02-23-2017, 18:31 | #1 (permalink) |
Crazy Poster Join Date: Jul 2015 Location: Italy
Member: 2426290 Status: Offline Thanks Meter: 19 | a510f no root no downgrade no cert ----------------------------------------------------------------------------------- To connect SM-A500FU phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. 6. Go to dial window. 7. Enter "*#0808#" number. 8. Select "DM+Modem+ADB". 9. Press Home button. 10. Press "Read Info" in software. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-A510F Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM4 Selected model: SM-A510F Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-A510F Proper android device not found. Make shure that "USB debug" option on the device is turned on. Reading EFS failed. Performed by 2.4.7 Software version. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM6 Selected model: SM-A510F Please, press "OK" button on the phone to allow USB debugging.. Detected phone model: SM-A510F Firmware compiled date: Fri Dec 9 13:42:49 KST 2016 PDA version: A510FXXU3BPL8 CSC version: A510FOXY3BPL8 SW version: unknown Phone SN: RZ8H20MRZ6B Android version: 6.0.1 (MMB29K) Sales code: SER Country: Russia HW platform: exynos5 HW Chip: exynos7580 HW Modem: unknown Security patch level: 2016-12-01 Codename: a5xeltexx Checking Root: Phone is not Rooted. Reading EFS failed. Performed by 2.4.7 Software version. Selected firmware file: Security-SM-A510F-26-07-2016_16-44- 22.asec.asec Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Writing firmware Canceled Performed by 2.4.7 Software version. Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. Selected firmware file: A510FXXS2APE2_A510FOJV2APC1 _A510FXXS2APE1_HOME.tar.md5 Please put the phone into Download Mode and connect USB cable. To put SM-A510F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Found phone on Invalid file format Performed by 2.4.7 Software version. |
