------------------------------------------
INFO : 31/07/2015 15:19:46 > Platform: Samsung Android
INFO : 31/07/2015 15:19:46 > Selected port: COM20
INFO : 31/07/2015 15:19:46 > Selected model: SM-A500M
INFO : 31/07/2015 15:19:51 > Selected file: C:\Users\Celetronic\Downloads\Cert-SM-A500F_356316062038146.cert
WARN : 31/07/2015 15:19:53 > Perform the following steps:
WARN : 31/07/2015 15:19:53 > 1. Connect phone via UART cable to the Box.
WARN : 31/07/2015 15:19:53 > 2. Note: phone screen must be active
INFO : 31/07/2015 15:19:53 > Connecting to phone, please wait...
INFO : 31/07/2015 15:20:04 > Found phone on COM4
INFO : 31/07/2015 15:20:04 > Phone connected successfully
INFO : 31/07/2015 15:20:04 > Checking Certificate file...
INFO : 31/07/2015 15:20:04 > Certificate file successfully checked
INFO : 31/07/2015 15:20:04 > Writing new phone IMEI...
INFO : 31/07/2015 15:20:14 > Checking certificate compatibility...
INFO : 31/07/2015 15:20:14 > Certificate is compatible
INFO : 31/07/2015 15:20:14 > Writing Certificate...
INFO : 31/07/2015 15:20:21 > Certificate has been written successfully
INFO : 31/07/2015 15:20:21 > Please, restart the phone to apply changes
Old 08-05-2015, 15:07   #2 (permalink)
Octopus box's Avatar
Member: 1146942
Sonork: 100.1587278
Thanks Meter: 27,406
Hello.
Write first QCN backup ("QCN-SM-A500M-356632060732997-31-07-2015_15-15-15-.qcn") back into the phone and restart . When phone turns on, wait 2-5 minutes, then try to find and select Network manually.
Old 08-05-2015, 18:28   #3 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
I do not know what happened but this beckup not there anymore !
only .sec files
Old 08-06-2015, 08:41   #4 (permalink)
Member: 1146942
Sonork: 100.1587278
Read QCN from another, correctly working SM-A500M and write into your phone.
Old 08-06-2015, 11:50   #5 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
do you have one A500M for read and send-me ? becouse i do no!
Old 08-06-2015, 12:38   #6 (permalink)
Member: 1146942
Sonork: 100.1587278
Unfortunately we don't have QCN files of SM-A500M at the moment.
Old 08-06-2015, 12:46   #7 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
how to revert this situation?
Old 08-06-2015, 13:34   #8 (permalink)
Member: 1146942
Sonork: 100.1587278
Write first Security backup (according to logs, it is "Security-SM-A500M-356632060732997-31-07-2015_15-15-16-.asec") back into the phone.
Writing of first Security backup will restore the phone to its initial condition.
The Following User Says Thank You to Octopus box For This Useful Post:
Old 08-10-2015, 11:41   #9 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
ok, done, but,how to repair imei for this model ( A500m Double sim) ? is possible or no?
Old 08-10-2015, 15:47   #10 (permalink)
Cheater -Don't Deal with him-
Member: 1965371
Thanks Meter: 441
repair imei only write certificate.
Old 08-10-2015, 16:21   #11 (permalink)
Member: 1146942
Sonork: 100.1587278
Currently IMEI of SM-A500M phone can be repaired only via "Write Cert" operation. Please check your PM, we have sent You test Software version, with which You will be able to write Cert files for IMEI A and B.
Enter *#0011# in and make a screenshot/photo of this menu. Then try to perform "Write Cert" operation, using test Software version and post here results.
Old 08-11-2015, 12:09   #12 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
sim 1 = signal OK
Sim2 = No servce
Plataforma: Samsung Android
Porto seleccionado: COM4
Modelo seleccionado: SM-A500M
Select Certificate2...
Selected file: C:\Users\Celetronic\Downloads\Cert-SM-A500F_356317062038144.cert
Found phone on COM4
Escrevendo novo IMEI do telefone...
Para aplicar os cāmbios, reinicie o telefone
Old 08-11-2015, 12:21   #13 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
Ok, i invert simcard in slot and now sinal ok in sim 2....only ( Oi perator)....
Old 08-11-2015, 12:58   #14 (permalink)
Member: 1146942
Sonork: 100.1587278
Most likely the problem is with SIM card. Please try to use another SIM card.
Old 08-11-2015, 19:52   #15 (permalink)
Member: 700706
Sonork: 100.1590381
Thanks Meter: 208
no,this cert not work in all operators,
do you have other cert ?
Page generated in 0.22673 seconds with 9 queries
